Question about IBM ThinkPad X30 2672 Notebook
How to change IBMThinkpad eprom
I need to change the eprom how ??
Computer brain
it will only work if it the right prom make sure the numbers of the 2 eproms match
Jun 19, 2013 | GMC Jimmy Cars & Trucks
E-prom
The set has more than one eprom...
With the model number AND the location number of the eprom (location number is marked on top and bottom of the board) GOOGLE FOR THIS INFORMATION.
Mar 27, 2012 | Panasonic CT-32SL14 32" TV
Need to purchase eprom 1.27and installation instructions and whatever comes with it. for alesis masterlink 9600, I have contacted Alesis, they are too slow at service at this time.
If you are very sure that the problem you are facing is generated from eprom only then go ahead with this.
As per my experience the best way to replace eprom is to find a similar motherboard with similar eprom version and replace the eproms.
You can also buy a eprom from the market but again you will have to program that eprom for which you will need the eprom programmer, an electronic device which feeds a script in eprom and also you will require the script.
Sep 20, 2011 | Computers & Internet
I deleted my bios how do i install my bios
The software in the BIOS is stored on an EPROM (Eraseable Programmable Read Only Memory). So, buy some hardware, namely an EPROM writer, remove the EPROM chip from the motherboard, insert the EPROM chip into the EPROM writer, download the latest BIOS-software from IBM's web-site, and load the software onto the EPROM writer, and rewrite the software onto the chip. Remove the chip from the EPROM writer, and reinsert it into the IBM motherboard.
Jul 17, 2010 | IBM NetVista PC Desktop
Error code u-2 solution
U2 00 EPROM error 11 EPROM error
U2 04 EEPROM serial communication error 11 counter check sum error 12 adjustment value check sum error(EEPROM) 40 CRUM communication error
U2 04 EPROM error 11 Main counter error 12 EPROM error
U2 04 EEPROM serial communication error 11 counter check sum error 12 adjustment value check sum error(EEPROM) 40 CRUM communication errorYou need the service help. It is no a distans work Good luck)
Mar 14, 2010 | Sharp AR-5320 Black and White Copier
Philips rear projection TV model 60P8342.
It`s not Eprompt, it`s the Eprom, Erasable Read Only Memory. The Eprom holds all the information in it about your set like has it got Ni-cam Sound, A wide-screen, A projection set plus a lot of other information like Convergence settings, RGB setup, PAL, NTSC settings plus customer settings like Colour, brightness etc. There are other settings besides these which are in binary bit code which can control the power supply, Standby timing etc etc. The Eprom may only be an eight or a sixteen pin device but it a crucial part of the set where information is perminantly being read from the Eprom to make sure the three guns are set correctly and the convergence errors are being kept in check. This is a very time consuming job even for a qualified technician, I know, I used to do these and Philips sets are notorious for Eprom and uPC failures. The Eprom comes formatted from the suppliers, so there`s absolutley no information in it at all meaning that you have to start from zero. If you can get the set to come on long enough and you can get the set into service mode, you may be lucky where you can write down the 200-300 or so settings, If not, WHAT A JOB. Believe me, you can change the Eprom in 2 minutes, but it could take 1 or 2 days to set it all up again and even then it`s very difficult to get it perfect. Ian
Aug 10, 2009 | Philips 60P8341 60" Rear Projection...
Rowe AMI CD100 RAM Error
try this turn the box off , hold down the 0 and the 1 selection button
at the same time turn the box on. that reloads the prom to the ram
Apr 01, 2009 | Audio Players & Recorders
LG 42LB5DF turns on by itself and the channels keep changing
almost all new LG 32, 37, and 42 inch, got this problem, newer version main pc board need to be replaced
Oct 09, 2007 | Televison & Video
IBM ThinkPad X30 2672 Notebook Logo
18 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
