Question about Pride Go-Go Ultra X 3-Wheel Travel Scooter
I HAVE AN UTRAX SCOOTERR, 6 YEARS OLD, JUST REPLACED THE BATTERIES. THE SCOOTER RAN FOR 15 MINUTES THEN STOPPED SUDDENLY. HIT THE RESET AND RAN FOR ABOUT 5 MINUTES TIL A SUDDEN STOP. HIT RESET EVENTUALLY TO A CRAWL FOLLOWED BY FREQUENT STOPS. MY WIFE ENDED UP PUSHING ME OUT TO THE CAR.
  • Pride Master
  • 1,271 Answers
Hi, that is either a connection problem to the batteries or ( and ) a connection problem to the rear axle, remove the axle and you will still 4 connectors , convince your self that these connections are good..
IT could be the controller breaking down but i doubt it...
Please come back to me ..
www.gewizrepairs.co.uk
Posted on Dec 30, 2013
5 Suggested Answers
  • 177 Answers
SOURCE: I HAVE A CELEBRITY DX SCOOTER,
Hi John.
The problem could be a worn throttle pot ( wig wag ). Next time you are driving the scooter, try moving the ends of the speed lever slowly up and down, instead of in or out as you normally use it. If the throttle pot is worn, moving the lever this way will make the machine speed up or slow down.
Another cause might be a faulty battery lead connector or a faulty motor connector.
Good luck. Neil.
Posted on Jul 07, 2010
  • 16 Answers
SOURCE: PRIDE CELEBRITY DX RUNNING SLOW
Hi
Please Check your Potientiometer also known as a Pot, This is your Speed Control and it may be on the way out after 4 Years ,
My Own Pot Packed up after 11 Months, Try to get a Second hand one as they are Expensive to buy,
Good Luck, Gerry.
Posted on Aug 01, 2010
  • 692 Answers
SOURCE: after using the scooter for about 15-20 min. much
Phud Bad brake!!! the brake disc pad is dragging on the motor housing and causing the squealing and battery drain. The motor housing is also getting very warm after that period of time. Replace the brake assembly Hope this helps
Posted on Oct 31, 2010
gfreed100
  • 60 Answers
SOURCE: celebrityx scooter blinks 5 pause 5 everytime i turn key on
Either your parking brake is engaged or if your scooter is more like mine i have a Rascal 600t it gives a code 5 service code when it thinks its in free wheel. The freewheel mechanism is located on the trans-axle which if you go outside across grass it gets wet. This device doesn't like moister and will get stiff will partially engage or disengage. In that mechanism there is a micro-switch which if the lever when slipped into the engaged position doesn't go all the way to the seated position the switch will see the mechanism as being disengaged [in free wheel] and will inhibit the motor from running. I lubricate the entire assembly with pure silicon spray oil,WARNING, do not use WD-40, It will eat some plastics.After lubricating the lever should move smoothly. I have to lub my scooter about once a month in the winter.
Now if this doesn't work check the connector that are all the wires are connected. Disconnect the connector check the pins are ok reconnect check to see if your still getting the failure. If you are still getting this problem do continuity checks on the wiring. You will need a multimeter only $9
http://www.amazon.com/Mastech-YG188-Pocket-size-analog-multimeter/dp/B00064CH6A/ref=sr_1_8?s=hi&ie=UTF8&qid=1339024102&sr=1-8 Check the switch in the freewheel assembly. Select ohms the highest scale, short the leads together, zero the meter by turning the zero adjust knob. There is only one wire we are interested in. On some scooters you can visually see the switch and the wire running from it. The wire usually goes to a spade connector. Disconnect the spade connector put a probe on that connector leading to the switch. Disconnect the battery put other probe on the positive side of the terminals that were connected to the battery not to the battery it side.Work the switch does the meter needle deflect to zero, no, try the negative side. Does the meter deflect, no, put the probes directly on the switch terminals, does the switch.when worked now cause the meter to deflect, no, replace switch, yes, the problem is in the harness, don't panic, use can use that meter to trace the wire through the harness. Wiggling wires and flexing connectors usually makes the meter flick at some point. Thats how i do it i'm never without my trusty meter. My scooter a Rascal are notorious for having problems of this type my mid-frame harness fell apart in the middle of a six lane intersection, the scooter simply locks up tight .I can do nothing but sit in the middle of this huge intersection. People try to move me but the scooters wheels are locked, my illness makes it so i can't communicate with people, it was a mess. So i modified the connector so its no longer a latch type connector. I drilled it for a quick pin which is much stronger than what its using now. Hope this helps
Posted on Jul 07, 2012
Celeb XL shows flash code 4-1.we replaced burnt plug &broken spring on a brush still no go.batteries less than 1 year old any ideas?
Hi check youre batteries with a load tester U can buy them on E/BAY FOR APROX $39 THIS WILL GIVE U AN ACCURATE READING ON THE CONDITION OF THE BATTERIES ::::code 4 current limit time out .::::::: Turn scooter of for a few minutes & turn back on. ::::::: If U have left the key turned on for over 15 min the computer (control box) will shut down remove key for a short time then try it :::::::: check youre freewheel lever is in drive :::::: also check the reset button on the panel in front of the seat push it in it might have turned of .. good luck
Oct 25, 2016 | Pride Health & Beauty
My E300 runs for 15 minutes get's slow rests then runs again what wrong???
it will run slow for 40 mins at a slow speed, after 15 mins of running fast, the batteries get too hot
Apr 11, 2016 | Razor E300s Electric Scooter With Seat
The scooter was in storage for some time--I'm sure the batteries completely ran down. Do you know if a trickle charger can be used to bring them back?
Hello Lara, go ahead and try a trickle charger. iIf your batteries are more than 3 years old, they may not recharge even with a trickle charger.
Jul 30, 2015 | Pride Go-Go Ultra X 3-Wheel Travel Scooter
My mobility scooter said batteries ok not charged for a while went for about a minute then stopped suddenly going over entrance to supermarket just completely shut Down thought batteries were gone but they...
Since this is a scooter you take apart you probably had an intermittent connection at the place where the 2 sections join. A few scenarios. 1. You may not have latched the 2 sections and they momentarily separated causing a disconnect resulting in a power failure. 2. The connectors are fitting loosely and the jolt caused a momentary disconnect resulting in the power failure. 3. You may have a connector in the circuit that has come loose and from the jolt you had a momentary disconnect. You need to make sure all connectors are securely clasped. 4. Check your battery terminal connections, sometimes they become loose and a jolt will do the same thing. If you find that the connector at the place where the two sections come together, you will have to replace the needed wiring harnesses to correct this problem.. A local service tech should be able to quickly find the problem.
Mar 10, 2014 | Health & Beauty
Rv furnace stopped working
Quick call the installer to see if it is still under warranty. There is something wrong if the motor is being replaced every other year. Most of the motors should be lubed with fan turbine oil and not 3 in 1, nor detergent containing oils. If the wrong oil is used, the bearings will go south in 1 to 2 years.
Nov 23, 2013 | Heating & Cooling
Is there a reset button on a Merit Pioneer 10 scooter
You had better recheck your connections because the batteries are polarity reversed
Mar 20, 2017 | Cars & Trucks
Won't come on
Definitely check the air filter, it has a sensor and will stop working if it's dirty. Easy to clean by running water through it.
Jun 09, 2010 | Goldstar DH304 Dehumidifier
I have a calypso washer it seems to be stuck on the heavy cycle no matter what i dothe display says 53 mins it wont do anyhting wont start if i hit the button wont let me choose another cycle like quick...
I just ran into a similar problem. Ours was stuck on Normal with 42 min. Started beeping every couple minutes last night after bad rain storm. Couldn't get it to stop. it would turn off if I hit stop and a couple minutes kater (like 2min) it would come on by itself. Left it unplugged overnight until about 6:00pm. Plugged it back in and it wnt right back to the normal mode after about 2min. HOWEVER, I keft it sit with the lid open and it beeped every couple minutes for a while then suddenly stopped. I checjked it and it is off, hasn't come back on. I haven't tried to run a load through it yet, so I don't know if it is fixed or not..
Oct 23, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
My chair isn't charging and has stopped running...
How long have you had the batteries? After a few years all batteries eventually need to be replaced. You can find a replacement battery at http://www.batteryinternational.com/electric-scooter-batteries.html Hope that helps
Sep 16, 2009 | Electric Mobility Invacare Pronto M41...
Microsoft wireless laser keyboard 6000 v2 - keys suddenly stopped/not working
i had the same problem, i checked the batteries with a DMM and the measured 1.4v i replaced the batteries with new and i still had the same problem. anyway i ended up taking the keyboard apart and found where the antenna is connected to a push on type connector alongside the pcb board inside the keyboard, the connection was slightly corroded. i cleaned it up and it is working fine know, even with the old batteries.
Aug 07, 2008 | Computers & Internet
Pride Go-Go Ultra X 3-Wheel Travel Scooter Logo
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
