Question about Behringer Music
How to connect a behringer Xenyx X1222 to a behringer europower PMP6000
hmerchant110
  • 7191 Answers
SOURCE: I need an owner manualfor a Behringer pmp 3000 16 channel mixer
You can download the manual by clicking this link
You'll require Adobe PDF Reader installed on your PC to view this manual. If it is not already installed on your PC, download it free from:
http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa
Posted on Jan 15, 2010
  • 5603 Answers
SOURCE: LEVEL POT ON A BEHRINGER EURORACK MX 602A-BAD
It appears that both these use a 50K pot in the identical circuit and it is UNLIKELY they re-engineered very much so it is likely they use the same pot.
Behringer parts service should be able to tell you.
Posted on Apr 28, 2010
sparky1500
  • 1066 Answers
SOURCE: i just both the Europower pmp6000 powerd mixer and
use 1/4 inch speaker cables. hook one speaker up to "main 1 R" out and the other to "main 1 L" out. if you have additional main speakers, hook them up the the "main 2" outputs.
look for the "bridge amp mode" switch and move it to the "main L- main R" position.
Posted on Nov 06, 2010
mrwtech727
  • 75 Answers
SOURCE: how to connect a Behringer XENYX 2442FX Mixer to a
you need a cable with two A3F  XLR s going to a 1/8" stereo phone plug, male. plug the XLRs into the Main out L&R on the mixer. plug the 1/8" into the LINE Input on the laptop. You should be able to get the cable from any music store,or Radio Shack. below is a link to the manual,in case you don't have one. Good Luck!
http://www.behringer.com/assets/1622FX_P0557_M_EN.pdf
Posted on Sep 01, 2011
  • 5603 Answers
SOURCE: i want a labelled diagram of behringer 2442fx mixer
Here: http://elektrotanya.com/behringer_ub2442fx-pro_sm.pdf/download.html
Scroll down to "get manual" and click to download. IGNORE other download links.
Posted on Dec 09, 2011
.necesito un diagrama esquematico para europower MPX 5000
.necesito un diagrama esquematico para europower pmp5000 pmp6000
Jun 29, 2012 | Behringer Europower Pmp5000 Powered Mixer...
I can't get my Behringer XENYX X1222 USB to control any of the faders within Sonar X1 Producer.
It may require the driver to be installed for the Behringer, or re-installed.
Go into the settings section of Sonar and if you can "De-select" M-audio as the default controler, or you may need to go through the preferences of M-Audio to find it.
To me it sounds like a driver is missing.
Jan 30, 2012 | Music
How would i connect a Behringer 1002B Xenyx to a hercules mk4 mixer
The main output jacks of the 1002 are PSUEDO balanced so you can use TS to RCA connections from the 1002 to the MK4. It is not hte best design, but it will work... with two cables go from the 1002 main outs to the stereo ins of the MK4.
Sep 19, 2011 | Behringer XENYX 1002B Mixer
Hello! I have a Behringer EUROPOWER PMH 1000. But the power board burnt source. What do I will acquire another, or fixable?
Often teh power supply fails because of other problems. Unless the board has flame damage the parts that are defective can be replaced... Getting some of the parts that are special can take time. Most of the components are available at many sources however. The SPS400 power supply can be repaired.
Here is link to schematic that should have the SPS400 as well as the rest of the PMH1000 on it.
http://elektrotanya.com/behringer_pmh1000.pdf/download.html
Jan 18, 2011 | Behringer XENYX 2442FX Mixer
How do i hook up my jbl-jrx112m monitors to my pmp6000 so i can control sound volume,i have sound but only main control not monitors
You have to make a choice... you can tie two main speakers to the "B" channel and the two monitor speakers to the "A" channel.
The speaker configuration slide switch is set to MON1/MONO. The main slider controls the volume of the mains and the MON1 slider controls the level of the monitors in conjuction with the rotary MON1 knobs for each channel.
Each output should not be loaded heavier than 4 ohms. This would be a max of two 8 ohm speakers for each output.
Dec 24, 2010 | Behringer Europower Pmp5000 Powered Mixer...
My pmp6000 wont work in mon1/ mono mode. I have one speskon channel going to two mains and the other to two monitors Can't get sound.
OK... from the schematics it appears that when in mon1/mono mode you use ONLY the MON1 gain controls, including the channel MON1's and the MON1 slider. Make sure you have each of those turned up as needed. In this mode, MON2,s and the MON2 slider are unused. The MONO slider controls the MAIN output.
Dec 03, 2010 | Behringer Europower Pmp5000 Powered Mixer...
I just both the Europower pmp6000 powerd mixer and Eurolive b215xl speakers and i need help conecting the speaker to the mixer. I will be using it with some mics at a function in an hotel. How do I connect...
Nov 06, 2010 | Behringer Europower Pmp5000 Powered Mixer...
My beringer europowered 800w mixer blew a fuse ,replaced it ,has blown several more fuse's since,i used a lower 5 amp fuse did not last - 10 amp is standard > is it time to trash this unit?
I don't understand because the Xenyx 1002fx draws only 16 Watts so the fuse should be well less than 1 amp why would you put a 5 amp?
And your 800 Watt mixer???... There is something wrong with this model number as the 1002fx certainly is not 800 Watts. Please supply the correct model numbers so we can help you.
The unit is repairable I am sure.
Aug 21, 2010 | Behringer Xenyx 1002fx Mixer 10 Input 2...
Music Logo
19 people viewed this question
Top Behringer Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Ben Armstrong
Are you a Behringer Music Expert? Answer questions, earn points and help others
