Question about Clarion GPS
INSTALL NAVIGON ON MIOPOCKET - Clarion GPS
How can y dow the sofware and instal on may navigon cg 2026
See the website, you can download a fresh install of your maps.
Probably you need to register first.
NAVIGON MN8
May 03, 2014 | GPS
Fs201
I would suggest going here and reading about your unit.
http://reviews.cnet.com/car-gps-navigation/navigon-2100/4505-3430_7-32744602.html#reviewPage1
Go through the 2 pages.
Good luck
Apr 10, 2012 | Navigon 2100 Portable GPS Receiver
Update
According to the sylvania website, There have been no updates released for this device.
If this device takes SD cards, you may want to look into software called MIOpocket
http://netfresco.com/MioPocket/
May 16, 2011 | Sylvania SGPD430 GPS Receiver
Accidentally delete the CNAV file on my NS-NAV01. Where can I find this file to reload it on my GPS?
Unfortunately the only real solution is to return this product for another. Insignia does not provide download support in the form of firmware or otherwise for these devices.
There is, however, another solution: These devices run WinCE, and can easily be brought back to a better life with free software like pocketnav or miopocket, The latter being my personal preference.
If you do decide to go this route, the information/download for miopocket is as follows: http://netfresco.com/MioPocket/default.aspx
May 04, 2011 | Insignia NS-CNV10 Car GPS Receiver
Motonav TN30 frozen after install Miopocket 3.0
Hi Mario, i beleive here is the link that you have been looking for to update your firmware/sofware for your Montonav TN30. Please click here.
Best of luck
Apr 28, 2010 | Motorola Mobility Motonav TN30 Car GPS...
Want to install xcsoar on a navigon 4310 pna. put the xcsoar program on a micro sd card, can't get it to work.
Hi Mart136,
Were you able to get XCSoar to work on your Navigon 4310? I have the same problem with XCSoar and my Navigon 2100 Max. I did exactly as prescribed for installation on the XCSoar site but my 2100 Max keeps asking for the Navigon SD card .. it doesn't want to recognize a standard SD card.
Does anybody have any suggestions? Thx Much!
Oct 04, 2009 | Navigon 2100 Max Portable GPS System
Vista operating system computer doesn't have a driver to install the navigon gps system
Your navigon gps system should of have came with a cd with the drivers on it. If you didnt recieve it visit the manufactures website. Check the Drivers and Downloads Section.
Aug 23, 2009 | Navigon 2000S GPS Receiver
Navigon 2000s I cannot reset the Navigon 2000s
Well after many emails to Navigon I got the fix for my 2000s What you have to do is download the 1.2 version software for the 5100 install it on a 2GB micro SD Card. Put it in the slot and turn it on. You will have to regester as if you have a 5100 but it will work. The reason you have to use a 2GB card is the maps are to large to go on the internal memory.
Jun 09, 2009 | Navigon 2000S GPS Receiver
I HAVE A MESSAGE ON MY 2100 GPS,SAYS MN6 .EXE HAS PERFORMED AN IL
Sounds as if the system software that runs the GPS has been corrupted. Your device should have come with a CD that has software that can be reloaded or a utility that can be installed on the PC that connects to the navigon website to download and install the software for you.
Might want to start with that.
Hope this helps
TankMurdock
Apr 24, 2009 | Navigon 2100 Max Portable GPS System
Installing mio pocket on Sanyo 4370
Use SDFree method and assume you have extracted MioPocket on your PC's local drive
  1. Hook up your GPS to a PC via USB cable and note a drive letter
  2. Copy MioAutoRun, SDFree, and Media folders to the root of GPS FlashDrive (drive letter) above
  3. Open MobileNavigtor and rename MobileNavigator.exe to MobileNavigator_orig.exe
  4. Rename all 3 files begin with Miomap in SDFree folder to MobileNavigator (keep the extension intact)
  5. Copy all 3 files and MortScript.exe to MobileNavigator folder
  6. Unplug the GPS and launch MioPocket via the Navigation button. MobileNavigator on top is Sanyo GPS apps.
HTH.
Feb 18, 2009 | Sanyo EasyStreet NVM-4370 Car GPS Receiver
GPS Logo
85 people viewed this question
Top Clarion GPS Experts
CheckitRight
CheckitRight
perdue40
Are you a Clarion GPS Expert? Answer questions, earn points and help others
