Question about Gateway Computers & Internet
My GATEWAY NE52207U won't start
Won't boot
Won't boot linux cd
Try changing the boot order to HDD.
Mar 07, 2013 | Gateway Computers & Internet
Gateway laptop ml6732 has a startup repair screen and won't boot
Please re install OS .
Please specify what exactly went wrong when u used setup cd to re install
Jan 05, 2013 | Gateway ML6732 Notebook
Why won't my Gateway PC DVD drive close?
Are all the Windows and Gateway updates and Hotfixes in? Look for a DVD rom fix on the Gateway website support. If there is no disk in the drive and it opens, you may want to replace it. You can try a work-around, I have no idea if it will solve the problem, but at boot open the BIOS, go to Boot sequence, Change HDD to boot first. DVD/CDrom 2nd or 3rd.
Dec 26, 2012 | Gateway Computers & Internet
Gateway 3522 laptop won't boot up
HDD problem, try to fix boot record and test HDD with Hierens Boot CD
Nov 13, 2012 | Gateway 3522GZ Notebook
Gateway CX 2620 unit won't turn on. Replace motherboard?
If the power LED is on then -
The problem maybe the RAM, it is faulty or just needs reseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up then remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you.
Sep 01, 2012 | Gateway Convertible CX2620 Notebook
Gateway MP8708 Won't boot past BIOS and won't boot into CD/USB/Safe Mode on XP - Blank screen with keyboard dead - Num locks on and wireless light
Windows won't start up? Well, try this Download Tenorshare Data Recovery from its offical site and install it. Burn it into CD/DVD, or USB flash, put into the computer you need to repair, Bios setting. It can make sure your important data will not lose. Best of luck
Related: windows won't start
Aug 25, 2012 | Gateway MP8708 Notebook
My gateway 4540GZ won't boot up when I turn it on
Disable other bios setup and enable only the hard-disk.The procedure is these:put on your machine for the first time immediately press (F2) button.if it refuse to display off your machine and restart Then immediately press (F9). when it display the setup locate and select boot menu it will display all the booting function such as: CD/DVD RW, HARDDISK,ADAPTER AND SO ON just select each one it will show two options:ENABLE/DISABLE. you just select disable for others except HARDDISK should be ENABLE.finally,close it and apply save& exit.restart your computer it will definitely boot up.
Nov 24, 2011 | Gateway Computers & Internet
I have a gateway laptop that won't boot up. Only
try checking out to see if maybe you have a bad memory inside first. then if thats not the problem im gonna have to figure your hard drive might be going bad because of corrupt files and fragments.
May 27, 2011 | Gateway Laptop with Intel Centrino...
Computers & Internet Logo
42 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
