Question about Other Sports Afield Executive Gun Safe Vault SA6033 60x33x20 Black
Serial number for sports afield safe a6033
Where can I find the serial number on a Sports Afield SA6033 Executive Vault safe?
Why distributer drive gear lays done
check the drive system for the distributor
ford employ a shaft that drives the oil pump and if the oil pump is under undue stress, it strips the gear or breaks a shear pin
all the gear is driving is a distributor shaft and in the first instance could be a seized bush for the shaft but with replacements failing I would be looking further afield , like an oil pump
Apr 04, 2016 | 1994 Ford Taurus
Toyota platz. 1000 cc. misfired. replaced one coil. now its working fine on idle. the part number is not the same. now it still surch or misfire when im driving. do I have to get the correct coil. it
misfires can be the coil but it can be also a faulty injector operation. The part number should not make a great difference as it idles ok so check further afield for the fault . Check fuel pressures as well
Oct 28, 2014 | Cars & Trucks
I need ea sports madden nfl 13 serial number, i have lost mine
Call EA and explain your situation. They are your only hope if you have truly lost yours.
Jul 30, 2014 | EA Sports Video Game Consoles & Games
Sports afield 6040 executive vault how to reset combination
Spot Afield safes default code is 1,2,3,4,5,6. Open the safe door, with door open lock the handle. This will let you have assess to your things if you have trouble while setting the codes. To change the code, press the * 6 times. You should hear a single beep and one flash from the LED, then enter the default code 1,2,3,4,5,6. Again you should hear one beep and see one flash. Enter the new code you would like to use ...lets say 6,5,4,3,2,1. You should hear one beep and see one flash. Enter the new code again 6,5,4,3,2,1. The code should now be set to 6,5,4,3,2,1. Try the new code and see if it unlocks the door. Also try the old code to make sure it no longer works.. If at any time during the process you hear 3 beeps and flashes something went wrong. You will need to start over.
Good Luck!!
Jun 30, 2014 | Other Sports Afield Executive Gun Safe...
Reset gun safe combination
I have a similar safe, although it is a different brand. I have a red button under the top of the safe, around where the battery's go in. I have to hold that button until I hear a beep and a red light flashes. Then I'm required to input the new combination. This may, or may not, work for you.
I recommend contacting the manufacturer and asking them.
Apr 28, 2013 | Safe International Adg Sports Secure Vault...
Need to change safe combo. I have the current combo. The safe is an Executive Vault EV-600.
Best bet is to contact Executive Vault on Monday. Each safe and safe manufacturer has specific details. Sometimes you cannot change the code.
Jan 06, 2013 | Toys
Lost combination the protective executive safe
Contact the maker by phone to see if there is a way to recover or reset the combination---most safes have a serial or id number which will tell the maker what the default combination for that safe is.
FYI: you have this posted in tv section.
Apr 05, 2012 | Televison & Video
Is there a shoe repair service for Geox shoes? Local shoe repair shops are unable to replace the unusual soles on the 3 pair of Geox Suede boots I own. Zappos was no help, neither was Geox Customer...
if the local shoe repair shop was of no help, then look further afield. We had a guy named "cant fix Bill" that ran a repair shop in our town. In case you have him in your town now, there are options to repair them!
Aug 22, 2011 | Geox Clothing Accessories
I need to replace the electrical lead and pedal to connect to my elna machine model 1010 , any idea where to look?
try www.sewingpartsonline.com for this, I'm assuming you are in the USA and need 110V foot control and lead? If not and you need a 240V cable, might need to try further afield.
www.sewusa.com is also a good source for sewing machine parts
Mar 10, 2011 | Elna 1010
Other Sports Afield Executive Gun Safe Vault SA6033 60x33x20 Black Logo
126 people viewed this question
Top Other Home Security Experts
Lawrence Oravetz
Are you an Other Home Security Expert? Answer questions, earn points and help others
