Question about Acer S200hl Abd 20" Class Widescreen Led Monitor
How can I clear up a blurry screen? - Acer S200hl Abd 20" Class Widescreen Led Monitor
Hp dv6000 laptop screen blurry
Hello Al,
I hate to inform you but the graphics chip in these laptops are known for doing this. HP is aware of that. Every time some one brings me a Hp Dv6000 laptop about 75% of the problem is the system board or overheating issues.
First try cleaning the laptop screen with laptop screen cleaner
Walmart LCD Display Screen Cleaner for TVs Computers and Cameras
if its still blurry connect a external monitor to your laptop to see if the display is blurry on the external monitor (to get to toggle the video from your laptop you will have to press the Fn key + F4)
If its still blurry then its the graphics card or chip needs to be replaced. They are all integrated with the system board / mother board.
If its clear and images are good then the laptop screen will need to be replaced. hope that helps.
Jan 21, 2014 | HP Pavilion dv6000z Notebook
View finder
Ok. On your viewfinder, there might be a round dial. Turn it to adjust focus. Otherwise, sometimes viewfinders are like that... blurry, especially electronic.
Apr 19, 2009 | Sony Cyber-shot DSC-H5 Digital Camera
Blurry screen
It may be a bad VGA cable. If you twist and wiggle the cable on the computer connected end the blurred screen will clear up.
May 14, 2008 | Gateway FPD1760 17" LCD Monitor
Fuzzy pictures
The blurry pictures are due to movement. Sometimes adjusting the flash helps.
Mar 19, 2008 | Samsung Digimax S630 Digital Camera
Lcd screen is blurry!!
http://www.imaging-resource.com/NEWS/1164376280.html
Nov 30, 2007 | Canon PowerShot A85 Digital Camera
Blurry Screen
The bottom is blurry because some of the anti-freeze (clear ethelyne glycol) has leaked out. This anit freeze needs to be replaced or the CRT will get too hot and break. It will also clear up the picture.
Dec 05, 2006 | GE 46GW947 46" Rear Projection Television
Screen goes from blurry to clear to blurry
The first thing to check is for loose conections,the problem is related to the high voltage but it can start in the main board with one component loose,when the high voltage is developed it goes to what is call the distributor block,a lot of sets have the focus and screen controls coming out of this block for each picture tube,this block might be bad but before we go to him we need to check everything is solid in the main board.If you are familiar with electronics you can remove the back cover and tap the chassis with a wooden or rubber handle to see if the set reacts,if it does you need to be atentive what area makes it react and flip the board to do some resoldering,If you are not too familiar with tv service you need the assistance from a servicer.Let Us know how it goes or if you need more information.
Oct 27, 2006 | Zenith H32G48S TV
Acer S200hl Abd 20" Class Widescreen Led Monitor Logo
15 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
