Question about HP OfficeJet 6310 All-in-One Printer (Printer/Scanner/Copier/Fax) w/USB Printer Cable , Retail
Dell latitude d630 laptop - os xpp
Printer will not print when attached to laptop with ethernet cable going into usb port. printer has been installed but will not print. already tried using wizard. did not help. how can this problem be fixed?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 127 Answers
You are a little confused. The ethernet cable will not fit into the USB socket. Do you mean that it is connected with a USB cable? Is the printer on, with paper loaded and the tray pushed right home? A bit unusual for an HP to jib. Make sure that all cables are well and truly home.
Posted on Dec 28, 2013
4 Suggested Answers
leroyal
  • 2120 Answers
SOURCE: unable to get printer to print
Go to www.hp.com and let the website auto-detect your printer
Posted on Mar 08, 2009
  • 45 Answers
SOURCE: Was able to use printer "wirelessly", now must use USB cable
first of all check whether the printer is on a network or not by printing a network confirguration page..to print a network confirguration..1.press the setup button..2.scroll down to option to network press OK..3. then it says view network settings press OK..4. then it says print network confirguration page..the page that prints you will see IP Address of the printer..
now come to the computer..open command prompt..type PING and then the IP address of the printer..if you get a message packets sent=4, recieved=4 ,lost=0 then it is on a network..otherwise turn off the printer computer and the router..wait for 5mins and then turn on the router wait for 3mins then the printer wait for 3mins..and then the computer..then try to PING..
and go to the printers folder you would see the icon of the printer..right click on it go to properties..and in the properties screen you would see a tab which says ports..under ports check for which option does the printer is been check..if it is checked for USB then the printer will not print..if it is checked for TCP/IP then it is fine..
if it is checked for USB then you need to do add a device by inserting the software CD..if it says TCP/IP then got to the setup folder in the Software CD..you would see a folder UTIL..open that then you would see CCC..open that then you need to select uninstall_L2..once the uninstallation is complete..restart the computer..and then start the installation.printer would be detected on a network..installation would be successfull..then try printing a test page..that would print
Posted on Mar 09, 2009
  • 39 Answers
SOURCE: HP3600 USB printer works but won't print on my HP7058 Laptop
Try removing all ports from your laptop, then reboot, and then create just one USB port. Also, go to your hardware devices and make sure your usb ports don't have any question marks or yellow warning symbols. Be sure first that the drivers for your USB ports are installed and working first. This sounds either a faulty USB cord, which does happen, or USB drivers issues in your laptop. The printer is probably not the problem here.
Posted on Feb 17, 2010
How to install a wind iows 7 os when nothing is going into internal memory
As long as the connection interface isn't different, the Rpm does not matter.
Here's a walk through on how to install the drive.
http://blog.parts-people.com/2011/08/15/dell-latitude-d630-hard-drive-and-caddy-removal-and-installation/
The Bios should automatically recognize the new drive. You can go ahead and install the operating system from a bootable cd or usb.
Aug 19, 2014 | Dell Latitude D630 Notebook
Dell latitude d630 - windows xpp os
Check virtual port for printer and conform it.
Dec 28, 2013 | HP Officejet 6310 All-In-One InkJet...
I have no internet on dell latitude e 6400 laptop how do I download drivers for it and get wifi going
What OS? Use a Ethernet cable, Have you tried here: http://www.dell.com/support/drivers/us/en/19/Product/latitude-e6400 OR try windows updates using a Ethernet cable. OR use another computer and a USB drive go to dell website, download drivers to USB drive, transfer to laptop, install drivers.
Sep 23, 2013 | Computers & Internet
My dell d630 works great but when i connect the VGA port to my sceen it does not work. do i need a driver or is this a hardware issue?
If you attach the VGA and just the projector(or external screen) is not working and your computer still works, it could be a settings option. Connecting it then going to Start>Control Panel> Hardware and Sound>Connect to a projector. Make sure "computer only" isn't marked.
Hope i could help
Jan 05, 2013 | Dell Latitude D630 PC Notebook
Broken headphone jack on dell d630
Yes! if the plugin is not secure the connection will be poor causing unstable reception in the audio department.
May 10, 2012 | Dell Latitude D630 Laptop Computer PC...
I just got a new dell. i've hooked my old hp
1. Try to connect this printer to your PC by ETHERNET cable as opposed to USB 2.0 and see if it speeds up.
2. If it speeds up we know it isn't necessarily the printer giving the problem
3. Now we start to look at the cable. Use a brand new cable to attach it to the PC. If it persists it may very well be the USB port on the Printer itself.
4. To test the port, attach it to another PC and if it speeds up as u expect, then it is not the USB port on the Printer
5. Now it's time to check the Printer Software on the new Dell and fiddle with it a bit accordingly.
Solution
If it is that u cannot get it to speed up by USB and it works well by Ethernet, just use Ethernet to connect it and call it a day
Mar 15, 2010 | HP Photosmart C6280 Printer
Will not print when docked
I would recommend that you undock the laptop, go into the Printers and Faxes console, and delete the printer. Then, dock the laptop, connect the USB cable to the dock and then re-install the printer through the dock. The USB ports on the laptop are assigned different hardware values than the PCI interface of the dock, and if the laptop is trying to print to a local USB port, it may not find the printer if it's connected through a PCI interface like the dock. That'd be my next move.
Mar 04, 2010 | Dell D/Dock Expansion Station Docking...
How do i activate the video camera to skype? skype is not recognizing that i have one on my dell latitude d630
Try uninstalling driver and reinstalling. Skype has a feature that helps you check your camera. Try donloading skype again and reinstall...
Nov 17, 2009 | Dell Latitude D630 Notebook
Connecting dsl modem to dell latitude laptop
If your DSL modem does not have a phone port or if it has one but it's bigger it's not a phone port, it's called an Ethernet port. Most of the DSL modems/routers they have an Ethernet port. This is how it looks like click here. If this the port that you have on your modem, the cable that is also in the picture is what you should be using to get the laptop connected to the modem. The cable is called an Ethernet cable. And your laptop must also have this ethernet port.
If you have more question please let me know. Just reply to this post.
Feb 14, 2009 | Dell (0E828) for Latitude C610 Modem
Large data transfer laptops, cable, or USB adapters DELL Lat-C
the system must surely have a ethernet port... why dont u try a peer to peer connection.... they can achieve very good speeds...
Nov 23, 2008 | HP Pavilion dv9000z Notebook
Open Questions:
See all HP OfficeJet 6310 All-in-One Printer Questions
Seeker5211
Seeker5211
