Question about Refrigerators
Can I adjust the temperature of the freezer? - Refrigerators
    Top Expert:
  • Refrigerators Master
  • 9,472 Answers
Model number?
Posted on Dec 28, 2013
The freezer is set at -4. How do I adjust it? Everything is freezing too much.
Hi Marisa:
Following is the instruction for adjusting the freeser temperature for your Samsung refrigerator:
You press the freezer temperature button repeatedly till you see your desired temperature. If you want to set it to -2F, stop when the display shows -2F and don't press the freezer button again. After 5 seconds this new temperature will be set.
The instructions from the Samsung manual is shown below:
Controlling the Freezer temperature:
The Freezer temperature can be set between 8°F and -14°F to suit your particular needs. Press the Freezer button repeatedly until the desired temperature is shown in the temperature display. Keep in mind that foods like ice cream may melt at 4°F. The temperature display will move sequentially from -14°F to 8°F. When the display reaches 8°F, it will begin again at -14°F. Five seconds after the new temperature is set, the display will again show the actual current freezer temperature. However, this value will be changed to the new temperature.
Feb 15, 2016 | Samsung RF265AA Bottom Freezer French Door...
Where is the reset button on a hottpoint side by side refrigerator.
Self Diagnostics
To enter Self Diagnostic mode, both temperature control panel displays must be illuminated. A display can be illuminated by pressing an adjacent temperature adjustment button. When both displays are illuminated, set the freezer and refrigerator temperature settings to 5. Simultaneously press and hold all 4 temperature adjustment buttons for approximately 3 seconds. A flashing 0 in the refrigerator and freezer displays will indicate that the refrigerator is in Self Diagnostic mode.
To perform a self diagnostic test, locate the test in Table 2, Diagnostic Tests.
For temperature control panels with single-digit displays, the COLDER temperature adjustment button will increment the numbers up and the WARMER temperature adjustment button will increment the numbers down. Use the freezer temperature adjustment buttons to enter the test code number in the freezer display. Use the refrigerator temperature adjustment buttons to enter the test code number in the refrigerator display. When a test code has been entered, the displays will flash to confirm the test. Press the HOLD button for 3 seconds to begin the test.
For temperature control panels with 3-digit displays, the COLDER temperature adjustment button will increment the numbers down and the WARMER temperature adjustment button will increment the numbers up. Use the freezer temperature adjustment buttons to enter the test code number in the freezer display. Use the refrigerator temperature adjustment buttons to enter the test code number in the refrigerator display. When a test code has been entered, the displays will flash to confirm the test code. Press any button other than a temperature adjust button to begin the test.
When testing has been completed, do one of the following things:
• Enter code 1 5 to completely reset the system.
• Enter code 1 6 to exit diagnostic mode. The temperature control panel is reset automatically.
• Unplug the refrigerator for at least 10 seconds. Test mode will terminate when the refrigerator is plugged back in.
Test mode will terminate automatically after 15 minutes of inactivity.
Read more: http://appliancejunk.com/forums/index.php?topic=10408.0#ixzz3VIqUINVz
Feb 27, 2015 | Hotpoint HSS25GFT 25.0 Cu. Ft....
How do I adjust freezer temperature on Electrolux refrigerator?
Hello friend, thanks for your inquiry!
I see that you would like to know how to adjust the temperature within your Electrolux refrigerator, EI23CS55GS1. To adjust the temperature you would use the control panel on the front of the freezer door. There should be a "-"or "+" near the freezer temperature control and that is how you would adjust the temperature within your refrigerator. Be sure to check and make sure that the control lock is not on or you will not be able to adjust the temperature. Any adjustments made within the refrigerator need at least 24 hours to stabilize. I hope this is has been helpful. -Matt
Oct 18, 2014 | Electrolux Refrigerators
Cant find temperature control knob
Good Afternoon Friend,
I understand that you are looking for the temperature control knob on your Frigidaire freezer, model# FFU2064DW. The temperature control is located inside your freezer on upright models, and on the left outside wall on chest models. The temperature is factory preset to provide satisfactory food storage temperatures. However, the temperature control is adjustable to provide a range of temperatures for your personal satisfaction. However, the temperature control is adjustable to provide a range of temperatures for your personal satisfaction. Hope this is helpful.
-Best Regards-
WP
May 09, 2014 | Frigidaire 20.3 cu. ft. / 575 liter...
Temperature
Hello R, thank you for your question! Generally speaking it is recommended that the temperature knob is set in the middle for both the refrigerator and freezer compartment for top mount refrigerators. The temperature can be adjusted by moving the knob in small increments, allowing the temperature to stabilize. If you desire a colder temperature, then turn the knob towards COLDER, or for warmer temperature, turn the knob towards COLD. Turning the refrigerator control will change temperatures in both compartments. For example, if the refrigerator control is turned to a colder setting, the freezer control may have to be adjusted to a warmer setting. Turning the freezer control will only change the freezer temperature. Hope this proves to be helpful!
Jul 22, 2013 | Refrigerators
HOW DO I FORCE A HOTPOINT SIDE BY SIDE REFRIGERATOR (HSS25GFTA) WITH AN ADAPTIVE DEFROST TIMER INTO DEFROST MODE?
Start a diagnotsics mode and enter test code 1 - 4 of the diagnostics to start the defrost mode
Self Diagnostics
(or in your case.... after the deforst cycle completes and possibly + 15 minutes)
Thanks for choosing FixYa,
Kelly
Aug 23, 2011 | Refrigerators
I need to learn how to control the tempature setting
The temperature controls are located at the top front of the refrigerator or freezer compartments.
The recommended setting should be correct for normal household refrigerator use. The controls are correctly set when milk or juice is as cold as you like and when ice cream is firm.
Wait 24 hours for your refrigerator to completely cool before adding food. If you add food before the refrigerator has completely cooled, your food may spoil.
NOTE: Adjusting the refrigerator and freezer temperature controls to a colder-than-recommended setting will not cool the compartments any faster.
If the temperature is too warm or too cold in the refrigerator or freezer, first check the air vents to be sure they are not blocked before adjusting the controls.
To turn Off/On:
Style 1 Press the freezer down arrow touch pad until a dash (-) appears in both the refrigerator and freezer displays. Neither compartment will cool.
Style 2 Turn the freezer control to the word Off. Neither compartment will cool when the freezer is set to Off.
Energy Saver option (on some models)
The Energy Saver option turns off the heater which helps to reduce moisture on the door hinge seal. The refrigerator uses more energy when Energy Saver is off.
Press the control to On to save energy when the environment is less humid.
Press the control to Off when the environment is warm and more humid, or if you notice moisture on the door hinge seal.
Adjusting controls
If you need to adjust the temperature in either the refrigerator or freezer compartment.
NOTES:
For Style 1 control, press the up and down arrow touch pads; for Style 2 controls, turn the dial to adjust the temperature.
Except when starting the refrigerator, do not adjust either control more than one setting at a time.
Wait 24 hours between adjustments for the temperature to stabilize.
Hope this guideline will helpout.....
Aug 10, 2010 | Traulsen Reach in Freezer - G22010
GE GSS25LGMFWW side by side. Freezer will run till iced up then defrost everything in the freezer compartment. Why is it doing this?
hi, have you try adjusting the temperature:
To change the temperature, press and release the
WARMER or COLDER pad. The SET light will come
on and the display will show the set temperature.
To change the temperature, tap either the
WARMER or COLDER pad until the desired
temperature is displayed. The
freezer temperatures can be adjusted between
–6°F and +6°F.
Jun 14, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
My 7 year old GE Profile Side by Side will not get
Self Diagnostics
• Enter code 1 6 to exit diagnostic mode. GSS manual
May 15, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
We just purchased a ge profile refrigerator today, and cannot get it off of demo mode
You have to go into the Diagnostic mode to see if you can reset this issue or if the main board in back is bad. Here's how to do it:
First, run the control and thermistor test:
Control and Sensor System Self-Test (0 7)
This test checks all five thermistors located throughout the unit. Once the test is initiated, the test code (0 7) will stop flashing and the thermistor test results will appear on the freezer display in the test order listed below. The thermistor test sequence number will not be shown on the display. If the unit is not equipped with the Quick Chill option, the third thermistor (quick chill) will display a 0 and 3 audible beeps will sound at the temperature control panel. This is not a failure if the unit is not equipped with the Quick Chill option.
Thermistor test results:
• P = Pass
• 0 = Failed
• S = Short to 5 VDC
• B = Bad amplifier
When testing has been completed, do the following :
• Enter code 1 5 to completely reset the system. Then press the Hold button (or any other button than a temperature button) to accept the code.
When you're done, unplug the refrigerator for 10 seconds and plug it in....if it does not run, the board is bad.
Jun 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
