Your going to need to empty out the fridge, take the shelves out, and then remove the rear wall inside to gain access to the evaporator area. Once you can see the evaporator look directly below it and you'll noticed a trough of sorts that should have a drain hole in the middle of it. More than likely this is clogged and needs to be cleared so water can flow smoothly out of the machine
If you need further help, I’m available over the phone at
https://www.6ya.com/expert/jason_4570d45317834dd3
