Question about Syma S301g Rc Helicopter 18" 3 Channel Rtf 27 Mhz Transmitter With Gyro
S301g helicopter charging problem
Got a s301g copter and it worked great for two days and now when I plug it into the charger, the charger blinks green and won't charge it. Any suggestions as to what the problem might be?
Helicopter charger and batteries in remote ok, chopper won't fly
Is the "flight light" blinking on the copter? If you connect the USB cable to the copter will it power up? Have you tried different batteries in the remote? Check the pins in the charging port on the copter, Otherwise there's not a lot that can be done with these little RCs.
Feb 24, 2015 | Syma S102 IR Control Micro Blackhawk RC...
Rotor spins while charging
You have a bad flight control board. There may be a loose wire near 5be charge port making fontact wi5h the output circuit for the main rotors. Good luck
Feb 26, 2014 | Generic Udi u13 3 channel co-axial...
Syma S109g Apache Ah-64 3.5-channels Mini Indoor Helicopter will not charge; the light will keep being red on the USB
Try bringing it to your local electronics store. It might be the connection, or in could be another electrical problem.
Jan 29, 2013 | Syma S109g Apache Ah-64 3.5-channels Mini...
Just got a s301g Helicopter and it won't start up
Check the wiring where you plug in the charger to the helicopter. There is a red wire with quick disconnects. If its loose (the quick disconnect) you get this problem. In my case the helicopter came out of the box with this completely disconnected. It was hard to connect because there wasn't enough slack wire but once we did it the white light on the front of the helicopter came on and we were flying.
Nov 19, 2012 | Syma S301g Rc Helicopter 18" 3 Channel Rtf...
Air hogs pocket copter, brand new. Inserted brand new batteries into charger and controller per instructions. Plug the helicopter into charger and led blinks red as stated. About two or three minutes into...
You bought a defective mini copter, the internal micro relay is malfunctioning and I hope you could bring it back where you bought it. Replace it with a new one and let them try to test flight it before you go home.
Hope that helps you out.
Thanks for asking FixYa!
Aug 09, 2011 | Toys
X107 Mini helicopter does not seem to be taking a charge from USB port on computer. ran coptor for about 2 weeks following recharging instructions... rest, recharge of heli in "off"...
Hi, My X107 MINI HELICOPTER does not receive transmit anymore. It was working fine before. It only flys if I hold the remote control right next to the sensor. If I move it away it loses transmit. Both units have full power. How do I solve this problem.
Jan 27, 2011 | Cobra Electronics Cobra RC 3 Channel Mini...
My son got a Halo UNSC Hornet remote control helicopter for Christmas. It was working great. Then on Monday Dec. 28 he tried charging it and it won't charge. What could be the problem? We have tried...
1.Check the battery of the Copter it seems to be dryied due to overcharging. 2. Check the charger, is it supllying the power or not to Charge the battery.
The solution is to change the battery with new one.
Jan 05, 2011 | NKOK Halo Hornet RC Helicopter
My copter will not charge i plug it up,make sure copter is in off postion,but red light never goes off and copter never charges,the green light never comes on,this thing has been flown maybe 6 times since...
I just bought one for my Grandson and we had to plug in the outlet to the copter first, before pluging in the AC/DC adapter to the power charger. I know the instuctions do not explain it this way, but the green LED charging light would not come on and it would not charge doing it anyother way
Sep 27, 2010 | Silverlit Toys Ed Hardy 115" Special...
Syma S301g Rc Helicopter 18" 3 Channel Rtf 27 Mhz Transmitter With Gyro Logo
56 people viewed this question
Top Syma Video Game Consoles & Games Experts
Gil Shultz
Bill Boyd
John mullen
Are you a Syma Video Game Console and Game Expert? Answer questions, earn points and help others
