Technics stereo tape deck rs-t20 manual - Audio Players & Recorders
welcomejee
  • 10594 Answers
SOURCE: Technics RS-CH770 double tape decks
Please check Capstan Motor working / rotating. If no, check its supply volts. If yes, then check Capstan Belt and FR Belt, should not be any cracks on it. If found cracks, please replace them.
Posted on Aug 13, 2008
  • 99 Answers
SOURCE: I need to know how to record 1 tape onto another
press the synchro start button, the tape deck should now go to REC PAUSE, press the SPEED button till you get the required recording speed then press the synchro start again and it should start to record from deck 1 to deck 2.
make sure the tabs at the top of the tape you want to record on are intact,
if not just put a bit of sticky tape over holes.
hope this helps?
Posted on Jun 29, 2010
caroldon
  • 17130 Answers
SOURCE: How to replace drive belts on Technics dual
First of all you will need some mechanical mind to open out the set. The tape mechanism has to be removed and the connections should be noted and removed. If the old belt is already in the mechansim then you will not have any issue with the direction of the belt to go around the capstan flywheel. If you have alreaddy obtained the correct belt then carefully open the back of the mechanism to remove and reset the new belt. When replacing check for the free running of the capstan if not use a small drop of oil to free. If the belt was not there then wind from the motor to the second flywheel after running it around the first flywheel to drag it along so that when the motor turns you have the flywheels turning freely. reset the back plate using a thin probe type tool to hold the belt and release to the motor. For a first time it may be a bit difficult but try again. Hope you get this right. Good day
Posted on Jul 20, 2010
skywavebe
  • 1258 Answers
SOURCE: technics tape deck rs-eh600 wont play it just clicks
Another dual deck it seems- the unit will need service by a Technician, there is no magic that will make it work. It may be as little as a large belt. I would have to see the unit to tell you the exact cause.
Posted on Aug 14, 2012
skywavebe
  • 1258 Answers
SOURCE: Technics RS-TR272 dual cassette deck
Ahh, Another Dual cassette deck. These are typically not worth a repair charge. I went looking for a service manual but Hi Fi Engine did not have one but they had a Owners Manual. Any unit that has a specification as to wow and flutter starting new at .18% was never made to be a long lasting deck of any quality. I don't like to be negative about people equipment but you might be better off getting a better deck from the start. If you think it is worth the repair, then send it to someone but I don't think you will want to sink $100 into a unit like this.
I am not saying it is unrepairable but that with what you come out in the end you could have made a better choice for a deck to buy.
It is probably a bad solder joint or bad capacitor on the circuit board.
I am in Chicago and would look at it for you if you want.
Posted on Oct 17, 2012
Technics rs-tr180 looking for repair manual
Look on Ebay. It will not be available new anymore. I might have it as well for a cost. Visit audioserviceclinic.com. Contact me there.
Sep 16, 2014 | Technics RS-BX501 Dual Cassette Deck
Technics stereo cassette deck rs az6 spares
Tape belts are universal generally. All you do is measure the diameter of the belt in MM and if it is wider than the "string" type the width in MM again. Put the words "cassette drive belt xx MM" into Google. You don't have to precise with the measurements.
Feb 23, 2014 | Technics Audio Players & Recorders
Finding a Microcontroller for a Technics Tape Deck
I am sure there is one available or suitable sub . I wonder if technics would provide more information if you contacted them or a local electronics store.
A microcontroller may or may not be programmed for a specific purpose so, that also may be an issue if not purchesd froma source used for that device.
There is also a forum called tapeheads:
Technics RS-B49R - Tapeheads Tape, Audio and Music Forums
www.tapeheads.net >
http://www.tapeheads.net/showthread.php?t=49248
I found some links here and even a few sold for parts around 15 bucks:
Google
https://www.icom.co.jp/world/support/download/manual/disp_down.php?SWT=&ID=20010101177&GNR=Amateur&TYPE=Mobile&PDNM=IC-901A/IC-901E&INQWORDSWT=No&INQWORD=
Mar 26, 2017 | Panasonic Technics cassette deck rs-br465
Can I use a microphone through a technics rs m216 tapedeck?
The tape deck was designed for stereo recording using two separate mikes, one for left input and one for right input
Jun 28, 2012 | Technics Audio Players & Recorders
I can't find the manual to my Technics RS-TR272 Stereo Cassette Deck. How do you tape something on one cassette to another?
Place the tape you want to record into the left deck, Then the blank tape into the right deck. Press play on the left deck and record on the right deck.
It may be opposite depending on which side your recording deck is on.
Which ever deck has record, place blank cassette into that one and the cassette you want to copy into the other deck.
Hope this helps and please rate thanks
Mar 13, 2011 | Technics RS-TR272 Single Cassette Deck
Where can I find a power cord for my technics stereo cassette deck RS-B282?
Not sure what is odd about it-is it a regular IEC 3-prong? Mouser may have a cable if it's something else.
Dec 20, 2010 | Technics RS-TR373 Single Cassette Deck
Tape deck not working on a technics rs-eh600. Small belt has slipped off, need advice in putting back on.
My tape deck is not working. When starting play it goes forward and then reverse. What can I do?
Apr 02, 2010 | Technics Audio Players & Recorders
Help
Just connect you EQ to your receiver as if it were a tape deck: EQ's outs connect to receiver's tape ins (play) and EQ's ins connect to receiver's tape outs (record).
Then you hook the tape deck up to the tape ins and outs on the EQ: Tape deck outs connect to EQ's tape ins (play) and tape deck ins connect to EQ's tape outs (record).
This will put the EQ in your receiver's tape loop. To hear the EQed signal with all receiver sources you'll need to engage the 'Tape Monitor' button or switch which will route the tape loop to the speakers.
Nov 22, 2007 | Technics RS-TR272 Single Cassette Deck
113 people viewed this question
 Grubhead
Grubhead
