Question about Hotpoint Refrigerators
Why do I smell paraffin coming from the fridge
Sour smell coming from back of fridge on outside
Check the drain pan under unit. Maybe something has got in there. May need to remove the back our go through the front. Can pour a very small amount of bleach our Lysol to kill in the drain pan to kill mold. Hope that helps.
Aug 18, 2012 | Hoover Refrigerators
Need instructions on how to use Dr. Scholl's Thermal Therapy Quick Heat Paraffin Bath -- how long to leave hands/feet in melted wax, how long to leave wax on, what to do after removing wax any...
How to fill your Dr. Scholl's Thermal Therapy Quick Heat Paraffin Bath1. Take the lid off your bath container and remove all packing materials.2. Place the unit on a flat, heat-resistant surface.3. Remove the plastic rack.4. Remove all three blocks of paraffin wax from the plastic wrapping. Each block is equal to one pound of paraffin wax, and three pounds of paraffin wax are needed to begin using your Paraffin Bath. Break each block in half, then in half again.5. Place the blocks of paraffin wax in the Paraffin Bath container.6. Plug the unit into an electrical outlet. The green light will glow. The red "Heater" light will initially come on and then cycle on and off while the wax is melting.7. Replace the lid and turn the switch to the "high" position. The paraffin wax will be ready for use when it is visibly melted (approximately 120 minutes).8. As soon as paraffin wax has melted, place the plastic rack on the bottom of the heating chamber. This will protect hands, elbows, and feet from heat.9. Turn the dial to the "Keep Warm" setting and wait 25 minutes before dipping hands, elbows, or feet.
Warning: DO NOT place hand or any other body part inside the chamber while the unit is melting the wax.
How to Dip Hands1. Remove jewelry, roll up sleeves, and thoroughly wash and dry hands. You can also rub in some of your favorite hand lotion.NOTE: The lid should be on during the time the unit is heating. Put the lid back on the unit after each use.2. Put a small amount of wax on the inside of your wrist to test the temperature.3. Spread fingers apart slightly and slowly immerse your hand in the paraffin wax container. Then immediately, but gently, remove your hand from the Paraffin Bath chamber. Let the paraffin wax solidify on your hand. Wait at least three seconds (until the paraffin wax no longer appears shiny) before redipping. Be careful to avoid touching the sides or the bottom of the Paraffin Bath chamber.4. Continue to dip your hand in and out of the paraffin wax, following Step 3, to build up layers of paraffin wax. For the best results, do this at least five times. The more layers, the longer the heat will last.5. If desired, cover your hands with glove liners and place your hands in the insulated mitts. These retain heat for better results.6. Remove the hand mitts from your hand. Remove the plastic glove and discard. Peel the hardened paraffin wax from your hands. It is recommended that the hardened paraffin wax be discarded.7. Massage in the oils left on your hand after the paraffin wax is peeled off to get the full invigorating and rejuvenating benefits of your Paraffin Bath.NOTE: Allow the paraffin to remain in place for 10-15 minutes before removing; longer if more layers exist or if the mitt has been used previously.
To Treat Feet or ElbowsFollow steps 1-4 as outlined for hands. Mitts are intended for use with hands only.
Product Care and Maintenance Place paraffin bath in a safe, cool and dry place when not in use. Wipe with a soft, damp cloth. DO NOT use abrasive cleaner. Never submerge the unit in any liquid. Keep away form all solvents and harsh detergents. DO NOT attempt to repair this paraffin bath. There are no user-serviceable parts.
STORAGEWhen not in use, "unplug it."Allow appliance to cool and store out of reach of children in a safe, dry location. To protect from dust or dirt, simply store in its original box. Never wrap the cord around the appliance since this will cause the cord to wear prematurely and break. Handle cord carefully for longer life and avoid jerking, twisting or straining, especially at plug connections.
CLEANING INSTRUCTIONSRemove plastic rack from heating chamber.1. DO NOT unplug the Paraffin Bath. Allow paraffin wax to remain undisturbed for a few minutes.2. Turn unit off and let the paraffin wax "harden."3. Right before cleaning, turn the unit on again until the paraffin wax is visibly melted around the entire edge (approximately 3-5 minutes), then turn unit off and unplug from the electrical outlet.4. Spread an ample amount of paper towels on a hard, flat, heat-resistant work surface and slowly turn the unit upside down to allow the hardened paraffin wax to drip from the chamber onto the paper towels. Allow the surface of the paraffin wax block to harden and then discard it. To clean the empty chamber, wipe with paper towels to remove any sediment.5. To clean the outside of the unit, remove any solidified paraffin wax.6. DO NOT use sharp objects to remove solidified paraffin max.7. DO NOT scratch or damage the Paraffin Bath chamber.8. DO NOT use abrasives when cleaning the Paraffin Bath chamber as it will damage the finish.9. If you discard the paraffin wax after each use, we recommend you clean out the unit completely every 40 uses. If you re-use the paraffin wax after every use, we recommend you clean out the unit completely every 20 uses.
PLEASE NOTE: This appliance should not be used in the presence of open cuts or wounds, inflammatory skin conditions, growth peripheral vascular disease where circulation is impaired, acute inflammation, or where sensation of the extremity is reduced or absent. If there is any question about peripheral vascular disease or decreased sensation of the extremities, consult a physician or physical therapist before using the Dr. Scholl's Thermal Therapy Quick Heat Paraffin Bath. Discontinue use if dermatitis due to paraffin sensitivity occurs. Discontinue use if wax feels too hot or cool, which could indicate health problems with the user.
There are also a bunch of standard warnings about dealing with electric appliances. Take care of them, don't dump them in water, etc., etc., etc.
It's worth pointing out that paraffin wax is flammable.
Jun 19, 2011 | DR Scholl's Drsp3752 Paraffin Bath
We lost the factory manual. Once the wax is heated please guide us through each step and the duration? Any help would be greatly appreciated. Thank you so very much and God Bless!
Feb 10, 2011 | Revlon Spa, Moisture Stay Paraffin Bath 1...
Phillips whirlpool built in fridge /freezer smell coming from the fridge section,we have tried various things but the smell still persists
Could it be that there is degradation of the plastics due to heating of the defrosting coils or is it the smell off leaked gas.
Remove all the food stuff from the fridge and clean, wash the inside throughly. Now restart the fridge and after aboutone hour check for smell, continue this till you notice, if the smell comes in after about 10 hours then you must look into the defrosting heater for any traces of material on it causing the smell on heat.
Aug 30, 2010 | Whirlpool Refrigerators
We have a Meile fridge freezer and the smell seems to be coming from the back (no smell inside)It has been a constant smell but occasionaly gets worse. It has taken us a week to find out that its coming...
Self de-frosting tray at the back of the fridge was full of old stagnent water. Removed tray cleaned out, flushed out the pipe from the inside of the fridge to the drip tray. No more smell.
Nov 02, 2009 | Refrigerators
Bosch classixx fridge freezer - smell coming from fridge. Can only smell when door opened.
bad eggs smell coming from behind Bosch fridge freezer. There is no bad food in fridge. Any comments appreciated. Linda
May 02, 2009 | Refrigerators
Bad smell coming from fridge
Unplug fridge. Remove the panel on the back of the fridge look for dead rodents or fungal growth in the drain pan. consult your local appliance parts distributor for a product called kleene air or try www.reliableparts.com
Apr 01, 2009 | Refrigerators
Odours from fridge
frigidare makes a product called fridge- aid you can get it at lowes or any appliances parts store its made of activated coconut charcole it might solve you promblem
Jan 08, 2008 | Frigidaire FRS26R4A Side by Side...
Fridge Smell
i have a whirlpool fridgefreezer and their is a very bad smell comming from the back of it what can it be
Aug 02, 2007 | Hotpoint FFM70 Bottom Freezer Refrigerator
Refrigerators Logo
46 people viewed this question
Top Hotpoint Refrigerators Experts
John Tripp
John Tripp
Sal DeAngelo
Dan Webster
Dan Webster
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
