Operator Manual for Keystone Regal K109 Projector
General operating Manual
SOURCE: operator/instruction manual
as the burden of battery camera canon digilife DDV-C330
Posted on Jul 21, 2008
  • 9 Answers
SOURCE: i need the manual for the Optoma DMD Projector HD70...lost mine!
you can call optoma and request an owners' manual. another idea is to check their website, usually sites have a download section and there you can download a copy of the owners manual in a pdf format.
Posted on Nov 12, 2008
SOURCE: OPERATOR MANUAL OF MERCEDES C220
how to wiper on marcedes c 220
Posted on Mar 26, 2009
joedirty
  • 158 Answers
SOURCE: Need an operator manual for the Keppler Power
here you go-glad to be of help
http://ifitnessdirect.com/pdf/kettler/7876-000-power-stepper.pdf
Posted on Oct 22, 2009
SOURCE: Keystone 8mm movie projector
Re Keystone 68 projectors:
I join the growing throngs of folks who wish to view their family archives in 8 mm before submitting the reels to the digitals for conversion. Doesn't anyone have an answer for us? I continue to search, if I find, I'll post.
Fauvette
Posted on Jan 21, 2010
I need a manual for a 2014 Keystone Laredo 290sre, 5th wheel
the 'manual' consists of a book - containing specific operator/technical manuals for all various attachments to your RV. suggest contact your unit's manufacturer for assistance, or go online and download the specific individual owner manuals.
Feb 21, 2017 | RVs
I purchased a 2014 keystone cougar 333mks fifth wheel last fall. We did not get a manual on how to operate, etc. Where can I get one.
2014 !! See your dealer. The manual isn't a manual per se, but you should get a booklet of general instructions and a manual for all appliances.
Mar 12, 2015 | RVs
I have problem with christie projector roadster x9
If your's is the "s" model there is no keystone adjustment provided. Otherwise the keystone adjustment is found under MENU then 1, Size and Position and under MENU 2, Image Settings. Also, refer to this excerpt from the manual:
NOTE: This function is not available in "S" models.
Adjust the keystone control if images appears non-rectangular or keystoned in shape-that is, smaller at either the top or bottom edge. The effect of keystone adjustment is similar to
physically tilting the projector forward or backward in relation to the screen, and it affects all sources.
NOTES: 1) Keystone is enabled for a source only if Size is 1000 and Size x Vertical Stretch is 1,000,000.
2) Keystone adjustment is not available in "S"
models. 3) Avoid using Keystone with Blanking.
Nov 19, 2014 | Office Equipment & Supplies
Keystone not working
Manual: http://www.mitsubishi-presentations.com/wp-content/files_mf/mitsubishi_manual_xd250ust.pdf
Installation>Wall Screen>Keystone
The automatic keystone adjustment may not be carried out correctly
because of the ambient temperature and the installation
conditions of the projector and the screen. In such cases, correct
the keystone manually.
• When the projector is projecting images where acceleration is
present, such as in a vehicle and aircraft, the automatic keystone
adjustment may not function correctly. In such a case, set AUTO
KEYSTONE in the INSTALLATION menu to OFF and correct the
keystone manually.
• You can correct the vertical keystones. However, their adjustment
ranges are limited in such correction.
When the keystone adjustment is carried out, the adjustment
value is indicated. Note that this value doesn't mean a projection
angle.
• The allowable range of the adjustment value in the keystone
adjustment varies depending on the installation conditions.
• When the keystone adjustment takes effect, the resolution
decreases. In addition, stripes may appear or straight lines may
bend in images with complicated patterns. They are not due to
product malfunctions.
• Noise may appear on the screen during the keystone adjustment
because of the type of the video signal being projected and the
setting values of the keystone adjustment. In such cases, set the
keystone adjustment values in the range where the image is displayed
without noise.
• When the keystone adjustment is carried out, the image may not
be displayed correctly because of the type of input signal.
Mar 13, 2014 | Mitsubishi XD250U-ST DLP Projector
How do you change the lamp in a mod # 980Z keystone projector
There is a black and silver knob under the keystone label( right above the automatic label ) on the side of your projector. turn this knob counterclockwise to loosen the covering over the housing unit for the lamb. once the knob is loosened lift the housing unit off of the side of the projector. You wlll see the enclosure where the lamp fits into beneath it.
Make sure the power is off for your projector while doing so. Screw the lamb into the enclosure , then replace the covering and screw the black knob in clockwise until it tightens.
Sep 21, 2012 | Office Equipment & Supplies
Keystone regal k109, how to change bulb?
1. Turn the projector OFF
2. Make sure the lamp housing is COLD.
3. Remove the two hex headed nuts on the top of the lamp housing.
4. Make sure the top of the lamp is COLD.
5. Use your thumb and press DOWN firmly on the top of the bulb,
6. Grasp the top of the lamp firmly with your thumb and one or two fingers and turn it counter-clockwise one quarter of a turn.
7. Lift the bulb 5-inch-long out of the socket and housing.
The bulb is available on Amazon.
Dec 31, 2010 | Cameras
The projector comes on.but there is no picture.lens not opening
Press and hold the two Keystone buttons on the top of the projector. Turn the projector ON and continue to hold down the two Keystone buttons for 15 seconds.
Release the Keystone buttons.
Turn OFF projector.
Turn ON projector, lamp should strike.
Sep 23, 2009 | InFocus ScreenPlay 4805 Multimedia...
Once the projector is plugged in there is no picture. The projector comes on but the lens doesnt open
Try doing a manual reset by depressing the two Keystone buttons and turn power on. Hold down the two keystone buttons for 15 seconds, then release and turn projector OFF.
Turn ON projector and it will be reset.
Fauvette
Jul 12, 2008 | BenQ (200NSH-LAMP) Projector Lamp for...
287 people viewed this question
jasbo
jasbo
