Question about Acer Aspire One PC Notebook
I only get left channel on DAW recording
Is USB mono or stereo, do I need driver upgrade?
    Top Expert:
  • Acer Master
  • 23,240 Answers
Check the processing setup.
Posted on Dec 28, 2013
Is usb audio mono or stereo
USB audio is digital and contains what it encoded to it. If a stereo signal with video and data is sent down the usb line, that is what will be there.
Dec 28, 2013 | Acer Aspire One PC Notebook
B2 Pro left stereo channel is Mute
This is not a stereo microphone. There is no left channel. If you are recording into a stereo input, you need to split the input into two mono inputs, and record each channel as a mono track.
Feb 02, 2013 | Behringer B-2 Pro Professional Microphone
Hi i have connected the Samson G-track with my macbook. also i using Nicecast & Traktor for radio broadcasting. when i talk from Samson G Track my voice comes only from left speaker. I try the...
This is because the G Track's Mic signal is on the Left channel and the Instrument signal is on the Right channel. You are making a stereo recording when you should be making 2 mono recordings. Does Nicecast have an option to set the track to mono Left channel? Traktor should, but I haven't used it so I can't tell you where the option is. There's probably a Track Input drop-down or something like that.
Sep 12, 2011 | Samson G-TRACK USB RECORDING MICROPHONE...
Samson G Track USB Mic
To get sound in both channels in Garageband for a podcast using the G-Track Microphone:    select a voice track to record into    make sure the Track Info window is open (blue i button in lower right region of screen)    at the bottom of the Track Info window you will find Input Source:    Change the default setting of Stereo to Mono 1 (USB Audio CODEC)
This assumes you have gone to Garageband preferences and changed the Audio/Midi settings for audio input to USB Audio CODEC which appears when you plug in the G-Track Mike
Apr 08, 2009 | Samson G-TRACK USB RECORDING MICROPHONE...
AKG Perception Microphone ony recording in mono but want stereo.
I have similar problems with inputing stereo sound. How do you know your mic port on the PC is set for stereo? What kind of a cable are you using? If it is an XLR, the connection is pure mono. Maybe you need a TRS cable, which looks like a 1/4 inch jack but is really stereo. Maybe you need a stereo mini. Usually a cable mismatch is the problem. Is your phantom power supply passing stereo? All the ones I have seen are mono. You may need two. Is your sound capture set for stereo? Are the input level controls set correctly for equal volume on left or right channel? I would try the mic with a regular amplifier to insure both channels are working. Then trace the signal from mic to power supply and power supply to computer.
Dec 03, 2008 | AKG Perception 100 Microphone
Recording one channel only
I had the same problem on a turntable and it was the cable, those rca cables are notorious for breaking inside at the plug end. The stylus cartridge not being completely plugged in may cause it too I imagine. I'd bet it's the right rca cable broken inside at the plug end.
Aug 05, 2008 | Gem Sound DJ-2100 Turntable
Samson co1u recording issue
you first 3 people are idiots... maybe if you had worked with the hardware you would know how the mic works because its obvious you don't. The 4th person is correct because this is exactly how i use the mic and it captures sound in stereo format beautiful when set up rite. Using it in mono, whether use keep on one channel or two drastically reduces the crisp sound that this mic can record.
Mar 18, 2008 | Samson C01U - USB Studio Condenser...
Playback only on left speaker
The quick, easy solution is to change your microphone to mono recording. In the attached YouTube clip, I'll show you how to do that.
The short and simple is to go to your Mac HD -> Applications -> Utilities -> Audio MIDI Setup. Select your C01U USB device, and set it to 1ch 16bit. This will set the microphone to record in mono, equally over both speakers.
Nov 26, 2007 | Samson C01U Consumer Microphone
Lexicon lambda
push the monitor button to go mono instead of stereo.
Oct 11, 2007 | Lexicon Lambda Usb Desktop Recording...
Acer Aspire One  PC Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
