Sanyo dp50719 i want a used sanyo screen panel dp50719 my screen is cracked
  • Televison & ... Master
  • 9,639 Answers
Finding a used screen is looking for a needle in a hay stack. You will have better luck looking on Craig's list for the same model that isn't working. Replacement screens can be had...just google them and you'll be able to find one. Price may shock you and with shipping and installation costs it may be more than a new tv.
Posted on Jan 06, 2014
2 Suggested Answers
walesarumi
  • 6993 Answers
SOURCE: My sanyo dp50719 tv comes on and right back off
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board.
I do not think it needs replacement, rather some defective capacitors are causing this issue.
Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors).
After replacing these capacitor(capacitors) most likely the normal operation will be restored.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Good luck.
Posted on Mar 02, 2011
What are my options for a cracked sanyo dp50843 TV screen
Have screen replaced (search the net.) for prices on new and used or replace TV.
Feb 10, 2016 | Sanyo REFURBISHED DP50843 50IN 1080P 60HZ...
Picture on a Sanyo dp42848
Fault with main board. Damaged component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ .
Sep 08, 2014 | Sanyo DP26648A DP32648 DP37649 DP42848...
Cracked screen want phone number costamer service
Contact the authorized service center for Sanyo. Cracked screen cannot be repaired. It has to be replaced with a new one.
Gopakumar Gopalan Google
Apr 23, 2014 | Sanyo Televison & Video
My flat screen tv has a cracked screen
No, cannot be repaired, only replaced. A replacement panel could cost as much as a new TV set.
Jan 08, 2013 | Sanyo DP42849 42 in. HDTV
Sanyo dp26649 cracked screen can it be replaced ?
Sorry, The cost of a new screen/panel would exceed the price you paid for the TV.
Oct 22, 2012 | Sanyo DP26649 26 in. TV
I need to replace screen on my sanyo tv model #DP42840
If screen (display panel is bad, cracked or damaged in any way the cost of the part will exceed the cost of this set when new or even the cost of a new set to replace it.
May 23, 2012 | Sanyo Televison & Video
Need to remove close caption from sony dp50719 but I do not have a remote control
you should be able to access an navigate the menus using the channel and volume buttons on the TV. Here's a link to the user manual if it helps:
http://us.sanyo.com/dynamic/product/Downloads/DP50719%20manual%20337-48985803.pdf
you can also purchase a new remote for $24.99 here
http://us.sanyo.com/SANYO-Store/Model-Specific-TV-Remotes
Sep 14, 2010 | Sanyo Televison & Video
Sanyo DS32746 screen cracked
The panels cost more than the TV. Check ebay for lightning damaged units and make the swap.
Sep 18, 2008 | Vizio L32 32 in. LCD HDTV
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
Electro Med Services...
