Question about Electrolux Heating & Cooling
Bad smell coming from a/c
Bad smell from a/c
  • 148 Answers
I am asuming it is a musty smell must clean unit and coil the drain pan is probably full of dried up algae and mold spray windex into the coil fins
Posted on May 18, 2009
Bad smell coming from ac on 2005 grand Cherokee
Why Does My Air Conditioner Smell Bad? - Hydes AC
www.hydesac.com/air-conditioner-smell-bad/
Apr 15, 2015 - Does your house seem to develop a strange smell every time that yourair conditioner ... Possible reasons why your air conditioner smells bad.
Sep 30, 2015 | AC Cars & Trucks
Why is a very strong gas smell coming from my tailpipe?
White smoke is water vapor and in this cold climate it is normal. Strong gas smell is not normal although you may smell some while engine is warming up. Bad cat converter can produce smells, but usually more like rotten eggs. If engine is running rough and seems rich, check coolant temp sensor. Bad converter can cause stalling too. Otherwise, idle speed is controlled by idle air contol motor which can get dirty and stick. Any codes set?
Feb 18, 2015 | Cars & Trucks
I have a strange situation going on in my house. When I turn on my airco frequently I get a nasty smell from the airco vents. Sometimes we have it running all day and it's fine (no smell at all) then at...
You should look in the air handler( Where the indoor blower is located) or in the plenum (where the duct system originate at the air handler) for any dead and rotting rats. Residential central air systems are sealed (uses circulated air only) and do not use outdoor air.
Aug 27, 2013 | Heating & Cooling
Odd odor coming out of dishwasher upon opening it. Smells like rotten milk. What is the best cleaning solution?
After a dishwasher is installed the hose rarely comes to mind - unless a problem occurs and a repair person comes out to inspect the job. If the hose was installed improperly, or if it is lying in a position that does not let it drain, stagnant water will create a bad smell. Examine the hose that is probably inside the kitchen cabinet beneath the sink. If the hose is lying in the bottom of the cabinet, it is probably full of water. A film begins to form inside the hose and the odor begins to grow. The next time the dishwasher is used, the stagnant water ends up on dishes, and in the meantime it can cause a bad smell inside of the dishwasher. Hang the hose at an angle on supports in the back of the cabinet. This alone might get rid of the bad smell inside the dishwasher.
Check the Seal
A dirty dishwasher seal can be a source of a bad smell. Before deciding the dishwasher needs to be replaced, check the seal - especially at the bottom. Old food and grime builds up in these areas and can cause a particularly bad smell. Clean it with a solution of diluted bleach and hot soapy water. One teaspoon of bleach for each quart of water is sufficient to kill germs and the odors they create.
NB I decided to add a little bit of vinegar to the machine after I unloaded it. Sure it would smell pretty strong for a while but then the smell would dissipate. Voila! For two weeks now my dishes have not smelled whatsoever.
Jun 23, 2011 | Maytag MDB6709AW Builtin Dishwasher
I smell bad odar when I get in my car coming from
If you had a bad smell coming from the auto box then you want to get it drained and refilled with DEXTRON 2,,as the smell you got would have been the forward band slipping and burning linings as the pump could have been low in oil pressure..
so dont say bugger it she be ok ,as the price of another G/Box will be a lot and the labour even more so dont hang around belive me.. Ron
Oct 28, 2009 | 2004 Pontiac Grand Am
Bad smell from the back
Any drippings in back may cause a funny smell with water settling behind the refrigerator. Pull your refrigerator out from the wall and trace the smell. Maybe your waterline needs to be cleaned.
Jul 03, 2009 | Whirlpool Refrigerators
Bad smell coming from fridge
Unplug fridge. Remove the panel on the back of the fridge look for dead rodents or fungal growth in the drain pan. consult your local appliance parts distributor for a product called kleene air or try www.reliableparts.com
Apr 01, 2009 | Refrigerators
Very bad smell coming from dishwasher
Possibly a water leak underneath or a dead mouse behind the unit.
Mar 17, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
Exhaust smell
What does it smell like? If it smells like rotten eggs that is a tell-tale sign that your catalytic convertor is bad.
Sep 10, 2008 | 1998 Toyota Camry
Heating & Cooling Logo
431 people viewed this question
Top Electrolux Heating & Cooling Experts
christian nielsen
ivan georgiev
ivan georgiev
Are you an Electrolux Heating and Cooling Expert? Answer questions, earn points and help others
