Question about General Electric GTDP490EDWS GE 7.0 Cu. Ft. DuraDrum Electric Dryer with HE Sensor Dry
General Electric GTDP490EDWS Gas Dryer will not turn on, power source checks ok.
Wiring diagram
Look online. There are plenty of sources that has schematics and wiring diagrams.
You can also check inside, behind the steel panel on the back of the dryer.
Apr 08, 2016 | GE GTDP490EDWS Electric Dryers
I have a gas dryer is it also electric dryer also
Up to my knowledge, GAS dryers work with gas
Sep 11, 2015 | Dryers
What to check when Dryer heats, but not moving air?
Does the dryer sometimes stop heating? Do you always use the lint trap when using the dryer?
May 02, 2014 | General Electric GTDP490EDWS Front Load...
Takes too long to dry clothes
You may have a clogged air vent, check that the air vent hose is not smashed, if it is not smashed, have your dryer vent cleaned professionally, all the way from where the dryer connects to the wall to where the vent leaves the home,
Recheck the dryer operation, dryer vents should be cleaned every other year for optimum performance
Feb 16, 2014 | General Electric GTDP490EDWS GE 7.0 Cu....
Takes several cycles to dry
Dryer model # GE DHDSR46GGWW igniter glows but no flame or indication of gas. At first when I hit the solonoid it ignited, but not anymore. I checked the connections, all seem ok. I figure the solonoid is...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101[][
Sep 01, 2011 | General Electric DHDSR46GGWW Gas Dryer
Was still tumbling but no heat, and now it wont even turn on checked breaker to see if power was ok that was ok.
heatman101
Jul 06, 2011 | Dryers
Had dryer 2 months it is not heating af has been checked and still doesnt heat up checked power source and still no heat
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 04, 2010 | Whirlpool GEW9250 Electric Dryer
No heat dryer
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Apr 07, 2009 | General Electric DBXR463EG Dryer
General Electric GTDP490EDWS GE 7.0 Cu. Ft. DuraDrum Electric Dryer with HE Sensor Dry Logo
49 people viewed this question
Top General Electric Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Donni Steen
Are you a General Electric Dryer Expert? Answer questions, earn points and help others
