Question about Casio CDP200 CDP-200 88 Key Contemperary Digital Piano w/ Stand
Dismantle cdp-200-r trying to disassemble, counter weight is off one key
I have two multiple CD players. One is a 200 CD player (CDP CX205) and the other a 300 CD player (CDP CX355)I do not have the manuals for either. Where can I get them?
Hello Albert,
I went to google and typed in a search for both of your players and came up with the following:
CDP-CX205 got to www.dvdplayer-manual.com and you'get a PDF to download;
CDP-CX355 go to www.usermanualguide.com and type in your model number in the search, then, on the next screen scroll down and select your model number.
Peace Out
Gerry
Oct 18, 2016 | Sony Audio Players & Recorders
How to fix a key with a weight issue
You'll probably have to take it to a Casio repair place, Matty. No weighting at all? Like... light tap gives you fortissimo?
Aug 12, 2014 | Casio CDP200 CDP-200 88 Key Contemperary...
My synthesia dosent work in the learning pack
Transpose the software or the keyboard 12 or 24 semitones up
Dec 24, 2012 | Casio CDP-120 88 Weighted-Key Digital...
I have a CDP-100 and need disassembly instructions for access to internal keyboard assembly. Unit was dropped while unloading from car. Now some keys are akimbo and won't play as though they are off their...
I just fixed my CDP 100 which had a similar problem - dropped and two keys not working up one end.
1. Lay keyboard upside down on soft surface. Under keyboard is plastic cover held on by 17 screws. Remove all these and lift cover away. The metal key ends are all revealed.
2. Locate the disloged keys. Carefully press them back into position - they will "click" into place. Make sure the corresponding key on the keyboard isn't stuck in an "up" position - you may have to remove the metal key part and replace it again while making sure the key is correctly seated.
3. Replace cover and screws.
Feb 22, 2010 | Casio Music
I have a sony CDP-CX235 200 disc CD player? If I want to create my own cd with music, any idea what type of disc and file formats I need to use?
First, I'd get a CD recorder. This machine is only a player.
Consumer CD Recorders will require CD-R Audio or CD-R Music blank media to record.
Feb 21, 2010 | Sony CDP-CX235 200-Disc CD Changer
Sony CDP CX 235 200 cd changer-cd's dropping off
Hi there.
I reckon that they are not being put back correctly by the loading mechanism! This is a common problem with these units. It is highly unlikely that they are actually falling off the carousel.
Open the unit, and watch it as it loads and replaces the cd's from the carousel. You will probably find that instead of grabbing the disc off of the spindle and putting it back, it might be grabbing before the cd is even in its grip. This then simply bumps the cd out of the way, and it will fall inside of the unit.
The good news is that it can be fixed with a bit of very gentle bending and persuading. But be very carefull when doing this!
Good Luck!
Jan 22, 2009 | Sony CDP-CX235 200-Disc CD Changer
Cd's always skip
You have done well for 10 years laser changes are in order
When a cd skips it is due to laser diode becoming weak over time not producing an original beam causing focus prolbems ,hence skipping discs
Dec 29, 2008 | Sony CDP-CX220 200-Disc CD Changer
My washing machine shakes so much when spinning that it comes out of it's slot from under the counter. I think the weight in the machine has fallen as there is cement dust on under the machine
sometimes the concrete weights come loose, it will need to be dismantled ( back, top, front, off) to see where. could need new fixing bolts or screws. when weights have been refixed ,make sure the machine stands firmly on the floor on all four feet and doesn'twobble at all
Oct 05, 2008 | Whirlpool Washing Machines
Pc drum
Replacement of the Photo Conductor Unit
1. Select Tech. Rep. Mode → [Counter] → [Special Parts Counter] → [PC Life].
2. Press the Clear key to clear the counter value.
3. Turn OFF the main power switch.
NOTE
• Clear the PC Life counter before removing the IU.
• After clearing the PC Life counter, be sure to turn OFF the main power switch.
4. Open the Right Door.
5. Remove the IU. Carefully pull on the two green handles
6. Remove four screws (silver) on the sides and disassemble the Photo Conductor from the Developing Unit.
7. Replace the Photo Conductor Unit
8. To reinstall, reverse the order of
removal.
NOTE
• Replace the Toner Filter (Developing
Unit) with a new one at the same
time.
Jun 06, 2008 | Office Equipment & Supplies
Casio CDP200 CDP-200 88 Key Contemperary Digital Piano w/ Stand Logo
37 people viewed this question
Top Casio Audio Players & Recorders Experts
Greg Cann
Greg Cann
David Payne
David Payne
Danny Kuhlmann
Are you a Casio Audio Player and Recorder Expert? Answer questions, earn points and help others
