Question about Swarovski Watches: Rock n Light - L.E. Prune
How to set time swarovski rock n light prune LE
Don't understand how I can set time. Don't see any crown
Setting Time on Police Hammerhead Watch PL 13088 JS/02
the three dials are for three different time zones, there is no minutes or seconds.
to adjust the middle dial just push the small bottom which is located on the back side of the watch
Jan 04, 2013 | Police hammerhead pl13088js-04
Cannot set time for time for tag heure CL111a
You probably have a screw down crown. Turn the crown counterclockwise and unscrew the crown. Now you should be able to pull it out. When tightening it back down, don't over tighten, just snug. This is to keep moisture out of your watch. Always have it screwed down unless you are setting the watch. Nice watch, Michael
Nov 05, 2011 | Watches
Can,t set timeon watch
OK try and follow these steps and it may help you set the time on your Watch. Once you understand the different function buttons on the edge of the case setting the time will be an easy task.
1-Note the 2 and 4 o'clock function buttons and the crown at 3 o'clock on the case edge of the Citizen Skyhawk Eco-Drive. These buttons set all functions of the watch.
2-Set the home city digital display function at 9 o'clock by pulling the crown to the first position. Rotate the crown until the mode hand in the subdial at 6 o'clock is aligned with TME. Press the 2 o'clock button until the nearest major city where you live appears. Press the 2 and 4 o'clock buttons at the same time to find the home city in the 3 o'clock digital display window. Once the city is selected, the time is automatically set by the automatic radio reception function.
3-Pull the crown out to the first position to manually set the time. Rotate the crown until the mode hand is aligned with the CAL, TME and RX-S position under the umbrella line. Push the crown flush with the case edge. Point the watch's 9 o'clock side in the direction of the radio transmitter. For example, if you live in Los Angeles, point the watch's 9 o'clock side east towards Ft. Collins, Colo., where the transmitter is located.
4-Hold down the 4 o'clock button for two seconds until the tone sounds and the second hand stops at the RX-S position. The second hand will then move to H, M or L found at the 2 o'clock subdial. Remain holding the watch in the same position. The second hand will move from the H, M or L position with the hour and minute hands to the correct time once the radio reception is completed.
5-Press the 2 o'clock button to start the chronograph's stopwatch. Press the button a second time to stop the timer. Press the 4 o'clock button to reset the timer.
6-Pull the crown all the way out and rotate it clockwise until the correct date is selected. Push the crown flush when finished.
IF you are still not able to set the time contact your dealer or the nearest Citizen showroom.
Jan 10, 2011 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
How do I re-wind the date on my Timex Easy Reader Woman's Watch?
mcdevito75 here, The stem (crown) on your timex shou;d have 2 positions, this allows you to set the date without haveing to turn the hands around so many times. Place a fingernail just under the crown (winder knob) and lift to it"s first position, it may take some practice so if you don"t get it the first time keep trying, Once you lift the crown to it:"s first position you shoulsd be able to set the date, set the date a day before the date you need, Now, push the stem back in all the way, now pull out the stem and set the date and time you want, you"ll have to go around the 24 hours once to set the correct date and time. Hope this helps. If you can"t do this adjustment, see a small watch repair shop in your area.
Jul 01, 2010 | Timex 27191 Wristwatch
Date function notworking properly
Do as follows:
1) At any time of the day pull the crown out and advance watch hands forward for EXACTLY 12 hours ( for example: if it's 6.35 on your watch, then after advancing hands it will be 6.35 again, just minute hand will be forwarded clockwise 12 full circles, while hour hand will be forwarded 1 full circle). Push the crown back in.
2) Pull the crown out to the date setting position and change to the desired date. Pull the crown back in.
Now your watch will be changing dates at midnight continuosly.
Rate me, please.
Apr 04, 2009 | Tissot Le Locle T41.1.423.33 Watch for Men
Can't set Seiko Yacht Timer Sports 150
Turn knob to set on "Match" Pull out crown knob. Press both buttons for 3 seconds. When you release both buttons it will beep and both hands start moving. Press either button to stop movement. Then press the top button to set the minute hand to 12 oclock. Press the bottom button to set hours to 12. Press in crown and turn to "Time" Pull out crown and set time the same way.
Mar 01, 2009 | Seiko Le Grand Sport SDWF73 Wrist Watch
How to adjust alarms
moz-screenshot.jpgSetting the alarm:
1. Pull the crown to the 2nd "click" (the possition you adjust the time) (Carefull: The seconds hand has to be on "12")
2. Press repeatedly button "B" to set ALARM hands to the time indicated by the main time hands (The ALARM hands move quickly if button B is kept pressed)
3. Push the crown to normal possition
4. Pull the crown to the 1st "click".
5. Press repeatedly button "B" to set the desired alarm time. (The ALARM hands move quickly if button B is kept pressed)
6. Push back the crown in to normal position.
At the designated time the alarm rings for 20 seconds, and it is automatically disengaged as it stops. To stop it manually, press button A or B.
Oct 15, 2008 | Seiko Le Grand Sport SDWF73 Wrist Watch
Swarovski Watches: Rock n Light - L.E. Prune Logo
53 people viewed this question
Top Swarovski Watches Experts
k24674
ray gallant
Are you a Swarovski Watch Expert? Answer questions, earn points and help others
