Magnavox Dvd Combo
When we put in a dvd it just says "loading" and nothing happens
  • MAMASIS Nov 09, 2007
    when we put in a DVD all we get is loading and nothing happens. maganavox dvd combo
  • MAMASIS Nov 10, 2007
    yes, but all I got was "loading"
  • 790 Answers
HI!
Your dvd is not reading well maybe your laser eye is dirty! you can clean it with 100% cotton buds... try to clean first... then test run.. if the problem is the same maybe the ribbon wire is defective replace a new one ribbon wire to test run.. if the problem is the same replaced the laser stigmata unit... this is the three method of repairing and testing of dvd! i hope this method is to help you a lot... thanks!
Posted on Nov 09, 2007
  • 752 Answers
The laser is either dirty or worn out. You could try a "Cleaning" disc, but odds are more likely that it is worn out. To have it repaired would be between $50-$150 depending on the parts needed and the shop.
Posted on Nov 08, 2007
  • Mitch
    Mitch Nov 09, 2007
    Right. Did you try the cleaning disc yet?
  • Mitch
    Mitch Nov 11, 2007
    It sounds more like it's worn out. Time for a new laser assembly. Call around for estimates.
Magavox flat screen combo dvd player spits out dvds
The DVD loading tray is not getting locked properly inside. It could be a mechanical problem. You may have to open the top and see what happens when you load it. Also look for worn out belt.
Aug 24, 2012 | SNK Magnavox 32MD357B_37 32 in. LCD...
Magnavox DVD eject button fell in TV
Take a close look where the plastic button was--it if there would engage a tiny round black rubber like button---using a pencil eraser see if you can gently push the button.
Jun 13, 2012 | Philips Magnavox 20MC4204 20 in. TV/DVD...
Magnavox vcr/dvd combo the vcr part only plays for 8 seconds
What you have is called a transport problem in the VCR unit--the mechanism is either jammed or something in it that loads the tape is bad.
Every time it is used it cycles to self check the mechanism--if it fails it is usually a belt bad or a gear assembly not working.
Someone would have to open unit to see what is happening.
May 28, 2012 | Philips Magnavox MWR20V6 DVD Recorder/VCR
I have a phillips magnavox vcr dvd recorder combo model number mwr20v6 that i have had fo about 2 years and here lately every time i try to record on to a dvd it pops up with error code e454037380.i have...
I have a phillips magnavox Problem with the Philips Magnavox MWR20V6 DVD Recorder / VCR Combo I have a phillips magnavox vcr dvd recorder combo model number mwr20v6 that i have had fo about 2 years and here lately every time i try to record on to a dvd it pops up with error code e454037380.i have cleaned the lens with a disc cleaner and still didnt help,same thing is happening. i am also using the same type of disc that I have been since day 1. Can you help??
Mar 09, 2011 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Magnavox ZV450MW8A DVD/VCR Recorder Dubbing.
I bought a ;magnavox dvd disc and cassette recorder combo.
I am having trouble with setup items? I get nothing on the screen to select from?
Oct 24, 2009 | Televison & Video
Magnavox dvd vcr recorder will not turn on
check fuse inside on board for power u have to take a part
Oct 08, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
My vcr won't play back
I have a Magnavox zv457mg9 DVD&VCR combo ,and the vcr records for a short period(10minutes) and then cuts off. This happens each time I try to record on the VCR. Any suggestions??
Feb 26, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Finalizing a dvd
Try this. In your SETUP options, ensure that AUTO FINALIZE and FINALIZE AT END OF TIMER are turned OFF.
Insert DVD. Press SETUP button. Be patient. Once DVD has loaded the DISK FINALIZE option will be available. You can then FINALIZE.
I found it much cheaper to get DVD-R from Radio Shack (about $5 for 25) for VHS movies that I know I want to keep. They do record up to 6 hours, even though the packaging is unclear on this point.
Dec 19, 2007 | Philips Magnavox DVD/VCR Dual Player
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
