Question about HP DeskJet 882c InkJet Printer
HP Deskjet 882C Both green and red lights flashing. Tried disconnecting plug and reconnecting it. (If you suggest I reinstall, please explain how.)
ctf1800
  • 4402 Answers
SOURCE: Color Printing Problem
If a document displays in color on the screen but prints in black and white, try the following solutions. Print a test page to determine if the color cartridge is working
  1. Turn on the printer.
  2. If you have an HP Deskjet 710c, 712c, 720c, 722c, or 820c series printer, follow the instructions below:
    1. Turn the printer on.
    2. Press and hold down the Power button while pressing the Resume button four times.
    3. Release the Power button.
  3. If you have any other HP Deskjet printers, click here for instructions on how to print an internal test .
  4. If the printout is black and white, with no color, follow the instructions below:
    1. Open the top cover of the printer and remove the cartridges.
    2. Verify that the correct cartridges are installed in the printer. Click here to see if you have the correct cartridges . If the correct cartridges are installed, make sure that the tape has been removed from the cartridge nozzles.
    3. Insert the cartridges firmly back in their cradles and close the latches.
    4. Close the printer door.
Verify the correct printer is selected as the default printer
  1. In the software application that you are using to print, click File .
  2. Click Print .
  3. In the Print dialog box, verify that the name of the HP printer you are using is listed in the Name box.
  4. If the printer is not listed in the Name box, click the arrowhead to the right of the box.
  5. Click the name of the HP printer.
  6. Click OK .
Check that the printer settings are correct
  1. Close the software application that you are using to print.
  2. Click Start , click Settings , and then click Printers .
  3. Right-click the icon (picture) for the HP printer.
  4. In the menu that displays, use the left mouse button to click Properties .
  5. In the Properties dialog box, click the Details tab. (In Windows 2000, click the Advanced tab.)
  6. Check that the driver listed under Print using the following driver or Printer matches the HP printer you are using. The following setting may be in one of several places, depending on your printer driver and operating system.
  7. In the Details tab, click Setup . Under Printout, select one of the color options. (If other options have check marks, click in the check boxes to remove the check marks.) If there is no Setup button, click the Graphics tab, and then click Color . Under Color Control, choose a color option, and click OK . If there is no Graphics tab, click the Advanced tab and look for the text Print in Grayscale . If there is a check mark in the box by Print in Grayscale, click in the box to remove the check mark, and click OK . If you are using Windows 2000, in the Advanced tab, click Printing Defaults . Click the Advanced tab. The box by Print in Grayscale should not be checked.
  8. Click OK .
  9. Close the Printers window.
  10. Open the software application that you were using to print.
  11. Try printing again.
Install a new driver If none of the above options worked, the wrong driver might be installed on the computer. For the most current HP printer drivers, go to the HP Web site.
Posted on Jan 09, 2008
  • 125 Answers
SOURCE: HP DeskJet F380 won't copy
If you can't get it to scan an image then you might have to have it brought to a repair center. How often do you use the copy function? Scanning function?
Posted on Apr 23, 2008
ginko
  • 19396 Answers
SOURCE: HP Deskjet F2100
Check power cable first
Posted on May 18, 2008
SOURCE: hp deskjet 3550 problem
my hp deskjet 3550 doesnt doesnt work it green light only keeps on blinking and no response from at all.. please help me tanx
Posted on Jul 10, 2008
  • 11 Answers
SOURCE: flashing on/off light on hp deskjet 3520 printer
Introduction The printer lights indicate the printer status. These lights can be on, off, or blinking (flashing), depending on the status of the printer. The sections below describe the most common combinations of blinking lights, how to fix the issue, and how the issue is caused. NOTE: The light patterns included in this document are described as blinking or flashing lights. For the purpose of this document, "flashing" means the same as "blinking." Blinking lights Printer lights can can blink for more than one reason, so the solution can vary. These solutions need not be performed in a specific order, but solutions for the most common issues are presented first. Blinking lights are often accompanied by an error message on the computer screen, which might help determine the solution. Issue: Power light is blinking
c00374282.gif Solution
Close the cover.
Cause
Printer cover is open. Solution
Insert appropriate media in the In tray.
Cause
The printer is out of paper. Solution
  • Change the printer's print mode setting.
  • Change the printer's paper type selection.
  • Use a different brand of label media.
Cause
The printer has difficulty picking up label media. Solution
Follow each of these steps until the problem is resolved:
  1. Remove the paper from both paper trays.
  2. Press the power button once. Wait a moment for the paper jam to clear.
  3. If printing labels, verify that a label did not become detached while passing through the printer. If the paper jam was not resolved, continue on to the next steps.
  4. Remove the rear access door.
  5. Remove the paper jam through the opening at the back of the printer.
  6. Replace the rear access door.
  7. Reload the paper into the paper In tray.
  8. Print the document.
Cause
There is a paper jam. Solution
  1. Remove and then reinsert the print cartridge(s) into the printer.
  2. Clean the print cartridges automatically using the Clean Cartridges option in the Printer Assistant.
  3. Manually clean the print cartridges and print cartridge cradles:
    • Open the printer cover and wait until the carriage moves to the center.
    • Press the Power button to turn off the printer.
    • Disconnect power cord from the back of the printer.
    • Remove the print cartridges and place them on a piece of paper with the nozzle plate facing up.
    • Lightly moisten a cotton swab with distilled water.
    • Clean the face and edges of the print cartridges with the swab. Do not touch the print cartridge ink nozzles or copper contacts.
    • Wipe the underside of the print cartridge cradle walls using a clean, moistened swab.
    • Reinsert the print cartridges.
    • Close the printer cover.
    • Connect the power cord to the back of the printer.
    • Press the Power button to turn on the printer.
  4. Calibrate the print cartridges.
  5. If the light is still flashing, replace the print cartridges.
Cause
There is a problem with a print cartridge. Solution
  1. Print a printer self-test by holding the power button down with a pencil and opening and closing the top cover four times.
  2. Check the nozzle self-test pattern in the self-test print out. If one or more of the solid rectangular areas are missing, an electrical contact problem may be present.
  3. Remove and then reinsert the print cartridge(s) into the printer.
  4. Print the document.
  5. If the problem persists, follow the steps listed above for cleaning the print cartridges and print cartridge cradle.
  6. Try printing again. If the problem continues, replace the print cartridges.
Cause
The print cartridge has partial loss of electrical interface with the carriage connections.
Posted on Mar 04, 2009
Service manual
The ink well in the printer looks like it
has packed up this happend to me
had to get a new printer
Apr 14, 2014 | Apple HP DeskJet 840c InkJet Printer
My printer won't feed paper
To resolve the issue please clean the paper feed rollers,you will get the instructions from the link below...
http://h10025.www1.hp.com/ewfrf/wc/document?docname=..........
Apr 11, 2010 | HP DeskJet 882c InkJet Printer
Loaded a new black ink cartridge, getting flashing yellow light and won't operate.. reloaded many times.. no luck... help plz?
Hello sir; Turn power on, open the cover, UNPLUG the power cord, loading the cartridge, put cover down, plug in the power cord, it should reset.
Dec 24, 2009 | HP DeskJet 882c InkJet Printer
HP 882C printer only prints email in red
When you give print command choose the printer also got to printer properties and choose the option black print mode.
Sep 17, 2009 | HP DeskJet 882c InkJet Printer
Hp Deskjet 5550 making grinding noise then stops.
Here is a page explaining how to resolve this issue:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=71895&prodTypeId=18972&prodSeriesId=71895&objectID=c00681585
Apr 21, 2009 | HP DeskJet 5550 InkJet Printer
I have an HP Printer DEskjet 882C. The colored cartridge ran out so I put a new one in and the flashing ink light still won't go out and so now the printer still won't print... I cleaned the nodes with...
Normal 0 Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 04, 2009 | HP DeskJet 882c InkJet Printer
Light flashing printer no print
unplug the (USB or Parallel) cable of the Printer from Printer backside which is connected to the Computer
open the top lid of the printer and check whether the carriage comes to middle or not?
It it moves automatically, then its fine.
Check the cartridges.
click the URL Link giveb below it will open a webpage. If it does not open a webpage then please copy the entire link and paste it in the address bar of the internet browser and click on "GO"
HP Deskjet 800 Series Printers - Fixing Blinking Lights
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpd09169&cc=us&lc=en&dlc=en&product=59305&dlc=en&lang=en
HP Deskjets - What are the front panel lights and buttons on the 800 series printers?
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpd09133&cc=us&lc=en&dlc=en&product=59305&dlc=en&lang=en
Check the End of warranty date on both the cartridges.
Deskjet 882c printer does not support reserve mode printing.
Means, even if only cartridge is defective or expired the printer will not print with other cartridge which is fine.
Both the cartridges should in inwarranty and fine.
Shake the cartridges well
With the color and black cartridges touch a clean, slightly damp cloth (squeeze out excess water),
to the printer nozzle area on the print cartridge, to see if you can make the ink flow freely.
Be careful not to touch the nozzle area (with holes on it) on the cartridges.
Wipe the copper-colored electrical contacts with a clean distilled water or clean tap water and then with a dry lint-free cotton cloth
Also using a new swab, clean the electrical contacts inside the printer, in the carriage.
Install both the cartirdges in the printer, disconnect the printer from the computer and try to print a self test and diagnostic page
Running a sample page
Press and hold the RESUME button until the printer starts printing.
Release the RESUME button.
Running a diagnostic test
Press and hold the POWER button.
Press the RESUME button four times.
Release the POWER button.
Nov 20, 2007 | HP DeskJet 882c InkJet Printer
Open Questions:
HP DeskJet 882c InkJet Printer Logo
56 people viewed this question
Seeker5211
Seeker5211
