Question about Crafts & Hobbies
Cuttlebug tutorial - Crafts & Hobbies
How can I turn off tutorial
How to disable newbie tutorial options? - Forums - World of ...
us.battle.net > ... > Forums > Support > Customer Support
Battle.netJan 14, 2011 - Also, is there a way to disable the large pictures of the quest ... Menu -> Interface -> Help -> Uncheck Tutorials....and if it doesn't do away after ... How do I turn off the tutorial pop ups? - Forums - World of ...
Sep 29, 2015
Practice =/= Tutorial - Forums - Heroes of the Storm - Battle.net
Dec 4, 2014
More results from us.battle.net
how to turn tutorial mode off in runescape 3 - YouTube
? 0:40
https://www.youtube.com/watch?v=wPI2XAV8U7Y
Aug 3, 2013 - Uploaded by Nazibb RS
how to turn tutuorial mode off in runescape 3 this is a guide show you how to turn your tutorial off in ...
Can I turn off the Tutorial in Fallout Shelter - Arqade
gaming.stackexchange.com/.../can-i-turn-off-the-tutorial-in-fallout-shelte..
Jan 25, 2016 | Tablets & eReaders
What exactly is die cutting?
Die cutting is manufacturing a lot of the same shape from a material. You can do it with fabric or wood, plastic, etc. The shapes you create are called blanks and are usually used decorated before they are sold.
Feb 27, 2013 | Crafts & Hobbies
Cuttlebug machine
Hi Mike, it was your name i noticed, it is not Mcmurtha by chance is it, if it is we are related
Nov 14, 2011 | Crafts & Hobbies
Side popped off Cuttle bug now no pressure
Mine has just done the same, have you found a solution?
Feb 07, 2010 | Provo Craft Cricut Disney Font Cartridge
Cannot use die cuts
No I don't think your machine is defective. Here are some "sandwich" ideas to help you. I know you asked just for Cuttlebug dies; I included other "sandwiches" that you can do with your Cuttlebug. If you need further assistance feel free to contact me.
Cardstock
Chipboard
Magnetic/ Metal Sheets & Thin cork (Media)
Cuttlebug Dies
Plate “A”, Plate “B”, Die (cutting side up), Cardstock, Plate “B”
Plate “A”, Plate “B”, Die (cutting side up), Chipboard, Plate “B”
Plate “A”, Plate “B”, die (cutting side up), Media, Plate “B”
Cuttlebug Embossing Folders
Plate “A”, Plate “B”, Folder (with cardstock inside), Plate “B”
Plate “A”, Plate “B”, Folder (with chipboard inside), Plate “B”
Plate “A”, Plate “B”, Folder (with metal sheet inside), Plate “B”
Nestabilities
You will need Spellbinders Tan Embossing Mat to emboss in
Cuttlebug™ machine (or a plumbers gasket cut to size, or some use a mouse pad)
Cutting Sandwich - (Stack from bottom up)
1. A plate
2. C plate
3. Spellbinders Die (cutting side up) that means the side with the
ridges
4. paper or cardstock
5. B plate
6. Run through Cuttlebug™ machine.
Embossing Sandwich- (Stack from bottom up)
*Remove C Plate for embossing sandwich
1. Place A plate on bottom
2. Leave die face up on A plate with die cut still in the die.
3. Place one Spellbinders Tan Embossing Mat on top of the die.
4. Use 2 or 3 pieces of cardstock to shim.
*Cautionary Note: Using more than 3 pieces of cardstock to
shim Cuttlebug Embossing sandwich will result in B Plate
breakage. When using Spellbinders Edgeabilities card making
dies, shim with only 2 pieces of card stock.
5. Place two acrylic B plates on top of sandwich and run thru
Cuttlebug machine to emboss Spellbinders die cuts.
6. Turn die over and use like a stencil with inks and chalks for
added detail.
BigShot Embossing Folders
Plate “A”, Plate “B”, Folder (with cardstock inside), Plate “B”, Cardstock shim
BigShot Large Dies
Plate “B”, Cardstock, Die (cutting side down), Plate “B”
Revolution Dies
Plate “A”, Plate “C”, Die, Cardstock, Plate “B”
Sizzlit Dies
Note: Provocraft suggests using Plate” C” instead of the second Plate “B”, however, CB owners have cracked plates, so try with two “B” plates first.
Sizzix Original Dies & other Steel Rule Dies
Plate “B”, Chipboard, Die (cutting side down), Plate “B”
Sizzix CutNFold Dies
Plate “A”, Die, Cardstock, Plate “B”, Chipboard shim
Also try:
Plate “B”, Cardstock, Die, Chipboard shim (maybe 6 layers)
Sizzix Embossing Folders aka Simple Impressions
Also try:
Plate “A”, Chipboard shims, Folder (with cardstock inside), Plate “B”
QuicKuts Dies (Regular)
Plate “A”, Plate “B”, Die, Cardstock, Plate “C”
Plate “A”, Plate “C”, Die (cutting side up), Chipboard, Cardstock shim, Plate “B”
QuicKuts Dies (Grand)
Brass Embossing Stencils
Plate “A”, Plate “B”, , Brass stencil ,paper/cardstock,mouse pad (cut to size, rubber side down), Plate “B”
Sandwich may need to pass through several times based on cardstock thickness
Or use plumber’s black rubber plus red rubber gasket, instead of mouse, then add last plate B.
Big Impressions Texture Plates
Plate “A”, BI texture Plate, Cardstock, Silicone Rubber pad (from BISK), Impressions Pad (from BISK)
*BISK-Big Impressions Starter Kit
Fiskars Texture Plates
Plate “A”, Fiskars texture Plate, Cardstock, tan Wizard pad, black or tan Wizard pad, (possible Cardstock shim,) Plate “B”
Also try:
Plate “A”, Fiskars texture Plate, Cardstock (lightly misted with water), 2 layers Fun Foam, Chipboard Shim, Plate “C”
Also try:
Plate “A”, Fiskars texture Plate, Cardstock (right side towards TP), Rubber Plate (made from Plumber’s rubber gasket), Plate “C”
Plastic thin stencils
Here too- may try
Plate “A”, Plate “B”, , plastic stencil, cardstock, black rubber, red rubber, plate B
Jan 28, 2010 | Provo Craft Cricut Disney Font Cartridge
Cuttlebug breaks apart when a cutter is put throught can anyone have sujestions thks ray
The reason this is happening is because the metal casting (inside the green plastic casing)  on one side (where the driving cogs are) has cracked due to trying to force through something that was too thick..
Unfortunately there is nothing that can be done with it apart from complain to the manufacturer
Apr 27, 2009 | Provo Craft Cricut Disney Font Cartridge
Crafts & Hobbies Logo
Top Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
