Question about Rainbow 75th Anniversary Canister Vacuum
Rainbow vaccum I have a rainbow vaccum and it stopped working. The on and off switch may not be working. I am not sure how to change that switch?
  • 2 more comments
  • geovany167 Jun 24, 2008
    where at is that pin?
  • asmistl Aug 27, 2008
    I just bought a used rainbow d4c, It sounded great running two days ago with no problems or noises. I tried to use it today and it doesn't run. The carpet power head runs but the vacuum itself doesnt do anything.
  • Anonymous Mar 11, 2009
    I was using it to blow the dust from my tv and it was working just fine then it just stopped working
  • HAUPTMANN Sep 10, 2013
    no pin in rainbow d4c. I.m work for RAINBOW FOR 20 YEARS.THIS IS PROBLEM WITH MOTOR.
Make sure the bowl has the pin on it. The Vacuum has switch in the bottom that keeps the Vacuum from running if the bowl in not on or the little pin is broken off.
Ralph Wakeman
Posted on Oct 20, 2007
Our rainbow e2 black type 12 vaccum was meant to be used on 110v and was plugged into a 220v, what part needs to be changed to convert the machine to work with 220v
nothing that I can guess at but changing the motor to a 220 . might be more cost effective to purchase a new vacuum cleaner .or use a 110 convertor for your outlets
May 22, 2016 | Rainbow Vacuums
How do I replace the fuse on a rainbow vaccum?
The D4 model Rainbow has a Thermal Cut Off
This has to be manually replaced. It is attached to the Field 120v D4
If this has blown, then most likely something is causing. The Armature Tall 120v D4 could be going bad.
You can also speak with our technical support team Contact Us
Jan 27, 2016 | Rainbow D4se Classic Canister Vacuum...
My rainbow stop red lights.3 times try to start and then switch off by itself.what should I do?
PDF]3 - Rainbow
RexairAs part of Rexair's Customer Care program, each Rainbow and Power Nozzle receives a ... If the Rainbow is not working ... Do not clean the unit or unclog the hose until theRainbow is switched off and the plug is removed from the wall ..... alone or with the Jet Brush attached. ..... The Power Nozzle brush is stopped and.
My Rainbow Vacuum Cleaner Won't Turn On ' eHow
Rainbow keeps shutting off Vacuums Questions & Answers > Forum > Tags > keeps shutting off > VacuumsRainbow vacuums keeps shutting off related questions and answers. ... My Rainbowstopped running I was using the Rainbow and it stopped running. ... the switch . my electrolux has the same problem but wont always turn it probably is ...Three common problems with Power Nozzles and how to fix ...
Dec 03, 2015 | Rainbow Vacuums
My rainbow E2 will run on High speed,but not the low's as if no power is getting to it, try to switch it on low,but works fine on high
This could be one of two problems. It could be your switch is broken, preventing it from going to low speed. Try clicking it, does it still make a distinctive click sound, does it feel loose? If so it may be your switch: Rainbow e2 power switch
Otherwise if may be your computer in your E2 is starting to go bad. Often times if Rainbow stops going into one of the speeds it is due to a computer going bad. This is an expensive part and repair, so you should probably take it in and make sure it is the computer. Rainbow E2 controller 120v
GoodVac com
Feb 13, 2015 | Rainbow Vacuums
How do i reinsert the black little chip on my rainbow vaccum e2 so it can turn on
<p>The part that is sounds like you are talking about is the <a href="">Interlock Plunger.</a> This part is under the <a href="">Right Baffle Plate Assembly.</a> It works with the <a href="">Interlock Switch</a> for safety so the Rainbow will not turn on unless it is latched onto the water pan. Remove the Right Baffle Assembly and insert into the small pocket that the Interlock Switch is installed.</p>
<p>RainVac </p>
<p><a href=""></a></p>
Feb 02, 2013 | Rainbow E series Canister Wet/Dry Vacuum
My rain vaccum
Need more information...Are you having problem with Main unit or the power nozzle? You can also call and speak to a Rainbow Specialist.
Oct 07, 2012 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow vaccum roller got caught in bed spread and stopped rotat
Assuming the belt is not loose, it sounds like something is still stuck under the roller (part of the bed spread?)
Did you check the power nozzle circuit breaker?
You may also need a new roller brush
Mar 17, 2010 | Rainbow Technologies D4 Bagless Vacuum
How to maintain up keep on my rainbow vacuum
Be sure and never store on water basin, keep separator and seal on bottom of rainbow clean. Keep your beater bar clean. You should be good for many many years.
Jul 10, 2009 | Rainbow E series Canister Wet/Dry Vacuum
I don't know how to take apart me Rainbow e2 series vac.
I recently took mine apart because the motor stopped working. Realized the brushes were pretty well worn down and one side was completely gone. I was looking on the internet for detailed instructions on how to take it apart. I ended up just ripping it apart with no problems but made a tutorial to help you guys out. Here's a link to it
This is for the e-series vaccum, not the e2 but they pretty much have the same design and same motor (e2 has a 2 stage motor).
Let me know if you have any questions
Jul 10, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow E Series
You are supposed to use the hard surface cleaner solution and mix with water. Vaccum the hard surface first, then dip the hard surface attachement in the mixture (while machine is off. otherwise you will just **** up all the mixture! :) ) turn on the machine and "mop" away!! I love it!!
Jun 23, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow 75th Anniversary Canister Vacuum Logo
819 people viewed this question
Top Rainbow Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Rainbow Vacuum Expert? Answer questions, earn points and help others
