I am assuming you mean the rear ones! you neeed to jack up and support the car, as you will be moving the rear subframe support the car on the forward end of the large arms that go to the floor (it is allways solid there) depending on the make and condition of the exhaust you might get away without disconnecting too much of it. support the subframe centrally with a jack, unbolt the 4 nuts and bolts that hold the mount to the subframe, lower the subframe enough to unbolt and change the rubber mounts, if the exhaust or brake flexy stop it dropping enough to change the mounts disconnect them, refit and tighten.
Front or rear???
