Question about Dryers
Condenser tank not filling up - Dryers
    Problem Solver:
  • 5 Answers
Check for blockage in the thin pipes take them off and clean them
Posted on Dec 28, 2013
Zanussi condenser dryers
It can be mechanical or electrical malfunction. I would check tank microswitch, float and lever.
Below is explained how the condensate drainage system works and that will facilitate fault detection.
The warm and cold air circuits cross inside the heat exchanger, which results in a thermal exchange which condenses the humidity contained in the warm air. The condensation which forms in the heat exchanger is collected in a sump, from which it falls by gravity into a tank. When the water in the tank reaches the max. level, the level of the water in the sump increases, which causes the float to move upwards, thus actioning a microswitch; The microswitch for dryers with electronic board sends a signal to the electronic circuit when the tank has been filled, switches off the appliance and lights a pilot lamp which indicates to the user that the tank is full. The microswitch with electromechanical control switches off the dryer (the timer motor is powered and ends its cycle) and lights a pilot lamp which indicates to the user that the tank is full.
Dado
Aug 10, 2014 | Zanussi Dryers
Hotpoint TDC32P condenser tank not filling
you should read the catalogue.
Mar 26, 2013 | Dryers
Fuel light came on,tank nearly empty,started bike up next morning and idles ok but badly misfires when try to accelerate,filled tank up with mobil 98 octane which i have used before and it still misfires...
Chances are condensation has collected in the carb float bowl. Drain the carb. Yes, keep the tank filled. This will lessen condensation. You may want to install a new spark plug as well.
Jun 15, 2011 | 2005 Aprilia SR 50 Ditech
First time start up
The external tank is to collect humidity (condensate) from the coil as it cools the room. You need to empty the tank when it is full, not fill the tank yourself. Hope this helps.
May 04, 2010 | Danby Portable Air Conditioner
Condensation on electric water heater
did you put the gaskets in with the elements, there should be a rubber gasket on both elements, if you did and it is just the tank condensating, when you took out the element was it easy or did you have to apply alot of pressure, if you had to apply alot of pressure you may have even cracked the tank, and it is not condensation but water comming out of the tank,, and if you are sure that you didn't then your water comming in must be real cold and you will have to wait for the water in the tank to heat up to stop the condensation,, cold water comming in comes from the bottom thru a dip tube that takes the cold water to the bottom of the tank and force the hot water out the top, if you are on well water it will be vary cold comming in,, these are the only things it could be,, by the way did you fill the tank with water till it came out of the faucet at full pressure before turning on the electric? if not you could have also burnt up both elements and the water can be seeping out of the elements beings they are plastic and when they are fried the plastic melts, so turn off the electric pull out the element check it to make sure it is intact then if not get another new one reinstall it, fill with water till it comes out of the hot side on your faucet, then turn on the electric
Jun 25, 2009 | Water Heaters
Danby dpac120068 Air Condtioner, where does the hose go? and do you fill the tank in the back with water?
hose goes into a bucket or out a window, drained, etc. it's the drain hose for the condensation. alternatively you can use the tank to catch the condensation, which must be emptied periodically.
Jun 14, 2009 | Danby Portable Air Conditioner
Water tank is suddenly filling up
look closely how the water flows from the evaporator to the tank. does it goes first to the condenser ?..or is there a heating pipe that is touching the tank in order to heat the water for it to evaporate?
here's the set up, your ac would cool and absorb moisture in the air and becomes water in the evaporator. these water is sometimes used to cool the compressor or the condenser to help it run cooler and at the same time evaporates the un-needed water . but incase the water is so much then you have the tank to keep the water from spilling. sometimes they still put some hot pipes to further heat the water to evaporate.
check those pointers that i have mention.
in some case, the air in your place just got humid and wet that is why it has too many water condensation..
Aug 08, 2008 | Danby DPAC8099 Air Conditioner
Ruud UBHC17J11NFA: Condensate pan filling up - condensate pump works fine
blow out the drain line from the coil to the pump the clog is there causing the pan to fill up and trip off
Apr 28, 2008 | Ruud UBHC Air Conditioner
Water tank not filling
Probably it is lint in the condense pump.
Jan 30, 2008 | Tricity Bendix TM310W Electric Dryer
Dryers Logo
Top Dryers Experts
