Question about Mtd Garden
Bought a second hand Turf power Tiller by AGWAY
Bought a second hand Turf power Tiller by AGWAY B& S 5 hp. How much oil and what brand and grade do I use.
2 Suggested Answers
rockitman187
  • 2559 Answers
SOURCE: what's the gas/oil ratio for CT 16 tiller
Husqvarna says 50:1
Here is a link to the break down repair manual for future use
I will send a link to the user manual when located.
Please rate this fixya solution
Posted on May 13, 2009
Have a farm and country rear tine tiller 5 HP.. what lube do you use for the drive system?? Has a lube plug. If lube how much should you use?
Most reputable oil brands have an application catalogue containing grade recommendations and quantities.
Choose your brand and then view the catalogue.
Feb 27, 2018 | Garden
How much oil is used in a 5 horsepower turf till garden tiller? and what weight?
The oil capacity is dependent on the specific make and model of the engine. The weight of oil used depends on the temperature the engine will be operated in. 30 weight for warmer temps 40 degrees F. and higher. 10w/30 for temps 0-100 degrees F. 5w/30 for temps of -20F- 120F. 5w/30 is the best all around oil to use since it flows at such a wide range of temperatures.
Nov 02, 2017 | Garden
Mtd turf power tiller
cannot find anything about a 420 tiller... need an actual model number please
Dec 24, 2013 | Garden
Peg perego 12 v tractor does nothing switch clicks
first of all check the battery and charger and make sure that they are both putting out 12 volts
Dec 27, 2012 | Peg Perego John Deere Turf Tractor
I have an older 5 hp. Mtd tiller Do I have to use
Look on top of the machine.If there is an oil fill then no you do not use mixed fuel if yes it needs engine oil,30 wt.If there is no engine oil fill then you use mixed oil and gas,at a 50:1 ratio.
May 30, 2011 | Mtd Garden Tiller (Mtd)
What type fuel; and mixture for honda fg 100 mini tiller
the Honda FG100 is a 4-cycle engine do NOT mix oil with the gas, - you will cause damage to the engine (head, valves, piston rings etc) not to mention if will not run well.
Mar 08, 2010 | Honda 25cc 4-cycle Mini Tiller
Mantis 4 cycle (brand new): oil leaking out, smoking soaking air cleaner, quits running..
Sounds like your gas tank is not breathing properly. try this: the next time you run the tiller and it begins to stall out, try loosening the gas cap. It should start running again. This means that the gas cap is clogged. Unclog it or purchase another one.
Jim
May 30, 2009 | Mantis 4-Cycle Tiller
Maxim tiller won't run
Try better quality gas. I had the same problem. Ethanol too high in lower grade gas. Buy better grade or ethanol free. Mine works fine with better gas.
Apr 06, 2009 | Maxim Garden
5 hp Briggs and stratton wont run on a MTD tiller.
I had the same problem a few years back. Check the rubber elbow coming from the gas tank to the carb, it's probably cracked and sucking air instead of fuel from the tank.
Nov 30, 2008 | Garden
Garden Logo
784 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
