Question about Sharp 25J-M100 TV
Input jacks in Sharp 25J-M100/ Pc to Tv cable
I'm planning to buy a PC to TV cable as a gift for my DH to use with our Sharp 25J-M100 tv which he picked up at a sale. I'm unable to figure out the what type of input jacks are present on the TV. I can see one jack for audio and another for video. Please clarify.
Our laptop is a Dell Inspiron E1405 which has the following output jacks - Video: 15-pin monitor connector and S-Video: 7-pin mini-DIN connector (I think those are the VGA and S-Video jacks, correct me if I am wrong).
Appreciate your inputs/ suggestions on what all I need to purchase so that we can stream internet videos/programs to our TV.
Thanks much,
Belle
You can purchase an s-video to composite video connector to view your Dell computer's television output on your sharp CRT television, though the image will be a bit blurry because of the connection and CRT technology limitations, though streaming video probably can be seen just fine. An example of an s-video to composite video connector can be found here: http://www.svideo.com/svideorca.html
but you probably can find a cheaper priced unit somewhere else, maybe even at radioshack.
I hope this helps!
Posted on May 29, 2009
Sharp instruction manuals
Contact Sharp customer service on the web..Sharp website...give them the model number you gave us.
Sep 04, 2014 | Sharp 25J-M100 TV
Tv showing with lines, screen blank but hearing clearly.
its white retrace fault, check video section or crt internal short problem
Apr 23, 2014 | Sharp 25J-M100 TV
Sharp aquos audio input jack not working
That 3.5 jack only works when the TV input is selected for PC. Try an HDMI or Hi def cable connection to the TV
Dec 14, 2013 | Sharp Aquos Televison & Video
We have a Sharp 25J-M100 and we cannot turn off the Closed Caption. We hit menu on our Sharp Remote Control and go down to Closed Caption and make sure it is off. The words never go off of the screen. Our...
If the captions are turned off on your TV, they have to be coming from your cable box. The TV is just displaying what it's getting. Check your cable box menu and make sure captions are turned off there. Cable boxes, especially on digital systems, can prevent the TV's caption decoder from operating properly. So they need to be able to provide captioning, and I suspect you've turned it on somehow. Comcast should be able to tell you how to turn off captions if you can't figure out the menus.
Jul 15, 2011 | Televison & Video
Tv switches on for about 3 seconds ,then switches off
The capacitor(s) of TV power supply spoiled and need replacement. Please check it out and get replaced. The purpose of capacitor is to stabilized power supply.
Regards, vote please, Jay
Jan 20, 2011 | Sharp 25J-M100 TV
Hookup a dvd to the Sharp 1999 25L-M100B
ron-goss: this model does not have the external a/v jacks for the cable out from the dvd to tv, you'll need to buy a RF modulator it comes with its own installation instructions, you can find it at your local radio/tv
store or electronics department of any convenience store.
Aug 24, 2009 | Sharp 25L-M100 25" TV
Connecting to a pc
you need hdmi cables yes
Aug 15, 2008 | Sharp 19R-M100 19" TV
Code for universal remote
One website (Universal-Remote.Net) , says the setup code for a Sharp TV, using a Philips universal remote, is one of the following numbers: 002, 013, 014, 111, 502, 712, 812, 813, 913, 918.
Hope these numbers work for you. Please take a moment to rate this info, using the rating system below, after you have tried these numbers. Thanks.
Jul 15, 2008 | Sharp 25J-M100 TV
SHARP TV - MODEL 25j m100
The RF jack is solder directly into the tuner module and as long as it did not break the circuit board inside that it connects to, it can be repaired . Takes a lot of heat though to solder the jack to the frame of the tuner. Sometimes I use 2 irons to get it hot before the plastic guts of the jack melt too bad. Also is sometimes hard to cram the jack back into its mounting hole, may need to file it out some. The makers don't solder these on they are just pressed in and crimped which is why they break off so easily. I recommend using the push on type cables to avoid this problem. Don't forget to solder the center conductor into the tuner board.
Hope Ya Fix It!
Feb 21, 2008 | Sharp 25J-M100 TV
Earphone
hi there, some tv model have the option for earphones, others don't, ty
Dec 29, 2007 | Sharp 25J-M100 TV
Televison & Video Logo
296 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
