Question about Vehicle Parts & Accessories
Interior lights dont work when doors open but work with roof console switch on 03 silhouette
    Problem Solver:
  • 14 Answers
Door switches or relay
Posted on Dec 28, 2013
How do i open install dome light in 2004 Silhouette?
4 screws hold the whole thing up.Open the compartments to access the screws.
May 08, 2017 | Cars & Trucks
I have a 2007 Buick Lucerne and the front reading lamps won't turn off.
Overhead Console Lamp and Roof Rail Courtesy/Reading Lamps
The courtesy/reading lamp is a duel purpose lamp that can be illuminated two different ways. First, the lamp can be turned ON during courtesy lamp operation as described above. Second, the lamps can be turned ON individually for reading lamp operation by the lamp switch. The BCM supplies battery voltage from the INT LAMPS fuse through the inadvertent power courtesy lamps circuit to the courtesy/reading lamps for reading lamp operation only. Ground for the courtesy lamp module or the roof/rail reading lamps is provided at G402
Courtesy Lamps
When either one of the front doors is opened, ground is applied through the door latch door open switch and the door open switch signal circuit to the door module indicting the door open position. In response to this signal, the door module sends a GMLAN serial data message to the BCM of the door open position. Or, when either one of the rear doors is opened, ground is applied through the door latch door open switch and the rear door open switch signal circuit to the BCM is indicating the rear door open position. Once a door open message or signal received, the BCM will then apply battery voltage from the CTSY/RF TRN fuse through the courtesy lamp supply voltage circuits illuminating the lamps listed below:
• Overhead console lamp
• Roof rail courtesy lamps
• Footwell courtesy lamps The BCM receives battery voltage from the INT LAMPS fuse in order to supply power to the inadvertent courtesy lamps. Inadvertent power courtesy lamp feature provides a similar function for the interior lamps as a retained accessory power feature. The BCM will energize the courtesy lamps supply voltage circuit when the BCM is in the active state (awake). When the inadvertent power courtesy lamps supply voltage circuit is energized, it supplies voltage to all the interior lights listed below. The BCM will continue to supply voltage to the interior lamps after the ignition is turned OFF so that the interior lamps may be operated.
• Overhead Console Reading Lamps
• Roof Rail Reading Lamps
• Vanity Mirror Lamps
• I/P Compartment Lamp
• Rear Compartment Courtesy Lamp
In the event that any of these lamps were to remain illuminated for a period of more than 20 minutes with the ignition switch in the OFF position and no BCM input activity, the BCM will deactivate the inadvertent power supply voltage circuit to prevent a total battery discharge condition. The BCM receives battery voltage from the CTSY/RF TRN fuse in order to supply power to the courtesy lamps. The BCM applies this voltage to the courtesy lamps through the courtesy lamp supply voltage circuits. When any door is opened, the door open switch contacts close and the BCM receives a door-open signal. If the BCM receives a door lock or unlock signal, the BCM will activate the courtesy lamp supply voltage circuit, providing battery voltage to the dome lamps and the left and right footwell courtesy lamps. The courtesy lamps can be manually activated by placing the interior lamp switch in the DOME position. For more detailed information concerning courtesy lamp operation refer to Interior Lighting Systems Description and Operation.
Jan 16, 2017 | Buick Cars & Trucks
2005 X-Trail interior lighting diagram
If you open other doors besides the driver door do the lights work? If so the door ajar switch is defective in the driver door. Also can you turn on the interior lights from the headlight switch control?
Jul 09, 2016 | 2005 Nissan X-Trail 2.0
The interior lights dont turn on, sun roof & car windows dont open
Sounds like a broken wire on the drivers side . A rubber boot at the front of the door. This is where the wires break first. To check for power and ground to the parts you have to pull the switches and door panel.
Aug 05, 2015 | 2007 Mercury Milan V6 AWD Sedan
Fuse panel box diagram for 2010 explorer sports trac
g06304730
F5 5 Rear window motor. Roof opening panel module. Auto-dimming interior mirror unit. Door lock switch, driver side. Door lock switch passenger side. Power window motor, driver side front. Overhead console switch assembly
Not sure if this is what you're looking for. Let me know if it works.
Jul 18, 2014 | 2010 Ford Explorer Sport Trac
Clock backlight, heating panel light and door light not working
So--there is no back-light on the heat panel and roof mounted display?
Similarly to a gauge cluster--there are bulbs that produce the back-light. I have a 90's vehicle and I had to replace the bulbs in the heat panel and on the gauge cluster. On some vehicles however you have to take the whole car apart just to access these bulbs. So--just take your time, consult a book, and check the bulbs to see if this is the culprit.
Hope this helps.
Oct 21, 2013 | Volkswagen Cars & Trucks
All the lights on the inside stop working at the same time and I can't find the right fuse
My husband and I had the same problem. One of us had hit a button on the roof console that turns off all the interior lights. Try that incase it is not a fuse. There is a fuse panel on the passenger side open the door there next to the glove compartment.
Nov 18, 2011 | 2002 Oldsmobile Silhouette
Windows and power mirrors stopped working and interior dome lights stopped working.fixed mirrors and windows but interior lights still dont work when door is opened.
on some vehicles there is a switch that disables lights some are on dash some are on the overhead light. if only one bulb ck bulb, if all lights could also be fuse
Mar 09, 2010 | 2004 Jeep Grand Cherokee
Dome lights won't work when doors open in 99 silhouette
check for a override switch. it is typically located near the headlight switch. That may have been hit by accident causing them not to work
Nov 22, 2008 | 1997 Oldsmobile Silhouette
Door Ajar Warning Light Stays On
Our Ford Expedition & an Olds Silhouette Premier & both did the same thing. Someone online said to spray the inside door where the metal connects with the frame & sensors are there with WD-40. We did & it fixed the problem. Maybe this will work for yours.
Aug 14, 2008 | 2000 Oldsmobile Silhouette
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
