Question about Samsung 61" Slim-Depth DLP HDTV
Fan noice and picture distortion...
Samsung DLP HL-P6163WX purchased in late 2004 and has worked GREAT up until a few months ago. Clearly "a" fan was straining and the TV would have a difficult time turning on. Once on, after a few attempts, it seemed to ease it's way to normalcy. Happens most of the time now and yesterday, TV was on most of the day and we began to get a very funny picture, over time we lost the picture. I turned the TV off the remainder of the night and tried it again this AM. It worked fine for a few hours and then began to act up (funny/distorted colors, whining noise, etc.)
  • Anonymous Mar 14, 2014
    Worked great but has recently began turning off on its own. If you unplug, tv resets and functions again. Still has great sound and pic when working.
  • 110 Answers
Replace color wheel.
Posted on May 18, 2009
Samsung p6163wx - lamp sign flashing with a loud noise fan on, no picture. Replaced with a new bulb - did not solve the problem
This set may use a color wheel if it has a lamp. A bad color wheel will make a fan like or high pitched sound.
If the wheel actually shatters (it can) the set will not function and will turn the lamp off.
See photo of color wheel and if you need to know I can tell you how to look at it.
Mar 14, 2012 | Samsung Televison & Video
I've a Samsung DLP Model HLR-4266WX that has started to hum and is distorting the picture. I've replaced the cooling fan on the heat sink in the back and that didn't work. Is there another fan in the set...
Color wheel would be cause of hum noise and distorted picture on screen.
Please note that color wheel is not user level repair and requires expertise because it is located in light engine, the most sensitive and expensive part of dlp tv.
If you are good with electronics stuff fix then have service manual copy in hand to start inspecting color wheel.
Aug 26, 2010 | Samsung DLP HL-P5663W 56" TV
Samsung DLP 56" tv,distorted picture
if you say that your picture gets distorted you mean like it moves to a side? do you see a black middle block?
if it's a yes?
so its probably the light engine. you need to change it!
try this link.. http://www.discount-merchant.com/1069179-HL-N5067W-p/1069179.htm
the price is more or less depends on your TV model... $279.00
Feb 02, 2010 | Samsung DLP HL-P5663W 56" TV
My samsung dlp has no picture or sound. Model hls5066wx, power comes on lamp light flashes for 15sec and then the standby lamp comes on then it goes back to the lamp light flashing. It repeats this a few...
hi first of all u should check ur transistor connections.Check your Horizontal and vertical output transistors.You should also check the horizontal and vertical yoke connections as well as your low voltage regulators.... if any of these got damaged u should purchase a new one.. but try to purchase with the help of a tv service assistant...
thank u!!!
rate me
Jul 12, 2009 | Samsung HL-67A510 67" DLP HDTV
Samsung HL-R6768W started making squeal noise from rear of TV. At same time lost picture and will not come back on. Sound is ok and you can hear light trying to turn on. Can fan motor not working correctly...
Look at the fan and verify its comming from the fan and not the power supply unit, you can clean the fan or replace it, but yes the fan would be likly the problem. Make sure you double check the power supply unit and clean if its needed,
Rulds2008
Apr 29, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung DLP TV has lot picture. Makes a Humming sound
That sounds most like the color wheel,
to change that you need to have some skill in electronics, I would recommend to take it to a shop
Apr 25, 2009 | Samsung DLP HL-P5663W 56" TV
HL-P5O63W : Rear Lamp Cover Error!
That my be the color wheel you are hearing
They will make a huge whining noise
The lamp door also had issues the lamp switch must be in the up position when you put the door back on
Feb 09, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung DLP HLR5668W has mostly dark picture + grinding noise
Pix looks like a light pipe issue, inside the Light Engine. as far as the shutting down, could be a bad fan causing the grinding and when stopps the DMD turns the set off.
Jul 08, 2007 | Samsung HL-R5668W 56" HDTV
Samsung 61" Slim-Depth DLP HDTV Logo
229 people viewed this question
Henry  Thomas
Henry Thomas
