Question about Frigidaire 20.6 cu. ft. / 583 liter Upright Freezer FFU2124D
My freezer makes a loud popping noise 4 or 5 times a day but freezes fine, it just makes that noise,what is it
    Habit-Forming:
  • 188 Answers
Maybe the ice maker?
Posted on Dec 29, 2013
3 Suggested Answers
SOURCE: Brand new unit, compressor noise.
Since I could get no one to tell me about new freezer compressor making buzzing noise while on, I had the store come a pick it up and give me my money back.
Posted on Apr 29, 2009
  • 64 Answers
SOURCE: my freezer stopped freezing and is making a loud
the loud buzzing is the freezer high temp alarm. dont know why its warm though.
make sure you don't store anything on top of or on the sides of the unit as the condenser of most freezers are buried in the walls of the unit and it will over heat the compressor. if unit is in a hot garage this will compound the problem.
Posted on Jul 02, 2009
Loud clanging noise from Kenmore upright freezer
Check the condenser fan (outside at the rear) and check the coil isn't baking hot. Electronics or board wouldn't cause your symptoms. Check the simple things first!
Jul 10, 2012 | Freezers
Freezer makes intermittent fan noise
one time i ran into this problem and found out the lady was putting hot things in the freezer creating alot of moisture. check your door seal also make sure its sealing if it had gaps you can heat it up with a hairdryer to streach it out.
Mar 28, 2010 | Whirlpool 16.7 cu. ft. / 473 liter Upright...
Upright freezer makes a loud rattling sound, like something is loose. Doesn't do it all the time, but does several times a day.
have a look behing your drws in the freezer it has probably started to freeze and the fan that blows the cold air around will have an ice build up. The noise you hear is the fan bashing against the ice. The fan is normally situated behind the panel in the freezer section.
Hope this helps
Mar 22, 2010 | Whirlpool Freezers
My freezer stopped freezing and is making a loud buzzing noise with the red light on at the bottom. Cant sleep HELP
Jul 02, 2009 | Frigidaire 20.3 cu. ft. Upright Freezer...
Apr 28, 2009 | Frigidaire 12.8 cu. ft. Chest Freezer...
Loud bang
John,
What you are hearing is popping caused by thermal expansion inside the evaporator enclosure during its' defrost cycle.
Depending on your make and model, it'll go into defrost every 8 to 12 hours of compressor "run time". That is, the defrost timer "monitors" how long the compressor runs and after it accumulates the pre-set "run time", the timer then shuts the compressor off and initiates its' programmed defrost routine. This routine lasts for 20-30 minutes, or until the defrost thermostat opens.
The defrost routine sends 120 volts to a heating element in the evaporator compartment which gets red hot. This sudden temperature change (from below freezing to warm) causes the cabinet to expand slightly. That's when you hear the "Pop".
I hope this helps, John. Thanks for using FixYa, and don't forget to rate my answer.
SG
Apr 02, 2009 | Freezers
Upright freeze made a popping noise like a thermostat
If you heard the noise at a fairly routine rate and time it was probably the defrost timer motor. Locate it and you should be able to engage it manually. It is a plug and go part to replace. Be sure to take the old one along with the make n model # with you to the parts house!!
Jan 17, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
A constant loud rattling noise throughout most of the day and night from a KGN33V60 model, appearing to come from the freezer compartment, for a very long time. This is the third replacement model we have...
Lots of stuff can cause noise. The only moving part in the freezer is the fan. I don't know of anything else that moves. If ice build up is an issue, then there are several things to concider.
Not enough defrost time. Cycle too short or heaters are not hot enough for some reason. Could be undersized heaters from manufacturer.(?) Defrost timer could be bad causing short or no defrost at all. This timer also controls the defrost heaters and compressor being off during defrost.
Be sure the seal around the door is tight. No air gaps. Warm air (contains moisture) will cause freeze ups. Long shot is that the thermostat is bad and unit never shut off. If timer is bad, compressor coudl be running during defrost cycle.
Hope this helps
Jan 15, 2009 | Freezers
Freezer/Refrigerator tempurature swinging wildly
The compressor is overheating and not starting. Could be just the start relay. If this happens again try unplugging it for about an hour then it should work for a while. Heat between doors is normal this is an electric heater designed to keep the doors from sweating. You just noticed it because the refrigerator wasn't cold.
Jun 26, 2008 | Freezers
Noise
When the freezer goes into defrost mode, some thumping/popping noises can sometimes be heard as the defrost heater melts the ice built up on the evaporator. Quite normal.
Nov 01, 2007 | Kenmore 12.8 cu. ft. / 362 liter Chest...
Frigidaire 20.6 cu. ft. / 583 liter Upright Freezer FFU2124D Logo
488 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Dan Webster
Dan Webster
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
