Question about Gigaset As300 Twin Dect Cordless Phone - Black
Phone Can't make or receive calls. Display all looks ok, but no dialling tone. When try to dial out display briefly shows line busy, but don't know why.
2 Suggested Answers
  • 16 Answers
SOURCE: Phone not working
Hi Pam,
Try these..1...remove your telephone line from base unit and fix it into a working land phone and check whether is it having normal dial tone.If it's having engage tone(beep beep...)remove paralleled phones and re connect to cordless base unit.
2.If line is ok (normal dial tone with full volume) & still display indicates line is busy, your main base unit must be having faulty components inside.Commonly these defects happen in thundering or surges through telephone lines.You have to take full set to a repair shop.
Rana.
Posted on Dec 29, 2013
No line displayed on handset. No dialling tone. Unable to make or receive calls.
At the cost of asking the obvious, please check phone line connection to the wall and the phone. Sometimes a minor disconnect can lose you dialing tone. If the phone company says line is good, try other phone jacks to see if you get dial tone.
Oct 21, 2014 | Lands Phones
What does a boken dialling tone on my phone mean? It is all working fine and there are no warning messages on the display.
Usually broken dial tone means the line has call-forward set. You get broken tone for 3 or 4 seconds, then goes back to normal. Are you receiving incoming calls normally? It's common to set or cancel 'cause the code might kinda match a number you use. And it may be forwarded to nowhere, example, you dial 729-1111, but press 72#-1111. You might be forwarded to 1111, the code being 72#. The 1111 goes nowhere, someone calls you, calls gets forwarded, then they get a message"that number does not exist". If that's the code for your area, then 73# might be the cancel code. Check the front of the original phone book, or Google codes for your service provider.
Jun 11, 2014 | Panasonic KX-TG4500 Phone
Phone not working
Hi Pam,
Rana.
Dec 28, 2013 | Gigaset As300 Twin Dect Cordless Phone -...
Phone can receive calls but not make them.
hello i have a solution, you need to change you dialing mode on the base option, the deafult is "tone dialling", change to "pulse tone " this fix my problem on my A495 gigaset.
May 16, 2012 | Lands Phones
Call forward will not turn off, have tried *74 & *73 , have rebooted and turned off then on, call divert symbol still on and phone calls still diverted.
To set Unconditional Call Forward ON Dial "*72" for a dial tone. Dial the forwarding number followed by "#". Wait for dial tone. LCD will display "Call FWD Activated"
To Cancel Unconditional Call Forward: dial "*73" and get the dial tone, then hang up. LCD will display "Call FWD Activated
but, since you have tried those two, it could be that there might still be a different type of call forward option that is still ON, on your phone like Busy Call Forward and Delayed Call Forward 1. To Cancel Busy Call Forward: dial "*91". Wait for dial tone. Hang up.
2.To Cancel Delayed Call Forward: Dial "*93" for a dial tone, then hang up.
Let me provide you a link to the website which I used as a reference for your future reference.
http://www.grandstream.com/user_manuals/GXP_User_Manual.pdf
Apr 27, 2011 | Grandstream GXP-2000 IP Phone
Dialled calls,missed calls and recieved calls
hi,
in my phone dialed, received and missed call data are not saved. all data vanished and it shows empty always
Jul 09, 2010 | Samsung Cell Phones
I can't make a call or receive calls, I tried unplugging it several times and all the lights starts blinking!! When I try to dial a button, it gives me a busy signal.
You are probably trying to dial out on an intercom button. This will give you a busy every time. You may have to dial 9 to get out.
To test your phone, 1st find out what your intercom number is (press feature*0 and then press the intercom button) Your display will show you the intercom number of your telephone. Then try to make an in house intercom call to another working telephone. If that works have them call you back.
The next step is to find out if you have any lines programmed to your phone. (press "feature*0) and then each button on your phone. The display will show you what is programmed on that button. If you have any that say "001 Line001" or such those are the outside lines to dial out on. Hope this helps.
Bill C. www.dyna-tech.us We provide remote programming and tech support for Norstar CICS MICS and Call pilot 100/150.
Mar 11, 2010 | NorStar M7310 Corded Phone
Cordless telephone sw/from pulse to tone
dear,
check this link and hope it will solve the problem
http://www.epinions.com/content_56960192132
regards,
Aug 15, 2008 | Uniden Cordless Phone
Fax nightmare!!!
If you have a BT line and use the 1571 answering facility , when you have a message waiting the dialling tone changes from a constant tone to a split tone. This is to let you know that you have one or more messages waiting.
In order to get the dialling tone to revert to the constant tone you have to deal with the waiting messages in accordance with the options provided i.e Save, Listen Again or Delete. BT say the Split Tone is to let subscribers know when they have a message waiting. This should resolve the Fax problem.
It certainly worked for my phone/fax system.
Good Luck
Geowilmil
Nov 28, 2007 | Pitney Bowes 9920 Plain Paper Fax
Gigaset As300 Twin Dect Cordless Phone - Black Logo
16 people viewed this question
Top Gigaset Lands Phones Experts
deton8 von Splosion
Rishan Ranatunga
Level 1 Expert
Are you a Gigaset Lands Phone Expert? Answer questions, earn points and help others
