Question about Discovery Channel Discovery Kids - Rocket Ship Projection Clock
Discovery Kids Rocketship Alarm Clock Up/Down buttons do not work
Cannot set time, etc.
HOW IS IT POSSIBLE THAT WHEN MY Isuzu 320 not starting after replacing the Timing belt please give some pictures of the whole set how to inline my timing.
this website has books on how to service, repair, operate, maintain etc, any vehicle, heavy equipment and you can find all wiring diagrams, electrical, torque settings, error/fault codes, PCV, removal, installation, assemble etc, a lot more.
Try it
www.reliable-store.com
May 24, 2018 | Isuzu Cars & Trucks
How do I keep the display set to TIME on Optimum 60100?
If you wish to get some details about treadmill repair ; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Sep 06, 2016 | York Exercise & Fitness
How do I set the time on the discovery kids rocket alarm clock?
ALL u do is go on the button to the right click it and hold
Jan 19, 2015 | Toys
Need instructions for Discovery Kids Projection Daisy Bloom Alarm Clock
1.set time: hold down "clock" button for five seconds, then use up and down arrows to change, and press "clock" button once to toggle between month/day/year/hour/minute. Try it a few times b/c sometimes it just goes to the alarm setting (i don't know why, i think it's a glitch).
2.set alarm: hold down "alarm" button for 5 seconds, use up and down arrows to change, press "alarm" button once to toggle between hour/minute. press "clock" button to return to clock
3.turn on/off alarm: press "alarm" button once, press up to turn alarm on and press up again to turn alarm off. press "clock" button to return to clock
4.to project the images: push the buttons that look like video cameras. to focus the image, rotate the cylinder around the lens that projects the image. on the daisy clock, there's a button on top that you can use to flip the projected image of the time upside down. use the dial next to the lens-cylinders to select a different image (you may need to point the cylinders in a different direction to reach the dial)
Aug 19, 2013 | Bon-Ton Kids Discovery Kids Projection...
I need discovery kids tm daisy clock manual
1) set time: hold down "time set" button for five seconds, then use up and down arrows to change, and press "time set" button once to toggle between month/day/year/hour/minute. If it goes to the alarm setting instead of time setting, try again.
2) set alarm: hold down "alarm set" button for 5 seconds, use up and down arrows to change, press "alarm set" button once to toggle between hour/minute. press "time set" button to return to clock
3) turn on/off alarm: press "alarm set" button once, press "up" to turn alarm on and press "up" again to turn alarm off. press "time set" button to return to clock
4) to project the images: push the buttons that read "time" or "image". to focus the image, rotate the cylinder around the lens that projects the image. use the dial near the lens-cylinders to select a different image
5) military time: press the "up" button when the time is displayed (not when you're setting the time)
Good Luck!
Jun 22, 2013 | Toys
Discovery rocket ship clock alarm off
You have to press the alarm setup, then press the up button. This turns the alarm off completely. If you want the alarm to go off again tomorrow you will have to set it again.
Feb 10, 2013 | Discovery Channel Discovery Kids - Rocket...
How do I reset alarm?
1. Press the Alarm Set button to display the current alarm.
2. Hold down the Alarm Set button for a few seconds. This will cause the time to flash.
3. Press the Up/Down buttons to reset the new time.
4. Press Alarm button once more to set minutes. Press again to exit alarm setup.
Cheers!
Jan 22, 2013 | Discovery Channel Discovery Kids - Rocket...
How do I turn off the alarm clock? It keeps coming on every 5 minutes
When you are in alarm setup mode the Up button Is your on-off switch
Dec 27, 2012 | Discovery Channel Discovery Kids - Rocket...
Discovery Channel Discovery Kids - Rocket Ship Projection Clock Logo
89 people viewed this question
Top Discovery Channel Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Discovery Channel Audio Player and Recorder Expert? Answer questions, earn points and help others
