Question about toyotanation.com
2007 Toyota Camry XLE V6, car shaking at 40 to 45 and 60 to 65 Mi per hr?
I think it is the drive shaft, had problems with steering, felt very stiff, then a mechanic said, the tab under the steering wheel had never been set, so he glued it down. Car was fine for a while, then shaking started, only when you step on gas, so I think it is the drive shaft.
Changing transmission in 1994 toyota camry xle
Well with a V6 it is most likely an auto? See here
http://www.turboninjas.com/camry/ax2.pdf
If a manual after all see here
http://www.turboninjas.com/camry/mx.pdf
May 07, 2014 | 1994 Toyota Camry
I have a 2007 toyota camry altese with 244,000km, it rides nice but the steering wheel is centred to be straight ahead and it feels like you have to overcome a spring or force to turn the wheel, if you...
I would start by having the drive belt checked for wear then getting a wheel alignment done. These camrys do have quite a stiff feeling in the steering, though if it feels quite tight I would have it checked out to see if there is a problem in the rack.
Mar 24, 2011 | 2007 Toyota Camry
'94 V6 XLE - Started slipping in reverse. Drained fluid and refilled, which which seemed to solve for a while, but now (1000 mi) is slipping badly again. Cold fluid level is good, but looks dark. Tranny...
Yea, was thinking same thoughts, you should've changed filter when fluid replaced. I would have it powered flushed and fluid & new filter. Toyota trans are pretty tough and this SHOULD cure the problem.
Mar 05, 2011 | 1994 Toyota Camry
My 1993 Camry steering wheel wobbles when I drive. Gets better as I go faster.
sounds like deformed tyres to me ,jack it up and spin the wheels then check them
Nov 05, 2010 | 1993 Toyota Camry V6
Downshift problem in 2005 Camry XLE V6
Check your motor and transmission mounts.
Mar 05, 2010 | 1999 Toyota Camry Solara
94 Camry V6 XLE; 278kmiles; Reverse only; Sudden poblem
most likly the trans is just plain worn out you could have it rebuilt or replace it with a used one
Jun 03, 2009 | 1994 Toyota Camry
Toyota Camry 1993 vibration during driving position
So you're saying it starts to shake as soon as you put it in gear? If so, you probably have a dead spark plug or plug wire, or disconnected plug wire. It could be something more serious. Head gasket, cam shaft, timing chain. Try the plugs and wires first, and go from there.
Apr 28, 2009 | 1993 Toyota Camry V6
toyotanation.com Logo
13 people viewed this question
Top toyotanation.com Computers & Internet Experts
David Payne
David Payne
Are you a toyotanation.com Computer and Internet Expert? Answer questions, earn points and help others
