SOURCE: parts breakout for stihl 041 (farmboss) chain saw
Stihl has terminated almost ALL support for this model and Illustrated Parts Lookups are not available online for Stihl products.
SOURCE: Stihl Farmboss - cord will not move
try taking plug out to see if it turns then.if not take off pull cord assembley to see if something has come loose and jammed flywheel, failing that could possibly have snapped the piston ring and jammed. oh yes one last thing check clutch if you have chain brake on and clutch is jammed obviously wont turn.
SOURCE: I have a stihl 041 farmboss and I am getting
Yes, but the location of the oiler is a secret.
An entire thread dedicated to your question follows (see post 5):
http://www.arboristsite.com/showthread.php?t=33705&highlight=041+oiler+adjustment
Please go here and request a manual. Please ask they add one that can downloaded too.
Stihl Product Instruction Manuals
http://www.stihlusa.com/information/info_product2.html
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
SOURCE: where can I purchase a
MANUFACTURED BY: STIHL ANDREAS MASCHINENFABRIK
STUTTGART, GERMANY
SERIES OR ASSEMBLY NUMBER: 1110
YEAR INTRODUCED: 1967
YEAR DISCONTINUED: 1977
ENGINE DISPLACEMENT: 61 ccm (3.72 cu. in.)
NUMBER OF CYLINDERS: 1
CYLINDER BORE: 44mm (1.72 in.)
PISTON STROKE: 40mm (1.57 in.)
CYLINDER TYPE: Aluminum with chrome plated bore
INTAKE METHOD: Piston ported
MANUFACTURER ADVERTISED H.P.: 3.7 (5.5 HP @ 7,000 R.P.M. DIN)
WEIGHT : 6.2 kg
OPERATOR CONFIGURATION: One Man operation
HANDLEBAR SYSTEM: Rigid
CHAIN BRAKE: none
CLUTCH: Centrifugal
DRIVE TYPE: Direct
CONSTRUCTION: Die cast magnesium
MAGNETO TYPE: Bosch
CARBURETOR: Tillotson HS 29A, B, C, D,
HS-77A, B, C, HS-87A, HS-100A, HS-138A, HS-208A
MAJOR REPAIR KIT: RK-21HS for HS-87A, HS-100A
RK-23HS for all HS-29A, all HS-77, HS-138, HS-208A
MINOR REPAIR KIT: DG-3HS for HS-87A, HS-100A
DG-5HS/T for all HS-29, all HS-77, HS-138A, HS-208A
AIR FILTER SYSTEM: Nylon mesh element
STARTER TYPE: Automatic rewind (Fairbanks Morse type)
OIL PUMP: Automatic
OPERATING RPM: 6,500 to 7,000
IGNITION TIMING: 2.5mm (0.1 in.) before TDC
BREAKER POINT SETTING: 0.4mm (0.016 in.)
FLYWHEEL/COIL AIR GAP:
SPARK PLUG TYPE: Bosch WKA175T6
SPARK PLUG GAP: 0.51mm (0.020 in.)
CRANKSHAFT MAIN BEARINGS: Ball
FUEL TANK CAPACITY: 560ml
FUEL OIL RATIO: 20:1 after break in.
RECOMMENDED FUEL OCTANE: Regular
MIX OIL SPECIFICATION: Castrol 2-stroke SAE40
CHAIN PITCH: 3/8 in., optional .404 in.
CHAIN TYPE: Oregon
BAR MOUNT PATTERN:
SHORTEST GUIDE BAR SUPPLIED: 35cm (14 in.)
LONGEST GUIDE BAR SUPPLIED: 63cm (25 in.)
COLOUR SCHEME: Grey with Red top cover
PAINT CODES:
ILLUSTRATED PARTS LIST:
SERVICE MANUAL:
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
