Question about Garden
Troy bilt 27cc weedeater
What is the spark plug gap on a troy built TB 21 EC
    Habit-Forming:
  • 114 Answers
Almost sure it is 0.025.
Posted on Feb 01, 2014
#1 Taper
  • 1040 Answers
SOURCE: Troy Bilt TB 465SS Pony 4 cycle weed trimmer won't start
Sounds like you need to take the carb. apart and clean it. I like to use a Den Tek Brush, (used for cleaning teeth), to clean the small ports in carb. they work great for this job. Make sure to either clean or replace the small screen in thcarb. as well.
Jim
Posted on May 26, 2009
  • 64 Answers
SOURCE: Rough idel and no throttle on a Troy -bilt BT25ET
It sounds like you have done everything but replaced the fuel filter. Which is usually located in the fuel tank. And clean the muffler. You will probably find some oil and carbine build up.
good luck
Posted on Aug 07, 2009
  • 7 Answers
SOURCE: troy-bilt gas edger trencher won't start. Spark
Remove spark plug and pour 5mls or one teaspoon of premixed gas in the engine. Depress trottle to full with choke on "run", pull starter about 10 to 12 times If it starts and run for a while and then shuts off your carb needs servicing. If not remove muffler and look for a spark arrestor screen. This could be plugged up with soot. If it is, replace and this would have been your problem. While the muffler is off slowly pull starter rope and examine the piston if gas and oil oozes backwards as the piston moves to the top then the piston and rings need replacing.
Posted on Nov 10, 2009
  • 512 Answers
SOURCE: Troy built 27cc string trimmer Model TB21 EC. What
4 cycle engines do not run on mixed fuel. Run on straight fuel. They have a spot to put oil in just like a lawn mover, and should be changed regularly. @ stroke engines run on mixed fuel.
Posted on Sep 28, 2010
  • 6468 Answers
SOURCE: cant get the heas off trou-bilt weedeater on a 4 cycle # TB 525-ec
the bolt on the end has left hand threads not right hand the most bolts have
Posted on Apr 08, 2012
How do I start troy bilt edger modle tb32 ec
It gets it spark from the module and they can go out at any time. But first check the coil gap with a business card and adjust it if necessary. When you have spark, then move on to fuel issues.
Oct 06, 2014 | Troy Garden
Troy built 27cc weedeater stops running after it gets hot
Check the coil with a spark checker immediately when this happens. You probably have a week coil.
Aug 18, 2014 | Troy Garden
What is the gap for a champion RDJ7J SPARK PLUG
On that particular sparkplug the gap should be set to 0.025 inch (0.635 mm).
Hope this helps,
Brad
Jul 29, 2014 | Troy-Bilt 27cc 2-Cycle Straight-Shaft Gas...
27cc Troy built spark plug gap
Ezra the easiest way to set the gap is use a Buisness card like the little stiff pieces of card that sales men give you.
Jun 27, 2014 | Garden
Troybuilt tb80ec wont start
If you didn't over winter the engine properly it could be several things. Start with replacing the fuel filter. If it still won't start... time to put in a carburator kit. Next time make sure you run your weed eater dry and spray some wd-40 or the like into the spark plug hole.
Jun 02, 2014 | Troy-Bilt 27cc 2-Cycle Straight-Shaft Gas...
Cant get the heas off trou-bilt weedeater on a 4 cycle # TB 525-ec
Apr 07, 2012 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Troy built 27cc string trimmer Model TB21 EC. What is the gas oil mix ratio?
Sep 27, 2010 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
What is the spark plug gap on a 4.5 HP 21" cut
With out the model # of engine or plug not 100% certian but 99% of those mower engines run a .8 or .9mm plug gap you will be preety safe setting it at that
Regards
Brad
Feb 05, 2010 | Mtd Products Yard Machines 158CC Tiller
Garden Logo
96 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
