Question about Car Audio & Video
Citroen c5 problems
Hi I have a citroen 2008 c5 all of the steering wheel functions have stopped working and the seat bellt warning buzzer and the indicator bleep any ideas thanks steve
  • Stephen Hewitt
    Stephen Hewitt Dec 28, 2013
    i have tried all the fuses and ther fine
  • Stephen Hewitt
    hi I have tried all the fuses and there fine
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 95 Answers
Broken clockspring.
Posted on Feb 06, 2014
Citroen c5 faults
This is the ABS control unit, they are faulty from years 2007 to 2008.
had to get mine replaced.
May 21, 2014 | 2008 Citroen C5 1.8
Headlight warning buzzer not working
My 2010 tacoma doesn't have a buzzer. The lights automatically go off when you turn off the engine and open a door.
Apr 05, 2014 | 2008 Toyota Tacoma
Steering Wheel hard every time i start the car
Check the power steering fluid
turn the ignition on and off 3 times (common citroen power steering fault solution)
hopefully this will fix
also check the power steering pump fuse
Mar 25, 2014 | 2008 Citroen C4 1.6i
PROBLEM WITH WARNING LIGHTS BEFORE IGNITION ON C5
most likely yes..when starting..each time it does a self diagnostic..once started if all the lights go out.. and it runs fine.. drive it..
Jan 05, 2014 | Citroen C5 Cars & Trucks
Citroen c5 2008 problems
check for blown fuses..
Dec 15, 2013 | 2008 Citroen C5 2.0
Citroen C5 airbag fault warning stays on
I had this problem after the dealer serviced the car! They couldn't fix it despite several tries so I was stuck with the fault. Then I remembered I had the same fault in my previous XM model but it would reset on engine re-start. On that car it usually happened after a full left or right steering lock combined with hard braking when maneuvering in tight car parks. I figured that if this caused the problem then maybe it could also cure it. I tried it in a safe place, alternating left and right lock with abrupt braking. It didn't seem to clear the fault but after a 15 minute trip to the shopping centre I was surprised to find that the fault was gone when I re-started the engine! I have not had this problem in over a year now despite living with it for over three weeks at the time.
Apr 16, 2009 | 2000 Audi TT
Replace ignition tumbler
STEP BY STEP Please Remember to Rate Me Thank You RejakWilson
WARNING: On vehicles equipped with Airbags, disable airbag system prior to performing service procedures.
  1. Disconnect battery ground cable.
  2. Remove steering wheel as outlined under STEERING WHEEL procedure.
  3. Using a screwdriver, pry cover from housing.
  4. Using lock plate compressing No. J-23653 or equivalent, compress lock plate, and pry snap ring from groove on shaft, Fig. 5. Slowly release lock plate compressing tool, then remove tool and lock plate from shaft end.
  5. Slide canceling cam and upper bearing preload spring from end of shaft.
  6. Remove turn signal (multi-function) lever.
  7. Remove hazard warning knob retaining screw, button, spring and knob.
  8. Remove pivot arm.
  9. Wrap upper part of electrical connector with tape to prevent snagging of wires during switch removal.
  10. Remove switch retaining screws and pull switch up from column, guiding wire harness through column.
  11. Reverse procedure to install.
  1. Remove turn signal switch as outlined under TURN SIGNAL SWITCH.
  2. Remove buzzer switch and spring clip. On 1990-92 models, ignition key must be removed from lock to remove buzzer switch. On 1991-92 models, switch and spring clip are one assembly.
  3. Turn lock cylinder to Run position on 1989 models or Lock position on 1990-92 models, then remove lock cylinder retaining screw and the lock cylinder.
  4. To install, rotate lock cylinder to the stop while holding housing. Align cylinder key with keyway in housing, then push lock cylinder into housing until fully seated. Lock cylinder must be in Run position to install buzzer switch.
  5. Install lock cylinder retaining screw, then the buzzer switch, turn signal switch and steering wheel.
Aug 30, 2008 | 1989 Chevrolet Celebrity
Car Audio & Video Logo
211 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
