Question about AOC L22W761 22 in. LCD TV
Envision l22h998 menu is locked, can not unlock
Menu locked on aoc envision series
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Unlock procedure and to override the password lock of many popular brand TVs and other devices are given. Search the site by type in this key phrase "How to unlock television"; in the search box at the top left of the display window, to get gathered related posts.
Nov 21, 2016 | AOC Televison & Video
How to change from antna to cable
Open your Menu.
Go left to Channel
Down to TV Source
Left arrow to Cable
Press Menu a few times to exit the menu.
Feb 23, 2014 | AOC L22h998 22 in. TV
Envision menu lock
Refer its user manual for details. Try this link to download the manual. Envision L19W698 LCD TV User Manual
Feb 03, 2014 | Envision Monitors L19W698 19 in. LCD TV
I can't turn my tv off. When I try, "power locked"
try pressing both volume buttons and the menu button at the same time.
Feb 28, 2011 | AOC L22h998 22 in. TV
Power locked
Considering you have been patiently waiting for almost two weeks, you probably have found a cure by now. If you have, please post it as a comment to help others.
If I had seen this before, I would have suggested pulling the AC plug overnight to see if it would reset itself; all modern sets are very complex making them prone to unintended actions of the kind we live with on our crummy PCs.
Mar 15, 2010 | AOC Envision L32W461 32 in. LCD HDTV
Power button locked, to unlock...
You may wish to try this (my model AOC g2016wa2)
1. push MENU button
2. scroll to Advanced
3. push MENU button
4. scroll to Factory recall
5. push MENU button
It resets the power button locked setting but you lose all other settings.
Feb 24, 2010 | Envision H190L Monitor
OSD locked on ENVISION Monitor
turn of the monitor then press the menu
Mar 13, 2009 | Envision H191W Monitor
Hcl lcd monitor osd locked
my moniter was automatic restarted, and osd lock not open,where is is osd open option?
Dec 19, 2008 | Acer AL1916W 19" LCD Monitor
Main Menu Locked
You are having problems with the main board, switching controls. This could be a component failure problem or a problem with the controlling IC. You can call Envision customer support at this telephone number. 1-888-838-6388. they should be able to help with getting service for your problem. I hope this information helps you with your problem.
Sep 02, 2008 | Envision 19" Widescreen Flat Panel TFT LCD...
Resolution problems following a power lock.
Turn on the on screen menu by pushing the number (1) button. Go down the menu to the memory recall function and Push the number (2) button to reset all the controls to factory settings. This should return you monitor to it normal function. If this does not solve your problem, you can call Envision customer support at this telephone number. 1-888-838-6388. They should be able to help you solve the problem. I hope this information helps you with your problem.
Jul 14, 2008 | Envision 19" Widescreen Flat Panel TFT LCD...
AOC L22W761 22 in. LCD TV Logo
Top AOC Televison & Video Experts
Raj Patel
Are you an AOC Televison and Video Expert? Answer questions, earn points and help others
