Question about Maytag MBF2556HEW / MBF2556HEB / MBF2556HEQ Bottom Freezer Refrigerator
LOOSE DOOR HANDLE ON GE PROFILE ARCTICA STAINLESS STEEL REFRIDGERATOR
THE RIGHT STAINLESS STEELE DOOR HANDLE TO MY GE FRIDGE
HAS GOTTEN EXTREMELY LOOSE AND I HAVE NO IDEA HOW TO FIX
THIS...ANY SUGGESTIONS???
  • 4 more comments
  • assemblers1 Jun 30, 2008
    I have Maytag MFD2561 HEB bottom freazer, fridge and one side of handle come off, handle is 2 color, I dont know, how to remove the top part so I can tight the hanle back to the body.
  • tabmine May 17, 2009
    The handle on my Maytag stainless steel fridge is coming loose how do i tighten it
  • Anonymous Mar 14, 2014
    door handle is loose on a ge side by side
  • Anonymous Mar 15, 2014
    to fix a loose door handle kenmore fridge 596-67942600
  • Anonymous Mar 18, 2014
    loose door handle
  • Anonymous Mar 26, 2014
    adora
  • 473 Answers
I may need to know your model # from the sticker inside the fridge to view a diagram but usually there is are small set screws (usually 2) on the handle which are allen head that can be tightened.  Look for this first and let me know if there are no set screws.  If this is your setup then I would appreciate a solved rating.
Posted on Oct 18, 2007
Where are the duel water inlet valves located on ge fridge arctic profile
unless you have a water dispenser, top mount refrigerators usually only have a single inlet water valve. Either way, the valves will be located in the back on the machine and covered by the lower portion cover, but will have a small area for the water line to hook up. Just remove the lower panel in the back and you will be able to see it
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 22, 2012 | GE Profile Arctica Stainless Steel Top...
I have a GE Profile Arctica Fridge. The temperature in the Freezer has dropped to 34 degrees and the Fridge has dropped to 40. The fridge is running and is blowing air in the freezer, but not really...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 11, 2010 | GE Profile Arctica Stainless Steel Top...
Fridge door not closing 100% at the top.
Loosen the screws holding the top door hinge. Pull up on the freezer door and hold it while you re-tighten the hinge screws.
Dec 31, 2009 | GE Profile Arctica Stainless Steel Top...
The freezer part keeps popping open whenever you close the fridge part. How can I fix this?
The magnets in the freezer door arent making good contact, try adjusting the front legs up to make the fridge lean back slightly
Nov 25, 2009 | GE Profile Arctica Stainless Steel Top...
GE Profile Artica side by side stainless steel wont get cold
The Profile and Artica are good refrigerators. the problem may be the defrost element, defrost thermostat or the mother board. Let me know if you want help on this one. Thanks Sea Breeze
Jun 18, 2009 | GE Profile Arctica Stainless Steel Top...
Freezer door handle loose
Can you give me the model number? Ther are alot of variation of handles.
Nov 14, 2008 | GE Profile PSW26P Stainless Steel Side by...
Ge artic refrigeratior freezer stainless steel
Unplug / Replug the fridge. If doesn't work might be the mother board in back.
Jul 13, 2008 | GE Profile Arctica Stainless Steel Top...
Loose Handle
the screws are sometimes hidden by a metal or plastic trim. you can take the trim off with a butter knife (usually).
Jun 29, 2008 | GE Profile PSW26P Stainless Steel Side by...
Maytag MBF2556HEW / MBF2556HEB / MBF2556HEQ Bottom Freezer Refrigerator Logo
590 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
Carlos Alvarez
Level 1 Expert
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
