Question about KitchenAid KGST307 Gas Kitchen Range
Too hot error - KitchenAid KGST307 Gas Kitchen Range
    Top Expert:
  • KitchenAid Master
  • 9,472 Answers
Replace the temp sensor. Here is the part to order.
Keep me posted.
Posted on Dec 28, 2013
  • william
    william Jan 04, 2014
    Richard, Thanks your solution worked great. I just installed the new temp sensor and oven has returned to normal. I had to unlock the door manually when I was replacing the sensor but it was an easy fix.
  • Richard Roth
    Richard Roth Jan 06, 2014
    I am glad I was able to help you!
Lg model lds5540 smells, will not clean properly and doesn't seem to have enough water during cycle. also occasionally shows the fe error code. ??? any thoughts?
WATER OVER FLOW ERROR // Water continuing to enter machine
The manufacturer has assigned this error or fault code to indicate that the washer is overfilling due to a defective water inlet valve. The valve is not repairable and will need to be replaced.You can check it with a multimeter to confirm, it should show continuity on both hot and cold pins. try exchanging the how and cold water hoses, cold on hot and hot on cold, see what happens. have u tried running only cold water or hot water wash? as for the smell could be a build up of detergent or frabic softner, try washer running machine with hot water and vinigar to clean out also check inlet valve for dirt build up
Dec 08, 2016 | LG Washing Machines
How do I fix a hot point fridge freezer FFUXL 4DK displaying error code 7?
Hotpoint Refrigerator Error Code E7 = Environmental temperature sensor fault
There may be a number of things affecting the temperature in your refrigerator if you see this error code displayed
Jul 22, 2016 | Refrigerators
Please error code H4 shows on my mx 181 sharp copier please what is the remedy?
Hold down the button to get the 2nd part of the error code. H4 type errors have to do with the fuser, that's the hot rollers that melt and press the toner into the paper. Depending on the 2nd part of the code, it could be too hot or not hot enough.
Aug 10, 2013 | Office Equipment & Supplies
The meaning of error code 24?
Hi, F24 error code a water temperature sensor error or enought hot water to the washer.
check to see you have both valves are turned on. Also, the water inlet valve on the washer has a screen and it is known to get clogged and restrict water flow. Turn off the hot water valve. Pull the hot water hose off where it attaches to the back of the washer.
Even if you are getting good hot water flow, inadequate water temperature can cause an F24 error code. Check the temperature setting on your hot water heater. It should be set at 120 F. You should reach this hot water temperature at your washer within about 1 minute.
If you are getting a good hot water flow, you may one of the following failures:
1 loose or dirty connection at the temperature sensor or control board.
2 The temperature sensor could be out of range. Bad or shorted sensor
3 Control board failure.
The temperature sensor should have a resistance reading of 6.6k ohms at 104 degrees F and should drop in Ohms as temperature rises,
The temperature sensor is located at the back lower section of the tub with 2 small black wires. It would require a ohm meter to measure the resistance of the sensor. .
Sep 13, 2010 | Kenmore HE2 Plus Front Load Washer
What wud be the reason behind fuser error in a printer?
A fuser is basically a really hot light bulb or heater element, turned on and off by the AC power module.
If the bulb/element blew, or the AC power module is stuck on or off, the temperature won't get hot enough, or will get too hot.
Either too hot or not hot enough will cause a fuser error.
Sep 08, 2010 | HP Office Equipment & Supplies
Error EA
Welcome to Fixya
you have a Bosch tankless water heater your heater is not pumping out hot water?
Please send model # Thankyou
Dec 15, 2008 | Bosch & Tankless LP Hot Water Heater
Beep with a display saying EFO
Dear novscorp,
According to the error code chart (a loose insert included with the operating instructions) EF0 means two things: Error 1. Over sudsing  or  Error 2. Hot water does not enter.
For over sudsing, it lists the possible causes as: a high efficiency detergent was not used (the detergent brand will have "he" on it for high efficiency) or too much detergent was added.  The solution lists: Use only a high efficiency detergent.  Follow manufacturer's recommendation for dosage.  Amount may need to be adjusted for water temperature, water hardness, load size and soil level.
For the 2nd error, hot water does not enter, it lists the possible causes as hot water hose is connected to the wrong faucet or hot water faucet is not turned on.  The solution lists: Connect hot water hose to hot water faucet and hot inlet on washer.  Be sure hot water facet is fully opened.
On a personal note, I received the same error when I mixed my detergent directly in with my color safe bleach.  It just caused a lot of suds in the machine.  One rinse cycle solved it.
Hope this helps, Ellenk4
Aug 18, 2008 | Kenmore Energy Star 44092 Front Load...
Error code F24
I see the same problem and now that I know it's a water temp sensor, I really don't have a problem. Living in Houston it get's so hot the cold water is hot coming through the pipes. I didn't have this error 24 until summer...
Nov 18, 2007 | Kenmore 46462 Front Load Washer
KitchenAid KGST307 Gas Kitchen Range Logo
73 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
