Question about Janome Hello Kitty 11706 Mechanical Sewing Machine
Handwheel stuck The hand wheel won't turn and the needle won't move. I've tried to clean everything but can't seem to figure out why it's stuck.
    New Friend:
  • 4 Answers
Most likely the bobbin thread is wound around the components.
remove the bobbin and check for a mass of thread cut it all away and remove every last bit then it should work
Posted on Dec 28, 2013
bargainbox
  • 1388 Answers
SOURCE: serger
With the door open, the needle plate removed and no threads in the machine, slowly turn by hand one or two revolutions & take a close look at the motion of the loopers and the needle/s, are they colliding, or is the needle becoming jammed by the black guard surrounding the lower looper ?
Ensure there are no threads or fabric debris jammed anywhere.
If it is "new" and under warantee, it would be worth a call to the dealer asking for their advice and see if they will take a look at it for you........arrange to meet with the technician if possible.
Posted on May 30, 2008
pauman
  • 248 Answers
SOURCE: Handwheel freewheeling
it could be the gears of your handwheel try spraying it with wd-40.
is it making any noise?
Posted on Jun 25, 2008
bargainbox
  • 1388 Answers
SOURCE: janome 5700 handwheel stuck/inside pulley stuck
The error message relates to the motor sensing that it is working unusually hard.........the extra strain will have a physical cause, generally in the hook and bobbin region.......something blocking or slowing things down, so.......
Remove needleplate and bobbin case.
You will probably find an accumulation of lint in and around this area, also possibly in the feeddog channels.
Use a small brush and vacuum with crevice tool to remove the lint and wipe the hookrace with a tissue moistened with methylated (denatured) spirit to remove any dirt deposits.
Also check that the bobbin case is not damaged on the top surface by needle strikes or on the underside rim by the hook gouging as it spins.
If damage is present but mild, you can use very fine emery paper to smooth surface, if more severe, replace the bobbin case. Don't forget to change needles regularly too.
Best of ......
 www.bargainbox.com.au
Posted on Nov 21, 2008
louislevel_2
  • 374 Answers
SOURCE: needle wont go up and down.
well,it seem that your upper camshaft was stuck due to several factor on mechanical linkages and maybe on gears.You have to isolate the checking since you have clean lower bobbins free from dirt and thread/fabrics chips.If there an opening on top of machine open it to check some mechanical destorsion or breakage.Check some broken gears inside.If nothing try to open also at the bottom of machine cover and there are also belt and gears connected to the motors and bobbins shuttle holder if so oil all shafting oil port,oil port bushing specially on bushing near hand wheel there is port for oil,
check also motor assembly of machine,you can disconnect belt from motor release the bolt holding motor adjust to lower tension belt and release the belt.Take some tools such as monkey pliers or small pipe wrench that can hold hand wheel just crack in order to move suddenly after oiling for several hours sometime bushing and shafting rushes emerged or if you have anti rush spray put in on.After cracking and you can move a little crack only by your hand several time lleft and right until all linkages free from rush.If you can move all parts and hand wheel rotate freely.Check also motor by rotating the small pulley conncted to motor if free to move.if ok put back and reassembly all parts disconnected.try to move again by hand if free to move after all asssembly.Run machine using foot pedal.
Posted on Mar 15, 2009
SOURCE: Janome 9000 seems to be jammed.
I had the same problem with my 9000. After my third visit to the repair shop they finally told me to always check my thread uptake lever. I have had no problems since.
Posted on Jan 10, 2010
Hand wheel moving needle moving but will not sew cannot release hand wheel to turn in opposite direction
Do NOT turn the handwheel the reverse direction.
If your machine is mechanical, most likely it hasn't been cleaned and oiled for a long time. Old sewing machine dries out and turns to glue which then prevents parts from moving like they should.
This web site may be helpful:
How to Oil Vintage Sewing Machine
Tri-Flow Synthetic Lube is very good because it has little teflon beads. It also does not dry out like sewing machine oil will. Then applying heated air from a handheld hairdryer will help loosen it.
Do NOT oil plastic/nylon, cams, or belts.
Aug 20, 2016 | Sewing Machines
Why does my hand wheel feel springy? why won't it turn and move the needle?
Is the bobbin winding mechanism activated? That will usually prevent the handwheel from turning and moving the needle. Otherwise, it could be broken...
Feb 23, 2016 | Bernina BERNETTE 65 Mechanical Sewing...
The needle acts like it is hitting something but there are no threads.
Test: Put needle on straight stitch. Put needle all the way to the left and turn the hand wheel forward.
Now move the needle to the right and do this again.
Did the hand wheel move all the way for one of the two sides the needle was placed?
If your answer is yes then you need to get the machine timed.
Also, make sure that your brake used for winding the bobbins is tight. If it is tight then loosen the small screw (usually on front of hand wheel). Move the brake forward a little more to tighten and then tighten the small screw again. Look at my picture.
Jun 26, 2015 | Sewing Machines
Hand wheel wont turn to raise needle.
If handwheel does not turn, you may have thread jammed in the hook. First try to force the handwheel BACKWARDS to try to force thread back out of hook. If handwheel turns, look around hook area and you will probably see a small piece of thread. Remove it with tweezers. To help eliminate this from happening, be sure to hold the needle thread when starting off.
Jan 18, 2015 | Brother Computerized Sewing/Quilting...
Singer 974 MY NEEDLE WOULDN'T MOVE WHEN I TURN THE HAND WHEEL AND MY HAND WHEEL WOOBLES. HOW CAN I FIX IT?
slacken the small stop screw and remove the centre free motion knob. the balance wheel should now be free to turn independent of the shaft. you will have exposed the friction washer. clean all surfaces and relocate the washer with the two locating lugs facing outwards into the two slots in the shaft and refit the knob and screw. if the screw bottoms on the friction washer remove knob and turn the friction through 180 degrees and try it again
Feb 21, 2014 | Sewing Machines
Cannot turn hand wheel or sew.
Have you checked the bobbin compartment to make sure there isn't a thread-jam there? It can get so tightly snarled that even the handwheel won't turn.
Aug 08, 2017 | Sewing Machines
Sewing needle won't move
it could be a part is damaged or broken or a timing problem,,it
would be a good idea to have the machine checked.
Dec 09, 2012 | Sewing Machines
HAND CRANK WON'T MOVE NEEDLE SEEMS TO HAVE LOST CONTACT WITH GEAR
adjustment info here. http://www.parts.singerco.com/IPinstManuals/15.pdf
And here is a manual for you. http://www.singerco.com/uploads/download/34_sm15.pdf
Those stop motion pieces must be put together correctly. Also make sure your needle is fully seated into the needle bar. Also look for any binding of metal parts. I had a 128 that came to me with a bent take up lever that would catch and make hand cranking difficult.
Good luck.. you'll love your old singer when you get it going well. Take your time and try not to get to frustrated.
One more thing... this blog is awesome if you are working on old singers.
http://vssmb.blogspot.com/search/label/fix%20%27em
Jul 27, 2012 | Singer Sewing Machines
Hand wheel will not turn
A FRIEND GAVE ME A SUPERLOCK 2000 WITH THE SAME PROBLEM. THE HANDWHEEL WAS HARD TO TURN AND MACHINE WONT RUN WHEN PLUGGED IN. I OPENED THE SIDE COVER WHERE HANDWHEEL IS LOCATED. FOUND THE BELT WAS DRIVEN OFF THE MOTOR. PUT ON THE BELT ON THE MOTOR, OILED THE MOVING PARTS.
WOKRING GREAT NOW.
Apr 30, 2009 | White Sewing Superlock 2000 ATS Mechanical...
Hand wheel is stuck
hi there,
well,stuck up hand wheel, is due to mechanical obstruction inside machine,bushing on shafting need to oil,and on handwheel bushing near clutch there is oil port there. since hand wheel are connected to cam shaft with set of gears and pulley is coupled to motor pulley,and other linkage under bobbins,shuttle race etc,broken gears are most common causes of stuck up handwheel,we can consider also the brush carbon,when worn out and damage the rotor commutator brush.if you can open the cover of motor below side of handwheel,you can see the pulley and motor assembly.also on top of machine there an opening to see the top gear assembly,this should be done by service technician.try to bring to nearest service center if still under warranty claim this for lesser maintenance cost.have a nice day,don't forget to rate me.thank's.
Apr 20, 2009 | Sewing Machines
Janome Hello Kitty 11706 Mechanical Sewing Machine Logo
481 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
