Question about UTStarcom Car Charger For Audiovox / Utstarcom Cdm 105 Cdm 180 Cdm 7000 Cdm 8945
How to reset cdm8945
How do you factroy reset this phone. want to get rid of it and get my info off and reset to factory...got from verizon
Dont know the google info after resetting lgk8vs500 on Verizon. My hard reset is not getting rid of the need for prior Google account
It won't get rid of it. It's called a Factory Reset Protection lock and it's meant to deter theft. Depending on your Android version, there are multiple ways to bypass it.
Oct 13, 2017 | Google Cell Phones
Greetings
ur phone must be reset to factory defaults by mistake.
Aug 29, 2008 | Panasonic KX-TG4500 Phone
My tablet does not fo nothing after press power on it just frozen
Try to factory reset your unspecified tablet. Search Google hoe to do factory reset lookng for terms
FACTROY RESET, MAKE AND MODEL OF YOUR TABLET
Sep 29, 2015 | Tablets & eReaders
How to undo a factory reset on my Verizon optimus zone2
As far as I know there is no such capability
Jan 06, 2015 | Cell Phones
Locked out virus. claims to be FBI asking to pay fine and lockout phone pantech breakout
This is a virus and Not going to be easy to get rid of unless a hard factory reset May work. You will have to look up your spacific model and find out as to how to Do a Hard factory reset. Before doing this i suggest you save all your phone numbers to a sim card. Get rid of all the apps you have on that sim card tho as these can be the issue. Just save your phone numbers.
Sep 29, 2014 | Pantech Breakout 4g Black Cell Phone...
Will a hard reset on lg lucid smartphone restore uninstalled apps
Yes, that will make it so that the software will return to the factory state. If not then you'll have to either follow the prompts through the phone menus or boot mode to initiate a factory data reset.
Mar 17, 2014 | LG Lucid VS840 4G Verizon
Restor factroy seeting
Open the MENU >Settings> Resotre factory settings> type 12345.
The phone will reset to default settings.
Jun 15, 2011 | Nokia 1100
Security code nokia 5130c-2
My Nokia 5130c-2 xpressmusic keypaid secuirty code is not open after i give 12345 nokia code.
Jun 27, 2010 | Nokia 5310 Cellular Phone
How to change security code for lg vantage becuase my phone is locked and forgot the code
In my experience and according to my carrier, Verizon, you need the code to change the code. If you dont have the code, it needs to be hard-reset. If you hard reset, you start all over with factory settings.
Have you entered your own code? The default code is the last four digits of your phone number, according to my carrier. for example 216 448 1234, the lock code would be 1234.
If your carrier IS Verizon, hpefully you have used The Backup Assistant. If other carrier, hopefully your info is on your memory card.
Good luck.
I hope this helps you.
Sep 27, 2009 | Cell Phones
How do i reset my Verizon Motorola Razr Silver
If by "reset" you mean you want to clear out all of the info and put all the settings back to factory defaults, then go into the settings menu, select initial setup, then go to master clear. It will ask for a security code. It should be six zeroes (000000). This will erase everything on the phone- contacts, texts, etc.
Mar 12, 2008 | Lands Phones
UTStarcom Car Charger For Audiovox / Utstarcom Cdm 105 Cdm 180 Cdm 7000 Cdm 8945 Logo
Top UTStarcom Cell Phones Experts
iphone service
buzzcola
Level 1 Expert
Are you an UTStarcom Cell Phone Expert? Answer questions, earn points and help others
