Question about Car Audio & Video
Pioneer car stereo
Stereo has kept surging on cd mode since the battery died and was replaced
  • steverichab Dec 10, 2007
    Ever sence my battery went dead and I had to get a jump I cannot put my factory install 6 disc changer into CD mode. I've checked for fuses but all look well. Besides the radio works fine. the only thing in the vechical that is not working is the CD changer
    Problem Solver:
  • 5 Answers
You may have a burnt fuse.
Posted on Oct 18, 2007
My stereo just quit on me there was bad weather but it was on one of those power surge cords it is a pioneer stereo fm-am digital synthesizer tuner
If it was plugged into a surge protector, check the surge protector warranty. There are A LOT of surge protectors that will cover damage to items plugged into them through their warranty system. I've had full home computers and TV's replaced by surge protector companies to avoid having a hit to homeowners insurance.
Aug 16, 2016 | Pioneer Audio Players & Recorders
I have the pioneer super tuner 3 DEH-1900MP. My car battery died the other day we jumped it and it is working fine but i cannot figure out how to turn back on the sterio. How to I turn it back on I've...
I have the DEH-1200MP model super tuner 3 and it would not power up after battery died and was jumped. There is a fuse at the back of the stereo that I unplugged and plugged back in and then the stereo powered up. I had already checked all of the other fuses. Took me a while to figure this out.
Jul 04, 2010 | Pioneer DEH-P690UB CD Player
My car battery died, after giving the car a jump, the car started, but now my pioneer DEH-P2900MP car stereo won't work at all. could you please assist. thanks.
If you have already checked the fuse(s) that supply the radio and none are blown, you may want to try to reset the unit by disconnecting the power feed to it. Keep in mind that the radio likely has two power feeds...one for the ignition and another that keeps all memory functions up and running, even when the ignition is off. Disconnecting both of these may allow the radio to reset.
Feb 11, 2010 | Pioneer DEH-P2900MP CD Receiver...
I have a 1998 Pioneer head unit to put in my car. the #is 1256237179. Is There anyway to get a diagram to see how to hook it up?
Well you can please follow the below steps -
1. Disconnect your car battery. It is vitally important to your safety that you never work on any type of electronic in your car with the battery still connected, as this puts you at risk for electrocution.
2. Remove the old stereo by taking off all the dashboard panels surrounding your stereo, sliding out your old stereo head unit, and unplugging all the wires that are connected to the head unit. Discard the old stereo.
3. Take your Pioneer car stereo head unit and plug each of the positive wires from your car speakers to the positive terminals on the head unit. Take all of the negative speaker wires and connect them to the negative terminals on the head unit.
4. Attach the stereo's black ground wire to a metal bolt or screw located near where the stereo is mounted in the dash.
5. Connect all of the ignition power wires to your Pioneer stereo.
6. Take the harness connector and plug it into your car stereo. Now plug the antenna into the back of your head unit.
7. Slide the stereo back into the dash, screw it in place, and replace the dashboard pieces you removed earlier.
8. Reconnect your car battery, turn the car on and test out your new Pioneer car stereo. Please post comments for more help or information..........
Good Luck!!
Thanks
Jan 16, 2010 | Sony CDX-F7710 Car Audio Stereo CD MP3...
Lost memory
Car stereos typically have an "ignition" and a "battery" wire. The ignition wire is connected to your ignition switch, and only supplies power to the stereo when the car is turned on. The battery wire is connected directly to the battery, and always supplies electricity to the stereo -- even when the car is off. This maintains presets, clock, and other settings in your stereo.
It sounds like your battery wire was either not hooked up, or has come loose. On your stereo, a Pioneer, this wire is yellow. Locate the yellow wire on the wiring harness on the back of your stereo. This wire should be connected directly to your battery (or another source that gets constant +12VDC).
Sep 14, 2009 | Pioneer DEH-P3600 CD Player
I love loud music
i have alpine stereo's in all my vehicles and i have had this problem. if you run a 10-14 gauge constant wire from the stereo directly to the battery the stereo will not shut down in protection mode. it is not the cd it is the stereo going into protection mode because of lack of current not voltage. i hope this helps after i did this i could play the stereo as loud as it can go until my battery died
Oct 28, 2008 | Alpine CDA-9856 CD Player
Auxillary mode: can't get to it!
did your battery die after you installed cd player or did it die because of some other reason. please first confirm this since wrong connections are the biggest culprit .best of luck.
Jul 13, 2008 | Pioneer DEH-P80MP CD Player
How to wire into a renault clio mk2
should plug straight in / there should be 2 connector blocks one with all the power leads and the other(8wires) for the speakers
Jan 19, 2008 | Pioneer DEH-P6600 CD Player
Pioneer X MT- 2000 Stereo Bookshelf Unit - No sound!
It definitely sounds like it took a surge. yhe Power Amop IC in those things are pretty sensitive. Any decent repair shop should be able to repair it for under $125.
Sep 18, 2007 | Audio Players & Recorders
Cd/stereo not working
Hi, The "sec" could probably stand for security lock. It is a feature to discourage car stereo theft but is prooving to be more of an owner's problem when battery dies or are replaced or simply when disconnected for maintenance or whatever. The sad part is you have to get in touch with the original dealer of the car who would probably ask you for registration papers, proof of ownership (deed of sale), VIN, make/model/serial number of the stereo and/or other documents. I know its a bit of inconvenience but there is not other way since they have to check a database and fill in so many data themselves. I just hope the dealer is friendly enough. Good luck and kind regards.
Aug 06, 2007 | Pioneer DEH-P44 CD Player
Car Audio & Video Logo
43 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
