Question about Samsung Un60d6000 60 Inch 1080p Led Hdtv
Samsung television manuals
Where are the hook ups for hdmi and Wii
3 Suggested Answers
SOURCE: Hi, I just purchased a
I figured it out,
The solution to my problem was to update my video cables for my new HDTV.
I found out through trial and error that I can only have one Anolog device hooked up to the TV because with two Anolog devices hooked up the same way it must confuse the TV somehow making one of the inputs showing up in Black and White, So I purchased the color coded AV jacks and everthing works like a charm now.
Posted on Jun 22, 2008
  • 5 Answers
SOURCE: I hooked up the HDMI cable from the satilite to
if you have more then 1 hdmi on tv your box should have 2 u take and plug1 directly in to tv from box and keep it the same way and just change input on tv to hdmi 1 or 2 or 3 etc. most new tvs have 4 of them or let me know what box u have hope this helps ya
Posted on Jan 29, 2011
I'm trying to hook up my wii you to my tv but tv only has one hdmi port that I need for the tv. How can I hook up both wii you and tv if only one hdmi connection on tv?
You can purchase a mult-HDMI box for small amount of money on Amazon. com just type in a search for it. I have one and it works fine, it takes one port and makes 4.
Mar 08, 2015 | Televison & Video
How do I hook up Wii, regular xbox to led hd samsung television The wires are red, white, yellow. Got the sound and picture for the xbox but still no colour. Is there a way to hook it up without buying...
you may have a bad yelllow rca cable for color make sure its plugged in right. or try plugging them into a different input. make sure all the right colors are matched up and pressed ALL THE WAY IN. if not you will need to upgrade your cables to svideo cable, hdmi, or component cable (the red blue and green cable)
Mar 16, 2011 | Televison & Video
I hooked wii up but I cant hear the sound. Help?
Using HDMI? The HDMI SETUP will tell the HDMI to receive the digital audio if the HDMI source (WII) is also setup to send the audio through the HDMI cable, so you need to check the HDMI sound setup at the TV and at the Wii.
Or you can use analog audio RCA jacks, but you still need to set up the TV and the Wii to send audio through analog ports.
Please leave rating if it helps.
Jan 13, 2011 | Dynex DX-L42-10A 42 in. LCD TV
Can't hook the WII and the DVD player both up and the same time.
You can hook the Wii up with the standard RCA jacks and the DVD with the HDMI or vise verses. How many hook ups are on this TV. You can also run the Wii through the DVD using a aux channel on the DVD.
Dec 26, 2010 | Olevia LT37HV 37 in. HD-Ready LCD...
I have a vizio HDMI DTV telvision, and a sony surround sound system, I am trying to hook my wii to this to watch movies, the problem is I have hooked the yellow cable from the wii to the surround sound, I...
If you're using the HDMI cable with 5 wires, the red, blue and green wires are for video and the red and white wires are for audio. If your TV has a component IN RCA jacks, they connect there. If you're using the 3 wire cable, yellow is for video, and the red and white is for audio. You will NOT get HDMI pictures with this setup so you will have to go into the input selections and choose composite video input on the TV menu. Get a connection diagram from Visio's website or look in your owners manual if you have one.
.Connect them to the corresponding inputs
Jul 28, 2017 | Philips HTS-3565 Theater System
I just got my first HD TV, I want to know how to use HDMI cables to hook up my suround, ps3, Wii, and Cable.
Very easy to hook up.It just two USB hubs hook up with a wire basicly.Use 3 HDMI cables for one each device.
Feb 16, 2010 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
I have a 37'' Samsung LCD flaf screen tv and the picture all of a sudden is not clear. It is hooked up to directv box and the two other tv's that I have are clear. I also have a Wii hooked up to the tv and...
Try different ports. Use and HDMI cable and see if it is doing on it. If you are using a HDMI cable now hook the connection up with the component cables and see if it is doing the same thing. If it is clear on one of the other ports you have a port on your mainboard that is bad.
Feb 10, 2010 | Samsung 37 in. Flat-Panel LCD HDTV
I am trying to hook up my wii to my LED TV. It
You don't need component cables. Just use the regular AV connector that comes with the Wii and put the video (yellow) in the video spot that is also labeled "VIDEO" and "Y" on the tv...but the red and white (left and right audio) need to go into the farthest red and white connections...DO NOT put them into the ones labeled "Component Pr and Pb." It works perfectly...I just had to figure this out myself.
Dec 27, 2009 | Samsung UN55B6000 54.6 in. LCD HDTV
I have a samsung led tv and am trying to hook up a wii. The tv does not have component video - only hdmi and usb. How do I hook this up?
I've never heard of a TV not having component cables (the 5 plug cables: red, blue and green video cables, red and white audio cables). I've seen some newer ones without composite (3 cables: yellow video, red and white audio), but never component.
I find is hard to believe it has no component. I looked at some Samsung LED tv's this weekend, and although they lacked composite, they had component. Are you sure you mean component?
The Wii only comes with composite video cables, so you'll need to buy a component video cable for the Wii to hook it up if your TV has no composite inputs.
Component Cables for the Wii
TV's have inputs on the side and rear. If the TV truly has HDMI, USB and nothing else (which I find hard to believe), then you'll need a cheap home theather 5.1 receiver. Ifyou get a cheap one with HDMI out, it should have a few composite inputs on the backside. A cheap sony one can be had for sub $200. If you hook the Wii into the receiver via composite, and the receiver into the TV via HDMI, it will allow you to hook up and play the Wii (and it may upconvert it too, depending on the receiver).
Nov 23, 2009 | Nintendo Wii Console
How do I hook up my dvd player and WII system to my Dynex 42 inch LDC flat panel tv so they are both in color, what inputs do I use ?
Allot depends on your DVD player and WII. Since the TV is a color one unless the movie your watching on the DVD player is B/W it will play in color, same with the WII. If your DVD player supports HDMI then select one of the HDMI ports on the TV (there are 3) same for the WII depending on what outputs it supports select one of the corresponding inputs on your TV. The user manual shows several options for various components and should be of some assistance in your connections.
Nov 14, 2009 | Dynex DX-L42-10A 42 in. LCD TV
Samsung Un60d6000 60 Inch 1080p Led Hdtv Logo
319 people viewed this question
Top Samsung Video Cameras Experts
Lawrence Oravetz
abdul rauf
abdul rauf
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
