Question about Bionaire Ionizer&Indoor Air Cleaner Environmental Purifier LP-1500 Air Purifier
Fan won't start after reset.
Bionaire 1415CN fan motor won't start after re-set. Held power button and the red filter alert light went out. Ionizer is working and green power light is on again. Just fan won't kick in.
maklean
  • 1665 Answers
SOURCE: Bionaire BAP1300 -- Working fine for 2 Days then, Red Light
It may be its power supply fault
Posted on Jun 09, 2008
  • 114 Answers
SOURCE: Fan does not work..any suggestion how to fix this
after cleaning the filters or changing them it does take a minute for it kick on... Now if it hasn't kicked on yet, you might need to reset it. there should be a reset button on the top, if not what you need to do is shut it off and then unplug for about 5 minutes. somtimes the fan might be dirty or clogged so i would check that as well and make sure nothing is interferring with it moving. if that doesn't work, cause i have used this product before. what you need to do is call the manufacturer let them know your warranty. as long as your under the warranty they should be able to replace the unit for you. they will need the date code/ or the reciept to verify the warranty. If you have the reciept they will ask you to fax it in because it is quicker. once they have that, they will give you a call back to discuss other options if you are still under warranty.
Posted on Aug 19, 2009
  • 114 Answers
SOURCE: Will not start up??
there is only one other thing that i can think of that might work ifyou haven't done that yet. right above the timer button there is a small pin hole. that is your reset button. you need like a safety pin or something really small to go in that hole. hold it for about 3 seconds. take the pin out and the system should reset back to normal. sometimes when you clean the filters that happens. not every time but sometimes. Now if that doesn't work. i would call the manufacturer again so see if they have any other solutions or if they can send you one more. I do apologize for the inconvenience. I will keep looking for you to see if there is anything else that i can suggest but try that first.
  • 114 Answers
SOURCE: Reset Filter Indicators on BAP 725
there should be a small pin hole somewhere on the top of the unit. Stick a pin in there hold for about 3 seconds and it should reset.
  • 114 Answers
SOURCE: red light won't stay off
I do apologize for the inconvenience, the best way that i can tell you to fix the light is that there is a tiny pin hole on top of the unit. that's a reset button. you need a small needle or something that will fit in there. hold it down for about 3 seconds. your unit should reset. the light sometimes comes on with new filters cause it hasn't recognized that they are new yet. if that reset doens't work please let me know
Are Bionaire F150/150S/150W available?
Refer your inquiry directly to Bionaire.
Jul 21, 2014 | Bionaire Air Purifiers
Try to do a hard reset by unplugging the device from the power outlet and wait for sometime to reconnect.
Jun 09, 2008 | Bionaire BAP1300 Air Purifier
May 15, 2009 | Bionaire PERMAtech BAP1500-U Air Purifier
Fan motor is dead I think...is it okay to run ionizer still??
no , it is not advisable to run the machine while there is an exsisting problem , it would be best not to run it untill the motor has been replaced
electech
Nov 07, 2008 | Ecoquest Flair Air Purifier
Will not start up??
Aug 26, 2008 | Bionaire BAP1500-U Air Purifier
Lost amnual
the lights are the ionizer light, the filter indicator light which is the light that will come on when the filters need to be changed, ionizer control button, the speed control and the power light.
Dec 04, 2007 | Bionaire BAP825-U Air Purifier
Will not start up??
Same problem here. Opened it but everythng seemed intact. Red light flashes momentarily during initial plug in. Has power, oscillates but no fan rotation.
Nov 05, 2007 | Bionaire BAP1500-U Air Purifier
Replacement Filter
i do apologize for the inconvenience that your having with the product. The only other thing that i can suggest cause you already did the majority of the troubleshooting, is that there should be a small pin hole on the top of the unit. that's the reset. stick a small pin in there and hold for about 3 seconds and then the unit should be reset. if that doesn't work there is something internal that is going on. recheck the manual for the trouble shooting options as well.
Oct 14, 2007 | Bionaire BAP815B-U Air Purifier
Red light won't stay off
Aug 17, 2007 | Bionaire BAP825-U Air Purifier
Red Light indicator on
I have a Bionaire tower air filter model BAP1700 that I bought from Costco. The filter check LED came on recently after 5 months of use. After cleaning the Permatech filters, I tried every remedy on this website including following the instructions that say push power button for 2 secs. Nothing worked. Then I noticed a tiny hole on the control panel in front of clean filter LED; I pushed a paper clip pin into that hole, felt a click, held it down and 2 secs later, LED went out. Success!
Apr 06, 2007 | Bionaire BAP1500-U Air Purifier
Air Purifiers Logo
27 people viewed this question
Top Bionaire Air Purifiers Experts
Bill Long
Jay Finke
Jay Finke
Tim Whalen
Are you a Bionaire Air Purifier Expert? Answer questions, earn points and help others
