Question about Ezip Currie 1000 Electric Scooter, Black
Where is fuse located on ezip 1000 - Ezip Currie 1000 Electric Scooter, Black
  • 4 Answers
There is a fuse in front of the battery area that is covered by a metal cover plate. There are two screws on the top of the L-shaped cover which might be hard to unscrew. Exercise patience, use penetrating fluid(s), & try not to de-form the screw head. Otherwise, you shall probably have to cut them off to get the plate off & work the screws out with pliers.
Posted on Jan 22, 2016
Hi I have a ezip 400 scooter we just bought a new charger and the charger has a green light but the ezip its charged I was thing maybe its a loss wire or something I got the ezip from someone said if
Push the circuit breaker back in first. The scooter will not move if the charger is connected. If the scooter has sat unused for a long time, the charger will NOT recover the batteries. Charge them individually with an automotive charger until the voltage is at least 11 volts each. May take a 12 or more hours. If you can't get 11 volts after that time then the batteries are gone.
Oct 04, 2014 | Health & Beauty
Wont start razor e300
On my eZip 1000 scooter, in front of the battery pack, there is a compartment that houses the controller & assorted connectors & wiring. There is also a plastic housing that contains 2 fuses. Check, inspect & test the fuse(s) with an ohm meter for continuity. If all other components are functioning normally, it's probably the fuse(s) that need replacing. Hope this helps.
Oct 02, 2014 | Razor E300 Scooter
2003 Honda VTR 1000 SP-2 fuse box location
Hi, Anonymous for this scenario you will need your service, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
2003 Honda VTR 1000 SP 2 fuse box location Google Search
circuit fuse box location
Honda VTR1000F Service Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda VTR1000F Firestorm Owner Manual
Apr 19, 2014 | 2003 Honda VTR 1000 SP-2 (RC51)
Scooter won't run
How old is the battery? Most are only good for three years........
Mike
Mar 15, 2014 | Ezip Currie 1000 Electric Scooter, Black
Ezip
The light came on because the charger brought voltage up to full, but when you hit the throttle, the voltage dropped since the charger cant power the motor. While checking the wiring (which I assume people automatically do), bypass the power switch with a screwdriver or a jumper wire. If it works, replace the switch. Check the battery with a multimeter...you should get > 25.2v full charge, no load. If you get 0v, check the fuse in the battery case. If all of the above check out ok, and it's totally dead, you probably need a controller.
May 28, 2013 | Currie Technologies eZip Mens Trailz...
Ezip 150 electric scooter. won't start.
Hi, did you charge the batteries for at least 8 hours? Make sure that your charger has a RED Light When you plug it in, You should see Green light in 4-8 hours depending on the Batteries.
Secondly Your scooter batteries were dead when you got the Scooter, Judging from the fact you didn't get a Charger with it. I would recommend getting a voltmeter and checking the battery voltages. If the voltage is 11-12 volts, then you need new batteries. If this doesn't work check that fuse on the scooter it could be blown.
Apr 15, 2009 | Electric Currie EZIP 500 Scooter
Ezip Currie 1000 Electric Scooter, Black Logo
396 people viewed this question
Top Ezip Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you an Ezip Cycling Expert? Answer questions, earn points and help others
