Question about Midland 1001Z 40-Channels Base CB Radio
Does it have a PLL02A in it
I have a Midland 1001z just wondering if it had Pll02A chip
    Genius:
  • Midland Master
  • 1,795 Answers
No its solid state
Posted on Aug 23, 2014
One Wire
  • 126 Answers
SOURCE: How far can that midland
Running most any regular cb, including this one barefoot (with no kicker), having a good antenna, set up with a good ground plane or a no-goundplane antenna, good coax; basically everything in good working order, you can usually bank on about 4 to 5 miles crisp and clear, and at least 6 to 10 miles fairly clear. Of course the further out you get it will start to fade out.
Some radios do better than others, but those are the general numbers I have seen in my years of experience.
Dean Pitts
Rollin CBs
Mt. Vernon, TX
Posted on May 22, 2008
  • 39 Answers
SOURCE: midland squealing when talking
soundwas keying up at the same time.s like it could be one of two problems. a loose wire in the mic or some one near you keyed up the same time as you. if the wire in the mic is loose sodder it. If some one keyed up near you you might have blown the reciever chip.
Posted on Oct 06, 2008
vortash
  • 431 Answers
SOURCE: Midland 1001Z Channels
Hi yes it is possible as is anything if your willing to pay for the conversion , it would require new chrystals and resetting of the If system but is possible . However porobably not economical Midland did do The 100 model in an Fm modulation format and you will probably find still available on Ebay or Amazon if not that paticular one a good version at any rate ..I beleive they did actually do an Am Fm model also ...Regards Vortash
Posted on May 11, 2009
SOURCE: receivers complain about squeeling noise from my
I had the same (squealing) problem on transmit with the Midland 1001Z when I used it indoors as a base unit. The problem was my power supply: it broke into oscillation when drawing more than 150 mA at 13.8V. The 1001Z draws about 150 mA on Receive, and much more (but only about 900 mA) on Transmit. If using the 1001Z as a base unit, I suggest you power it with a fully-charged car battery indoors, or test your power supply to check if it can't supply the required 1 Amp, approx., on Transmit. It's a GREAT radio, just give it a good power supply. My power supply was defective out of the box, but now I have a good one and get great reports on signal strength and audio quality. Remarkable, for the low price and 3 year warranty. Good luck!
--Sky Junkie / Tucson, AZ / USA
Posted on Oct 12, 2009
  • 1274 Answers
SOURCE: How do you peak and tune a Midland 1001z.
Try Cbtricks.com.................hope this helps you some..........
Posted on Mar 02, 2010
How do you turn up the power on a midland 1001z
You can't "turn it up". You may be able to carefully compress or spread the coil windings near the Final Output Transistor (Q 14 a 2SC 2078) to get a bit more out of it but it isn't a real "Big Time" CB like the Cobra 29's. Sorry.
Feb 13, 2014 | Midland 1001Z 40-Channels Base CB Radio
Garbled modulation midland 1001z. I would like to be able to adjust.
the ANCE is DM1. you can adjust the.modulation by turning it. you can also just back the Mic gain down until the aaudio is cleaner.
Jul 19, 2011 | Midland 1001Z 40-Channels Base CB Radio
How to connect the 4 pins miccrofono that color on each pin? Please help urgent MIDLAND 1001Z
Try this;
Pins Color
1 White
2 Shield
3 Red
4 Black
This should get you going. If this does not fix your problem then repost your problem and I will help you out.
Jul 14, 2011 | Midland 1001Z 40-Channels Base CB Radio
Feb 18, 2010 | Midland 1001Z 40-Channels Base CB Radio
Receivers complain about squeeling noise from my midland 1001z when I transmit. Is this an RF Gain setting problem?
Sep 27, 2009 | Midland 1001Z 40-Channels Base CB Radio
May 04, 2009 | Midland 1001Z 40-Channels Base CB Radio
Midland squealing when talking
Sep 15, 2008 | Midland 1001Z 40-Channels Base CB Radio
Midland 1001Z 40-Channels Base CB Radio Logo
69 people viewed this question
Top Midland Radio Communications Experts
Steve
eradiostore
eradiostore
Are you a Midland Radio Communication Expert? Answer questions, earn points and help others
