Question about Lands Phones
MY AT&T 1782,, 2 LINE MACHINE, ANSWERS THE CALL BUT WHEN I LISTEN TO THE MESSAGE BACK, THERE IS JUST A LOUD HUMMMMMMMMMM..WHAT THE HECK DO YOU THINK IS WRONG? THANKS,, SCOTT
  • bossjock95 May 18, 2009
    ITS NOT JUST THE PLAYBACK, YOU CAN NOTHING BUT THE HUM WHEN THEY TRY TO RECORD
    I GET NO VOICE MESSAGE AT ALL JUST A HUMMMMM ON THE MACHINE
    Genius:
  • 1,689 Answers
Hi Bossjock,
does the humming sound happen on another storage? if so then this is a clear issue with the way the input is being recorded.
best if you have the issue isolated first before boiling down to a specific fault.
regards,
voodoo
Posted on May 18, 2009
  • 11,896 Answers
It sounds like you may have a faulty capacitor inside the machine that is not sending the correct voltage. I recommend checking for any loose components and wires inside the machine. Also check to make sure there is no loose or broke solder joints inside. It does sound like a faulty capacitor or other internal component. You can check the capacitors with an ohmmeter to make sure they are not shorting out.
  • Nate Stansfield
    Nate Stansfield May 18, 2009
    If you do not feel comfortable testing the components, I can guide you through the process. Otherwise I recommend having it replaced or repaired.
    Novelist:
  • 130 Answers
In the recording machine there is filter and a mini speaker .in your unit the filter and mini speaker are got faulty so they are leaving this hummmm noise while listening the recorded message.this parts has to be changed in the unit.as you can get the part at
www.radioshack.com
but if the unit is quite old replace it.
the cost of this part may not be more then $15 for both.
thanks.
please do rate the solution.keep updated.thank you for using fixya.
I have Comcast on my phone & have had the phone answering taken off from them, however, I cannot put a message on my GE phone answering system. The "phone lady" answers saying we are unavailable at...
The phone lady thats answering the line,it that message through comcast or the GE answering machine? Also, whats the model number of the GE answering system?
Jun 09, 2010 | GE Lands Phones
When I start machine C451 it says Call Tech Error C-B003
FAX Board Error To clear turn power off and on the machine if it comes back fax board needs replacement and or main board. Check your phone line is it clear use a old phone and listen to dial tone and have some one call the fax line listen to line clear and crisp? Phone company check line also. Nice machine!
Mar 05, 2010 | Office Equipment & Supplies
Armada m700 working fine. oneday got message 1782 disk controller failure. have tried removing things. will get message even if hard drive & caddy removed. have reset startup sequence have tried with...
 disk controller failure - the chip from the laptop's motherboard that's controlling the disks is fried. Nothing you can do - all hd's will be unrecognized - that laptop is dead.
 Buy a new one.
Oct 30, 2009 | Compaq Armada M700 Notebook
Retrieving messages over phone
when your greeting answers, punch in your code, usually a 4 digit code, each manufacturer has their own default code that it comes with.. check the manual or website
Apr 14, 2009 | Lands Phones
How to access messages remotely
While you are away from your home or
office, you can use a touch-tone phone,
or a pulse (rotary) phone with a pocket
tone dialer (available through your local
RadioShack store) to enter your PIN and
do any of the following:
• set the phone to answer or not
answer calls
• listen to your messages
• record a new outgoing message
• erase messages
• monitor the room where the phone
is located
Notes:
• You cannot remotely operate the
phone using its handset or another
telephone on the same line as the
phone.
• You can also listen to the message
recorded on Line 2 by making a call
to Line 1’s number (or vice versa).
USING THE TOLL-SAVER
If RING TIME is set to TS (toll-saver),
(see “Setting the Number of Rings” on
Page 15), the phone answers after three
rings if you have new messages (ones
you have not listened to). If there are no
new messages, the phone answers after
five rings. This gives you time to hang
up before the phone answers so you
can avoid unnecessary long-distance
charges.
Note: Toll-saver works only on the line
you called. If Line 1 has no new messages,
but Line 2 has one, the telephone
answers after five rings when you
call Line 1.
USING REMOTE
COMMANDS
Follow these steps to operate the phone
from a remote location.
Note: If you wait more than 15 seconds
between keypresses, the phone sounds
a long beep and hangs up.
1. Dial your phone number and wait for
the phone to answer.
2. If the phone is not set to answer
calls, it answers after about 10 rings
and sounds a series of beeps.
3. When the outgoing message begins
(or the phone sounds a series of
beeps), press #, then enter your PIN
within 2 seconds.
If the PIN is correct, the phone announces
the day and time, then it announces
the number of new and old messages.
The phone plays all new messages,
then beeps about every two seconds to
let you know it is ready to accept remote
commands.
Notes:
• If the phone does not respond, try
entering your PIN again. If you enter
an incorrect PIN three times, the
phone beeps and hangs up.
Remote Operation 27
• When the phone is operating from a remote location, it stops all answering functions
and rC appears on the display on the base. The phone resumes answering
functions when it is no longer in remote operation, if you have not turned it off.
• The remote playback of incoming messages is limited to 4 minutes. If you have
more messages after 4 minutes have passed, you must press # 2 again to listen
to the rest of the messages.
• When using remote operation, you can only delete the current message during
playback. You cannot delete all the messages stored at one time.
The following table shows the remote commands you can use.
Note: Remote operation stops when someone picks up the handset and presses either
LINE 1 or LINE 2 (whichever is flashing), or any phone on the same phone line.
Remote Commands
Press #
then (within
2 seconds:
Function
Repeat current message during playback.
2 Play messages.
3 Skip current message during playback.
4 Delete current message during playback.
5 Stop playback, recording, and room monitoring.
6 Set the phone to answer or not answer calls.
7 Record or stop recording a new outgoing message.
8 Play the outgoing message.
9 Switch to the other line (Line 1 or Line 2).
0 Monitor the room where the phone is located for 15 seconds
Mar 19, 2009 | Lands Phones
Machine won't answer
Hey there Tgd258,
Yes... indeed AT&T has been making answer machines (that I am aware of) ...
For more than a half a century ...
Western Electric, Lucent... whatever...
they all share VERY clear... concise DIRECTIONS.
Digital means it does not even need tapes...
Read the instructions and you are good to go...
AT 1782 User Manual
Hope this helps
Carnac the Magnificent
Dec 26, 2017 | AT&T 1782 Digital Answering Machine
Panasonic answering machine not working
We had the same problem. Unplugging the unit and restarting it again solved the problem.
Nov 15, 2008 | Panasonic KX-TG6700 Cordless Phone
Sprint RadioShack answering machine CAT. NO.: 43-5812
http://telephones.att.com/docMgt/public/art/162/1717_manual.pdf
Your question is not clear enough, You can check it out in the user manual. I just guess you are asking recording your personal annoucement.
Before using this answering system, you
should record the announcement (up to
one minute long) that callers will hear
when the system answers a call. If you
choose not to record an announcement,
the system answers with a prerecorded
announcement: “Hello. Please leave a
message after the tone.”
1 Press and hold "Annc/Skip". The system
beeps. Speak toward the microphone
normally, from about nine inches away.
While you are recording, the Message
Window displays —.
2 To stop recording, release "Annc/Skip".
The system automatically plays back
your announcement.
To review your announcement, press
and release "Annc/Skip".
Sep 02, 2008 | AT&T 1717 Digital Answering Machine
Will not send faxes
Make sure the phone line is plugged into the LINE jack on the fax, NOT THE PHONE JACK. The phone jack is to add a telephone to the fax. If it is connected properly, try calling your fax from a cell phone and see if it answers. If the fax answers, hang up and press the HOOK button on your fax and use the fax keypad to call your cell. If the cell rings, answer the call and listen for the fax machine tones. If you hear the fax on the cell, you may have to change your machines TRANSMIT or DIALING settings.
Jul 30, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Answering machine cuts message off
Sometimes if the person isn't talking loud enough the machine may "think" there is nobody there, so it simply hangs up.
Jim
Jan 23, 2008 | Uniden Cordless Phone
Lands Phones Logo
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
