Question about Troy-Bilt Garden
Cant get a spark on my briggs and stratton 4hp engine, trying to
Engine bee stood for some time.plenty of compression, also magneto on top of flywheel has moved and do not know the gap. I just finished rebuilding my 8hp magnetron briggs which is on my pto horse, repainted all while it was apart. I had it bored 10 over, valves ground,when I got it all together no spark. Just installed new coil, took head bolt out cleaned it to insure ground to block no help. I had to do that to the starter too.
    Problem Solver:
  • 5 Answers
Doooh!!!! had the coil on backwards this will cause a weak or no spark situation. Should have had my glasses on , there is a faintly perceptable this side out on the new coils. Also there is no mention of this in the directions.
Posted on May 19, 2009
Husqvarna yth22v46 no start. Backfires
Most common issue with this engine is a broken flywheel key. The key is a small piece of metal used to locate the flywheel to the crank. if the flywheel nut is not to the right torque it can slip breaking the key and putting the ignition timing out. Your symptoms fit this.
This page shows single cylinder engine info, but it is relevant. I quick search on YouTube will show many videos on how to check and replace this key.
How to Inspect Flywheel Key for Replacement Briggs Stratton
Jan 22, 2018 | Cars & Trucks
Why my 6.5 craftman eager-1 has no spark
Check the engine stop wire where it connects to the carb mounting plate. make sure it is not shorted to ground. Remove the top cover from the engine and check the flywheel to magneto air gap, it should be about .020 of an inch, this is about the thickness of a matchbook cover. Also check the spark plug wire and the connections, make sure they are clean and tight. The magneto is the y shaped piece behind the flywheel. Remove the flywheel holdown nut and washer and make sure the notch in the flywheel and in the crankshaft are across from each other. If they are not, you will need to remove the flywheel, and replace the aluminum key that goes there. The notches need to be aligned for the ignition timing to be correct. I hope this helps, good luck. Dan
May 23, 2014 | Briggs & Stratton Briggs Stratton...
I need to find a user manual for a briggs and stratton 4hp engine
always check spark and compression first spark needs to be blue and compression should be 120 but will barely run on 80psi if both are fine rebuild and acid dip carb
May 14, 2012 | Briggs & Stratton Measuring Tools &...
I have a 17.5 briggs and stratton intek engine it turns over but wont start and its backfiring pretty bad do you have any idea what it could be thank you
There are 2 things that cause backfiring.
1. Dirty valve seats where the valves are bypassing compression
2. The engine flywheel key partially sheared or sheared and the engine is firing out of time.
Do a compression test. You should have 110 minimum PSIG indicated but 120 + is desired. I think you will find there is a compression problem.
If the compression is good use 2 new spark plugs and attempt another start. After the spark plucg change the wiring to the magneto and the magneto to be tested.
If you can not tdetermine the problem I need your exact engine model and type numbers (ALL of it) so that I can get you service manual data to assist in repairs.
Thanks for choosing FixYa,
Kelly
Aug 03, 2011 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
I have a craftsman 675 and it has not spark. I have replace the coil/magneto with no change to the lack of spark. I am wondering if the coil is not grounding properly. Any ideas, Thanks?
I believe your problem is not the coil/magneto but rather your timing. If you hit something hard with the blade you most probably sheared the timing key. This key is what keeps your flywheel in the proper timing position.
Remove cover top of engine, remove flywheel bolt,remove flywheel, remove key. If key is sheared off or even dented replace.Put back together. Happy mowering.
Jun 14, 2011 | Craftsman 675 Torque 190cc 21" Briggs ...
I have a Briggs & Stratton 18.5 HP Twin Cylinder engine that has no spark. How can I check the magneto? And, there is a wire that goes to the magneto. Should there be 12v to that wire? If I replace the...
It all depends on the model of engine. If it is a twin engine doesn't it have two magnetos.Very unusual for both to go bad It will depend on the type of ignition(points or solid state) The wire going to the magneto could be the kill switch (kills when grounded) Disconnect it and see if you get spark. IF so then it is in your safety/ignition circuit. If you replace magneto usually the gap is .008-.012
Aug 18, 2010 | Garden
Engine will not fire {no spark }
Did you sand the rust off of the flywheel? where the magneto is. And did you set it right? It has to be real close to the flywheel. The thickness of two pieces of paper. And yes the pto switch will keep it from starting. If it is ingaged it wont start. Can you hear it enganging when you connect the battery? Try turning switch on and off see if it will kick in and out. With key on
May 10, 2010 | Yard Machines 155 Torque Briggs Stratton...
Timing for briggs and stratton 15.5 engine
There are no timing marks, timing is correct when the flywheel key is in place, the flywheel is properly torqued and the air gap for the magneto is properly set
May 18, 2009 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
gap from coil to flywheel is .010. if you've replaced coil, points and condenser with no spark i would try replacing the coil and points with an magnetron kit or a coil that allows for the elimination of points.
Mar 21, 2009 | Briggs & Stratton Ignition Kit 2-8 HP...
Garden Logo
272 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Jim Parker
Jim Parker
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
