Question about RCA 55" Class 54-5/8" Diag. - LED - 1080p - 120Hz - HDTV
RCA LED55C55R120Q when I power DVR and TV off with cable remote, blue background remains on TV.
I have read that this blue screen will turn off but it doesn't unless I manually turn TV off on side of TV. Do I need this option?
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 94 Answers
The code the cable remote is using is only partially controlling your TV.Try a different code for your cable remote for your brand of TV ... OR check the cable manual to have the (cable) remote controller search and "learn" the TV settings.
Posted on Dec 28, 2013
yammy_alf
  • 666 Answers
SOURCE: RCA 37" FLAT SCREEN NON STOP FLICKERING/FLASHING SCREEN
you need to remove main ckt, (m.board) some part need to re solder specially in hot area. (lost contact i one of the flickering problem you encountered.
Posted on Mar 26, 2010
hardrocko
  • 1476 Answers
SOURCE: RCA R301F1 remote problems
If you have tried 5 remotes I would have to say that the set has a problem in the remote circuit. You will need a tech to look at it and repair it. Let me know how this works out for you.'
hardrocko
Posted on Feb 01, 2010
  • 73 Answers
SOURCE: RCA universal nor cable remote will program RCA L40FHD41 TV
might be able to use the cable co remote and autosearch thru the codes, but its too hard to explain, the cable tech should have ran that procedure. unfortunately, rca has 50 million models. it is common to have a tv and yes rca for sure, to not take the codes. sometimes the tv is too new for the cable company remotes to work. i am leaning toward the tv too new theory. give it six months and i bet there will be a new remote version.
Posted on Jan 21, 2010
SOURCE: blue power light is on the tv cant turn it off
Unplug the TV wait 10 Seconds and Plug it back in. Should work fine
Posted on Jan 02, 2010
SOURCE: I have the RCA model L32HD31R LCD TV and I need
I have a RCA model L32HD31R LCD, also but the codes from comcast will not turn tv on or off.
Posted on Oct 06, 2009
My remote wont work on my led55c55r120q rca 55 inch tv, the red power light just blinks but wont do anything else, this has happened to me before, but I don't remember what I did to fix it
If you have the manual for the tv it may tell you how to reset the remote. If you don't have the manual you can most likely find it on the internet. Also you tube may have some videos. If all else fails you could purchase a universal remote..
Jun 14, 2017 | RCA Televison & Video
Screen remains locked on Blue background welcome screen when it finally comes up. Status light remains blinking green. Over the past 7-10 days it took several tries powering on then off before picture...
Tv manual PCB control buttons all work?Like power on/off,volume - + and chanels + - all work than it not the manual PCB board control IR is parts of this board.Not the IR problems,when tv is finally on the remote work fully everything buttons?No,could be remote control have problems.Tv might have DM power supply board problems.
Feb 08, 2011 | Mitsubishi WD-73737 73 in. HD-Ready TV
Hi Have Vizio Flat Screen and a Denon 3803 receiver. The Tv a Vizio 65 Inch flat screen was here. Out of the wall is a power cord and red,blue,green monster cable. Red and Blue is audio and green video I...
Red, Green and Blue cables together typically denotes a component video signal - an Analog, High Definition transportation for video. This cable does not carry audio, you need another cable to hook up audio between the DVR and receiver. You can use either an RCA stereo cable (red and white), optical-audio, HDMI, or a whole plethora of other audio cables. I would recommend optical or HDMI to get the most out of your system.
Jul 16, 2010 | Denon AVR-3803 Receiver
I need to know how to hook up my vcr to my dvr to record something off of it onto a vhs tape. directv said i need to contact the maker of the vcr & guess what RCA doesn't help with that. but i...
Ok. You connect the vcr to the televison first. Take an rca cable and connect it to the video out of the vcr then connect the other end to the av input on your television. Then take another set of RCA cables and connect them to the RCA av input on your vcr and connect the other end to the output on your dvr.
Now hopefully your tv has another RCA input you can hook directly to the dvr with another set of RCA cables to another one of the dvrs outputs. If not then don't worry about that.
Now make sure the tv is switched over to the av video RCA input the vcr is connected to and turn the vcr on. The vcr should be in input and when it is you will see the picture from your dvr and you will change channels with your dvr remote. You can now record using the vcr remote.
Jun 14, 2010 | RCA VR546 S-VHS VCR
Cant program my rca rcr4258 remote it has no setup button
  1. 1. Manually turn on the component you want the remote to control (TV, VCR, DVD, DVR, satellite receiver, or cable box).
  2. Press and hold the component key (TV, SAT•CBL, DVD•VCR, DVR•AUX) you wish to program. The LED turns on and remains on. Keep holding down the component key.
  3. While holding the component key down, press and hold the POWER key. The LED turns off. After holding down both keys for three seconds, the LED turns back on.
  4. Release both keys. The LED remains on.
  5. Press and release the POWER key repeatedly until your component turns off. Each time you press the POWER key, the LED blinks, and the next code in the list is sent. This process continues until all of the codes in the Code Lists have been tried. If your component turns off, you have found the correct code. (If it cycles through and the LED blinks four times and turns off, all codes have been searched. The Manual Code Search method is exited.)
  6. Once you have found the correct code, you must save the new code by pressing and releasing the STOP key. The LED turns off. You must press the STOP key to save the code or the correct code will not be stored! When you press the STOP key, the code is stored.
Click here to Download full manual with codes
Nov 23, 2009 | RCA RCR-4258 Remote Control
I have a DVR from my cable company which I recently replaced. I have the cable coming to the DVR, then out to my RCA DVD recorder, then out from the DVD to my Vizio TV. I have an HDMI cable connection...
IT SOUND LIKE THERE SHOULD BE AN INPUT BUTTON ON YOUR CABLE OR T.V REMOTE TRY CHANGING THE INPUT. ALSO TRY PLUGGING DIFFERENT AUDIO AND VIDEO CABLES BETWEEN RECORDER AND TV. ALONG WITH YOUR HDMI.
Oct 22, 2009 | RCA Televison & Video
Cannot tape on vcr with new dvd-vcr player
You need to route the signal from the cable modulator to the DVR and then to the TV to be able to view and record. If this is done you will be able to watch what you are recording. When you are not recording, the signal will go through the DVR to the TV.
Please change the cabling and you should have what you want.
May 26, 2009 | RCA 32V550T 32" TV
Blue screen on my haier 37 inch tv
my tv just went to a blue screen one day. I can turn it on and then it will just remain on the blue screen. Any button (except the volume) I push on the remote comes up on the screen "no signal". What would you suggest? I have been reading about replacing a fuse or board? Most of those are on the 42 inch version---I have teh 37 inch version.
Feb 02, 2009 | Haier HL37S 37 in. LCD HDTV
No Sound In Home Theater with Dish HDTV DVR Dual Mode Remote Connection
HDTV is not carried via coaxial cable from tuner, you need HDMI or the 5 RCA cables that are different colors. I forget if they are called component or composite, I think they are called composite, the R and W are sound. If you run the HDMI or composite cables to your TV, there should be a variable out or audio out on the back of the TV that outputs ANY sound coming into the TV, like Wii, DVD, tv, etc. So if you want to listen to tv sound, just pipe the audio out to the receivers available input and turn it up. Cant be used with mag input (turntable) all others are compatible. Did this answer your question? Sat cables are usually kept under 130 ft from the dish, and the dish receiver can output coaxial signal over 400ft on RG-6 cable. HDMI is limited and can get very expensive. Does your sat box have a coaxial digital out (orange RCA) you can use that if your receiver can read it, usually associated with the DVD input or video input, but only for digital encoded programs.
May 19, 2008 | Insignia 5.1-Ch. Home Theater System with...
RCA 55" Class 54-5/8" Diag. - LED - 1080p - 120Hz - HDTV Logo
169 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
